2/13~14/2010 Update
Heater core is a nightmare... I am not sure how much more I have to remove to be able to remove the heater core box, but I guess I didn't do enough... Looks like the metal cross bar has to come out... Plus I couldn't get the inlet heater hose disconnected at the firewall. The outlet hose was a 45 minute cursing job as well (had to remove a bunch of stuff out of the way to make room for me to get to the hose clamp and pull it out). I was so discouraged that I decided to take care of other things; so overall this weekend I did:
1) A little bit more heater core work: Got A/C unit out and not much else, really
How much more do I have to take out to get this sucker out??!@#!% :x
:shoots:
:bangshead:
COOLANT LINES IN FIREWALL. Only managed to remove the outlet one...
2) Drained coolant from radiator. Not much came out; maybe a gallon? The rest puked itself into the car cabin, I suppose. It was also nasty dark red and thick. I don't know why I didn't do a full coolant flush when I got the car-- but I definitely will be doing it now!!!!
3) Installed ARC BOV: Tried using my high-quality HoseTechniques clamps, but they were too thick, so went back to traditional worm clamps. The outlet of the BOV hits the radiator hose, but hopefully that's fine.
RADIATOR UPPER HOSE & BOV OUTLET:
4) Installed my C-One Camber Plates. I shall call them caster plates, because that's what I'm using them for.
I set them back as far back as I could. Oddly, the left side didn't go back as far as the right (max back), since the top of the spring metal thing was hitting the inside of the car body. I think the metal tab on the bottom of the spring top is rotated towards the back of the car on that side whereas the other side is rotated away from it.
Notes:
A) I had to move the adjusting screw inwards 2 notches to be able to clear.
B) I can't use the Koni adjustment knob, since the nut on the C-One plates are high and cover the sides. I'll have to hack up the knob or find another way to do quick adjustments of my shocks.
C) With the settings the way I have it, the car has A LOT of toe in. It is visibly obvious. I need a realignment, plus I need to find out what my front camber settings are too.
Remember to use the spacer ring that was included with the kit. This gives the plates enough "wiggle" room to rotate. Without it (tried it first like that), it doesn't freely move:
ASSEMBLED:
RIGHT SIDE:
LEFT SIDE:
LEFT SIDE hitting the body:
ENGINE BAY (BOTH SIDES):
5) Installed front crash bolts. Found the right part # for our car (Part #90105-17005), so I'm happy it worked. I got the 3-dot one (most adjustment). [Again, for the rears, SW20 MR2 ones (Part #90105-15006) worked-- the fronts are much thicker in our cars.]
6) Rebled the front brakes since I had to remove them in order to take out the coilover housings (why Toyota didn't have a tab that is split so you can just bend it, I dunno...)
7) Installed front license plate frame holder
8.) Tightened power steering belt. 14mm short socket + pry bar was the key.
My CF card died on me again, but I was able to recover some of the images using this utility program that I bought (Zero Assumption Recovery). Seems to happen all too often, so I'm going to see if I can get it replaced under warranty from Kingston. It's about 8-9 years old, lol...
--> All photos from the weekend are here: http://picasaweb.google.com/mikechoi210 ... PlatesBOV#
