A small update on the car. I have been collecting the parts necessary to get it running again. Unfortunately another speed bump in this train wreck that is my project is that it was broken into the other night resulting in a broken window, a door that doesn't open, a missing stereo amp, a wrecked stereo dash unit and a turbo timer hanging halfway out. I have an extremely large distaste for thieves and I would pay the money to go home and whoop some ass if I knew who did it.
On the bright side is that I found a reliable guy to swap the head out with my new one. And here is an updated mod list.
Motor:
Rebuilt 3sgte bottom end and newly rebuild head.
- KO Racing SB .50
- TTE Head gasket and ARP Head Studs
- HKS Valve Springs
- Blitz 264 Cams
- AEM Cam Gears
- 2 1/2 inch exhaust
- EGR block off
- MSD Ignition coil
- ATS Bored out stock Fuel rail and FPR upgrade
- 550cc injectors
- Bay Area FMIC with what I think is an apexi BOV (can't remember)
- Fidanza Light Weight Flywheel
- ACT 6 Puck unsprung Clutch
- AEM ECU
- Turbo Timer
- ATS Throttle body adapter
Suspension and others:
- Unknown brand lowering springs
- Koni adjustable shocks
- 15mm spacers front
- 25mm spacers rear
- 18 inch Rota Sub Zero Wheels on Nitto 555s
- Steel braided brake lines
- Cusco Front Strut bar
Future Mods:
- TWM short shifter
- Wilwood big brake kit
- Cusco under body brace
- Cusco rear strut bar
- Some Momo interior look goods
- New Tires
- Upgraded intake manifold
- Clock down turbo
- Ceramic coat exhaust manifold and hot side housing
There my be more that I am forgetting right now but, I'll update it if i remember what is missing.
