Well, here is some more work I have done on the intercooler setup.
Here is a picture of the bottom brace for the heat exchanger on the passenger side, thought I might as well drill a hole through it and secure the hose with a loom hanger, the 3/4" 90 degree hose was from Napa.
I put in a bracket half way down the hose to put another loom hanger in.
This picture shows where I attached the lower support of the bottom of the heat exchanger to on the drivers side. I don't know why Toyota put in a slotted hole off to the bottom condensor but I appreciate it, the brace I made has two 90 degree bends and turned out good. I was going to put an S shaped 3/4" molded hose from Napa to run the return hose under the car with the supply, then I saw the light of where I should run the return. The hole in the side support works well, I put some split loom around the metal edges incase the hose rubs on it, but then I made this hanger bracket to firmly keep the return in place, the assembly barely clears the AC connection, but it does clear.
Here is another shot of the lower drivers bracket I fabbed up, this one I also drilled a hole in to put in a hanger, also another hanger shown to secure the hose right before it enters the pump.
Ok this is how I mounted the Mustang Termi intercooler pump. I used an old air conditioner dryer mount off a Toyota pickup to secure it, fits kinda tight, needs a very little amount of loom hanger rubber in the bands and it should be a very tight hold. I had to cut a little off one end and do a little bending, but it enabled me to make a starting point for the mounting brackets to bolt to.
Supply and return hoses meet up here and are secured with some more hangers, need a few zipties in there to keep em all together in a few spots. I tested out the air filter and AFM and it all should work, I'm going to make some brackets to keep the filter off these hoses, but I need some viberation mounts first to ensure the AFM doesn't shake to death due to the stiff motor mounts.
This is all for now until I get further down the road,bad thing is it's getting busy again at the shop.
