Mike's '92 ST185 Teal in New York (Daily Driving It)
Postby mike325ci » Wed Aug 29, 2007 11:46 pm
Inspired by Towel's post and also from having the pleasure of reading through the other "projects" here, here is mine. I didn't make one before because frankly, I don't see my Celica as a "project" and wasn't going to do much to it. But my plans changed this year after I decided to keep the car and "freshen" it up and restore it. So here begins my story.
Car: 1992 ST185 Teal (Color Code 749), Grey Leather, All Options
Date Purchased: July 1, 2005
Mileage when purchased: 70,190
Current Mileage (4/2010): ~72K
Goal: To restore and refresh the car to stock spec, while freshening up the suspension for cone dodging duties. And to eat a few WRXs while I'm at it. :D
Quick story: I bought this car shortly after I sold my '88 ST165 because I realized that I really missed having a running turbo car. I had an SW20 MR2 at the time, but it was totally apart and a big project (eventually sold off the entire thing and ended the project). I bought it locally from a fellow ex-MR2 owner. I had seen the car for the first time the year before at our annual MR2/AllTrac meet and I knew it was mint. I wasn't planning on touching the car at all. And at one point, I considered selling this car as I was looking to cut down on my total # of cars (I had at that point owned 5 cars and was looking to get a 6th!). After some thought I decided that I would keep the car as I know it'll be hard to find another like this and I know I'm going to miss it again. Shortly after, I decided that if I were to keep the car and enjoy driving it, I would need to make a few changes, namely in the brakes and suspension, to bring the car up to my liking. And thus begins my "project" in 2007. Most of this work was completed in November 2009. The inaugural "coming out / test & tune" autocross took place on April 3, 2010.
Current Mods/Work Done "Before" Project in 2007:
Some photos of the following collected here: http://www.mchoi.com/go/carpix/ST185/first_mods_round1/ -and- http://picasaweb.google.com/mike325ci
Body/Exterior:
H4 Headlight Conversion
JDM Clear Signal Lens http://www.mchoi.com/go/carpix/ST185/fi ... n6126.html
Replaced front Faux CF Trim with JDM one (original had chip in it http://www.mchoi.com/go/carpix/ST185/fi ... n6053.html )
Rallyarmor Mud Flaps (prototype) http://www.mchoi.com/go/carpix/2007_06_ ... CN7263.htm
17x7.5" Volk CE28N Bronze Wheels with 225/45/17 Kumho ECSTA MX Tires w/Rays Aluminum Lug Nuts http://www.mchoi.com/go/carpix/2007_06_ ... CN7275.jpg
Engine/Exhaust/Drivetrain:
Magnecor KV85 8.5mm Silicone Ignition Wires http://www.mchoi.com/go/carpix/2007_05_ ... CN6969.htm
Rebuilt the distributor
Replaced Valve Cover Gasket http://www.mchoi.com/go/carpix/2007_05_ ... CN7069.htm
TwosRUs Valve Cover Bolts http://www.mchoi.com/go/carpix/2007_05_ ... CN7077.htm
Painted Valve Cover flat black http://www.mchoi.com/go/carpix/2007_05_ ... CN6987.htm
Speed Source Brass Shifter Bushings http://www.mchoi.com/go/carpix/2007_05_ ... CN7064.htm
Replaced alternator and power steering belts http://www.mchoi.com/go/carpix/2007_05_ ... CN7082.htm
Cleaned/rinsed out intercooler tank
Brakes/Suspension:
Replace front and rear brake pads w/Toyota OEM
Interior/Safety:
Replaced original 3-in-1 Head Unit with another one (from MR2) - old one didn't play CDs properly http://www.mchoi.com/go/carpix/ST185/fi ... n6009.html
HKS Turbo Timer Type 1 http://www.mchoi.com/go/carpix/ST185/fi ... n6186.html
Custom Hardwired RJ-11 Power Supply for Radar Detector http://www.mchoi.com/go/carpix/ST185/fi ... n6172.html
Reupholstered rear leather seats
Replaced interior carpeting viewtopic.php?t=20573
Shampooed Trunk Carpeting/Spare Tire Cover http://www.mchoi.com/go/carpix/2007_06_ ... CN7230.htm
Fixed cupholder, yay!
Other:
Optima 34/78 Redtop Battery w/Custom Billet Aluminum Tray http://www.mchoi.com/go/carpix/2007_05_ ... CN7086.htm
STAGE 1 Mods - 2007~2009 (Completed 11/08/2009)
Parts that I have on hand and waiting to be installed (planning to start this weekend, cos as you can see I have so much parts that I have that just need to go in!):
Body/Exterior:
Rallyarmor Mudflaps (prototype version) http://alltrac.net/phpBB2/viewtopic.php?f=24&t=21178
Engine/Drivetrain/Exhaust:
2.5" KO Racing Downpipe
2.5" Custom 409 Stainless Steel Mandrel Bent Midpipe http://alltrac.net/phpBB2/viewtopic.php?f=4&t=36782
2.5" HKS Cat Back Exhaust http://www.mchoi.com/go/carpix/2007_06_ ... CN7301.htm
Rear subframe polyurethane mounts (Mario)
Rear diff cushion (aluminum Mario)
ST205 Torsen LSD & Halfshaft
Speed Source Polyurethane Engine Mounts
Speed Source Front Crossmember Aluminum Bushings
Brakes/Suspension:
New Brake Rotors (Toyota OEM)
Goodridge Stainless Steel Brake Lines
Complete Whiteline "Works" Kit: Koni Sport (Yellow) Adjustable strut inserts, Whiteline Springs, Whiteline Adjustable Rear Sway Bar,
SuperPro Polyurethane Bushing Kit (entire kit)
TwosRUs heim joint sway bar endlinks (front & rear)
Camber Bolts (Toyota crash bolts)
New Front Tie Rod Ends
C-One Camber Plates, rotated to able to adjust caster
Full wheel alignment
Interior/Safety:
Momo Race Steering Wheel
New Rear Hatch Plastic Cover (Toyota OEM) - current one has crack
Replace HKS Turbo Timer Type 1 with new black one (the old silver one was broken) - located in glove box now
Fire extinguisher under driver's seat
CG-Lock seat belt locker
Other: n/a
STAGE 2 MODS (PLANNED FOR 2011+)
ST205 W2A Intercooler System [purchased]
Koso Boost Gauge [Installed 7/2010]
apex'i AVC-R Boost Controller [Installed 7/2010]
Eventually replace Clutch & Flywheel [Fidanza Aluminum Flywheel purchased] &
Speed Source Stainless Steel clutch line & extended clutch slave rod [purchased]
Replace or rebuild Brake Master Cylinder
Upgraded brakes - Wilwood, ST205, or AP Racing
Custom-made wheels with proper offset and 9" width for 265 tires
ACPT Carbon Fiber Driveshaft http://alltrac.net/phpBB2/viewtopic.php ... driveshaft
HID Headlights
Change interior dash lights to LEDs
Other "To Do" Items in the short-term:
Hubcentric Rings for my Volk wheels [Installed]
Replace driveshaft center bearings [purchased]
Fix the steering wheel tilt mechanism (I recently broke it somehow).
Replace door light triggers [Cleaned & Tested]
Recharge A/C System or convert
Swap out the Optima for a lightweight battery (Braille or Odessey)
Schroth ASM Harness
Remove "stars" pinstriping
Pull small dents (hood & RL wheel arch)
Wheel spacers
Electronics Mini-Project (AC power plug [Done], USB power plug, RJ-45 power plug [Done])
+ Ongoing maintenance items
AutoX fans and WRXs... I'm back!! :evil:
PAST:
(photo of first and only autox I've ran the car at)
BEFORE PROJECT:
AFTER PROJECT:
NYC, NY, USA
mike325ci
Postby ST165_Den » Thu Aug 30, 2007 12:50 am
Nice work man~ keep it going and keep us up to date
:D
I love ST165!!!
ST165_Den
Postby WarTowels » Thu Aug 30, 2007 4:58 am
Glad to have inspired you! Not sure I've ever inspired anyone before! 8)
What was wrong with your cup holder?
When I bought my car mine wouldn't click back in. I took it apart and I can't find any noticeable damage or broken plastic? Same issue?
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby Hotrodhendrix » Thu Aug 30, 2007 3:10 pm
Nice clean car man.
Postby mike325ci » Thu Aug 30, 2007 4:08 pm
WarTowels wrote:What was wrong with your cup holder?
yep, same issue and very very common issue. what's broken is this thing:
If you take out your 1/2 DIN cupholder and look at the back, it is there. I ordered a replacement (I can get you the part # this weekend when I go home) and swapped it out. Now my cupholder clicks back into place and flush with the radio face like it should be.
NYC, NY, USA
mike325ci
Postby vip09 » Thu Aug 30, 2007 4:36 pm
I really like that color. The car looks great.
And thanks for the cupholder fix!
vip09
Postby CMS-GT4 » Thu Aug 30, 2007 5:01 pm
RAWK! The wheel color really makes the color of the car look so much better.
Postby WarTowels » Thu Aug 30, 2007 8:47 pm
Nice. Part number would be sweet.
Cheers,
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby scandinavian link » Thu Aug 30, 2007 8:53 pm
sounds like you've got a nice collection of parts waiting to go in :)
sounds like it should be verrry enjoyable afterwards!
and +1 on the wheels :)
bryan -central ohio
2000 zzt231
1988 st165 (sold)
1990 st185 (brother's)
scandinavian link
Postby mike325ci » Sat Sep 01, 2007 10:57 pm
thanks, i'm looking forward to when i'm done with this thing, hopefully by november-- that's the goal, so i can have it ready by the annual MR2OC Bear Mountain Meet/Rally...
so, i'm right now in the middle of working on my car right now (came upstairs to dump the memory card to my computer cos i took too many pictures and it filled up the car)...
anyway, the SB1010 Speed Bleeders that I ordered DOES NOT fit in the front calipers. the screws are much smaller. SB1010 is much bigger. i'll take a measurement of the stock piece when i get back down there.
so poo, i can't install the speed bleeders this weekend. i got my springs/shocks on finally (what a pain in the butt, had to run out to buy a spring compressor cos what i didn't work too well), 1/2 way done rebuilding my calipers (just waiting for them to dry-- i painted them blue with some leftover caliper paint i had ;) ), and i have control arm bushings, front sway bushings, and speed source engine mounts to do, which i know is going to be a pain...
NYC, NY, USA
mike325ci
Postby RedCelicaTRD » Sat Sep 01, 2007 11:20 pm
WarTowels wrote:Nice. Part number would be sweet.
Cheers,
-Towels
If I'm reading my EPC right it should be 55631-32013
Postby mike325ci » Sun Sep 02, 2007 2:28 am
thanks for the part #... :)
so the correct bleeder screw size for the front calipers is M7 x 1.0 -- i measured it out with a measuring teeth thing and then inserted in my tap/die kit thing and that's what it is. so i can't replace the bleeder screw this weekend, will have to order SB7100 then. that's the same size as the one in my MR2.
oh, i have ton of photos collecting. i'll post them up all at once and link to them.
here's what things look like now. i also did "project 3-car garage" last night where i managed to fit 3 cars into my 2-car garage. the miata is stuck in the corner.
so as 9/1/2007 tonight:
1) Replaced strut inserts with Koni/Whiteline Yellows
2) Replaced springs with Whiteline Springs
3) Replaced strut top mouns with KYB Strut Top Mounts
4) Disassembled/cleaned both front brake calipers + painted Blue with VHT Caliper Paint
5) Removed front brake lines
Plan for tomorrow & Labor Day:
1) Finish rebuilding front calipers (w/Toyota Rebuild Kit)
2) Install Goodridge SS Brake Lines
3) Replace front Rotors w/Toyota ones
4) Replace Front Control Arm Bushings w/SuperPro Polyurethane
5) Replace front sway bar bushings w/SuperPro Polyurethane
6) Replace motor mounts with Speed Source Polyurethane
7) Install the finished strut/spring assembly
8) Install front camber bolts
9) Replace turbo timer with new HKS Type 1
And that should complete all the work on the front of the car... The rear of the car (will be about 2x the work since it'll be all of the above (spring/shocks/bushings/brake lines & calipers) PLUS rear subframe mounts and rear diff mount and LSD and sway bar install. I am not sure when I'll have a free weekend for that, so that is why I'm going one end of the car at a time, starting with the front...
So that's my progress so far. Thanks for reading!
NYC, NY, USA
mike325ci
Postby b00staholic » Sun Sep 02, 2007 4:40 am
You have a Miata too?!? It's not in your sig!!
Vincent
'90 ST185
b00staholic
Postby mike325ci » Tue Sep 04, 2007 2:26 am
haha, i only have *my* cars in my sig-- the miata is my sister's, and she keeps it over at our parent's house as well.
anyways, things never go as planned... hehe. i didn't get to finish all the front work this weekend. ran into some roadblocks.
1) the front motor mount is stubborn and won't pop out. i don't have a press. i'm wishing i had a press. i did what speed-source said in their instructions, using a hacksaw to cut through the inner thin metal sleeve, but with PB Blaster and hammering that thing, it won't pop out "easily" as they said. lol, it's never easy. i may have to take it to a shop to have them press it out. or buy a press already...
2) removing the front control arms was a lot more work than i thought. i thought i could do it without looking at the BGB, but i couldn't figure out how much to take out. so i finally refeered to the BGB and turns out I had to remove this metal piece that goes across the car and attaches both control arms to the body. it was filthy (covered in caked oil), and so were the control arms, so I spent about an hour washing/scrubbing them. that delayed me. also, looking at the control arm bushings, it looks like i can't just take them out via my jaw puller method. i might need a shop to press them out for me as well. or buy a press already...!
3) so i was all set to replace my front sway bar bushings, and then realized that the bushings i got were WAAAAY too small. 16mm. i measured my sway bar to be about 27-28mm in diameter. damn! i though i specified that my car was a 1992 with thicker sway bars... ugh, so i'm gonna have to return these and get a replacement set. lord knows if they are in stock or if i have to wait another gazillion years. bah.
and then it got dark, and i had to pack up for the day. and my back hurts. it was a tiring weekend. but i "took a break" on saturday and went to the Porsche Club autox in New Jersey and took first place in "stock non-porsche" class with my Exige. it was my second time autoxing it, and i think i'm getting a better sense of the car. marlon with the red ST185 came and watched us run all day. like i said to him, his Celica is the only other GT4 that i ever see around this area. the rest of them are in hiding. or maybe up on jackstands like everyone else in the club, lol. ...and that now includes my car... i need to finish all this up quick so it is not jackstand-bound more than it should be... ;)
NYC, NY, USA
mike325ci
Postby smog7 » Fri Sep 07, 2007 6:11 pm
found a car that looks like yours! except with te37's
http://www.pistonheads.com/sales/229884.htm
-omar
rally tarmac 1990 st185
smog7
