My 93AllTrac Project
Postby 93cc » Mon Aug 27, 2007 2:27 am
The AllTrac has been in the shop for a while and close to being done and I thought I should post what has been going on with project...
Here is the current list of things being done...
AMD 3SGTE PRO Engine Build
J&E Pistons w/ Pro Seal Rings and Pins
ARP Rod/Head/Main Complete Stud Kit
Cometic 8.6:1 Head Gasket
ACL Coated Main, Rod, Thrust Bearings
Plugs/Cap/Rotor
Shimmed, High Volume Oil Pump w/ Gasket
Waterpump,Tstat,Orings,Gasket
Oil Pan Modification for ARP Main Studs
AMD PRO Head Port/Polish
Stage 2 head w/Port 65lb sprins/simless
Nissen OE replacement radiator
AMD 600hp core FMIC with 2 1/2 pluming
AMD Competition Airbox
Complete Transmission Rebuild
Walbro Drop-In HP Fuel Pump
Samco coolant hose kit
Transmission cooler upgrade
Greddy BOV
Silicone fill of engine & dif mounts
Power Coat all suspension components
SPA oil and temp guage
R&R hood hinges
Painted engine bay (since the engine was out)
Cermanic coat Turbo/manifolds/Shield
R&R wheel bearing and seals
H&R 25mm wheel spacers
Gold Zinc plating all the old rusted bolts/brackets
Top mount fuel rail
550cc RC injectors (At least... Probably bigger)
AMD subframe busing kit
Autronic SM4 ** Updated **
Newest update
Aquamist Water Injection ** Wife bought it for my Birthday **
I think thats it... Things have changed as the project has moved along.
93 Black AllTrac
13 Scion FRS - Current Daily Driver
81 Black/Blue Celica - Sold
2007 Silver Tacoma Sport
93cc
56k warning
Postby 93cc » Mon Aug 27, 2007 2:37 am
Here are a few pictures I took the other day...
93 Black AllTrac
93cc
Postby WarTowels » Mon Aug 27, 2007 2:51 am
Looks amazing!
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby fhalperformance » Mon Aug 27, 2007 3:49 am
Sounds pretty extensive. Bigger turbo in the works or no?
'93 trac - V6TT project.
'91 trac - 564awhp.
'91 mr2 - parting out.
'04 ducati 999
'04 tacoma TRD - for sale
fhalperformance
Postby 93cc » Mon Aug 27, 2007 2:26 pm
Not right now... I think I will just run with the one I have for now and see how things go. As it is I might be pushing the limits of the stock brakes.
I should also say I already have 3" exhaust from the cat back.
93 Black AllTrac
93cc
Postby vip09 » Mon Aug 27, 2007 3:15 pm
Looks great. Very clean build.
It will probably be around stock performance with the lowered compression and stock CT26.
vip09
Postby 93cc » Thu Sep 06, 2007 9:54 pm
Picture from the other day with the engine in the car
does anyone know if the throttle cable can be made shorter or if there is one from another car that can be used. [/quote]
93 Black AllTrac
93cc
Postby WarTowels » Thu Sep 06, 2007 10:08 pm
I'm no pro, but I'd heard of people cutting it and/or rerouting it behind the engine so it's not awkwardly wrapped around front. I'll see if I can find that thread for you.
EDIT: It's discussed here:
http://www.alltrac.net/phpBB2/viewtopic ... 158#198158
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby 88st165 » Fri Sep 07, 2007 12:48 am
wow that looks awsome! :shock:
Black st165 - gone
2011 FA5 - Family Truckster
88st165
Images: 2
Postby Trumanpriest » Fri Sep 07, 2007 2:58 am
That really looks amazing. I bet you're gonna smile ear to ear every time you open your hood- I would.
Trumanpriest - 1990 ST185 | 2010 Tacoma 2.7 SR5 | 2009 Yaris
Trumanpriest
Postby 93cc » Sat Sep 08, 2007 8:13 pm
I think it make guys feel like chicks do with diamonds. :wink:
93 Black AllTrac
93cc
Postby fhalperformance » Sun Sep 09, 2007 4:24 am
^ very true
'91 trac - 564awhp.
'04 ducati 999
fhalperformance
Postby WarTowels » Sun Dec 23, 2007 5:53 am
Any progress / updates?
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby 93cc » Sun Dec 30, 2007 11:30 pm
They should have finished all the wiring for the Autronic Saturday and now just have to weld the piping and add fluids. I took some new pictures but now I can't find them. I may have to go back and get more pictures.
93 Black AllTrac
93cc
Postby Puffy » Mon Dec 31, 2007 1:03 am
93cc wrote:does anyone know if the throttle cable can be made shorter or if there is one from another car that can be used.
Use an ST182 throttle cable.
Below is a good write up of a 205 going with a 182 cable.
http://www.gtfours.co.uk/how_to/throttl ... rottle.htm
Puffy
