Project:Left Hand of God
Postby stevo27 » Wed Dec 26, 2007 2:28 am
well boys im building a MONSTER of a st-165
almost done and believe it or not this is my daily driver :P ( not anymore haha)
here we go
ENGINE:
2nd gen 3sgte
complete port job (done by me)
ferrea comp plus 1mm oversized valves
shimless bucket conversion
hks 272 exhaust/ intake cams
ferrea dual valve springs with titanium retainers
ats adjustable cam gears
86.5mm weisco pistons (o.o2o over)
pauter rods
acl main and rod bearings
tte metal head gasket
ats l-19 head studs
high volume oil pump
Gt3588r garett turbo (42r now)
Tail 40mm external wastegate( twin 40mm)
custom tubular exhaust manifold 304 sch 40 stainless steal (built by me)(diffrent now)
aeroquip oil/ coolant lines
rmr 75mm mustang tb centerfeed intake manifol
bbk 75mm throttle body
34x16x4 front mount intercooler (now bigger)
2.5/3" charge pipes
hks ssqv blow off valve (twin)
aluminum radiator
dual 12" electric fans ()
FUEL SYSTEM:
1600cc top feed fuel injectors with 880cc backups
speedsource top feed fuel rail
aeromotive adjustable fuel pressure regulator
aermotive a1000 inline fuel pump (controlled by switch in cockpit)
aluminum fuel cell
1/2" id stainless braided fuel lines
high flow fuel filters
100-180 shot of love juice
ELECTRONICS:
autotronic sm4
hks evc5 boostcontroller
autometer 35psi/ 30hg boost gauge
autometer 2000 F pyrometer
autometer fuel pressure gauge
autometer oil pressure gauge
autometer oil temp gauge
autometer water temp gauge
aem eugo wideband gauge
10,000rpm monster tach
160mph speedo
DRIVETRAIN:
rps billet carbon twin disk
RC transmission
ats cromoly axle cages on all 4 corners
aluminum drive shafts
aluminum driveshaft hoops
soilid rear diff mount
speedsource soild motor mounts
willwood big brake kit
stainless brak lines
extended clutch slave
soild crossmenber bushings
solid shifter bushings
motegi tacklites 16x8 14lbs each
DIY short shifter
tein HA coilovers
full cage 12 point (having it certified by nhra)
INTERIOUR:
corbeu lightweight fixed back seats 12lbs each
corbeu 3" 5 point cam lock harness'
FULLY gutted (minus stereo hehe ;))
mr10 lexan hatch and rear quarter windows
aluminum hatch floor
umm thats pretty much everything im sure i forgot a bunch of stuff
but here's some progress pics enjoy
theres ALOT more pictures i just have to upload them
as in my sig im going for the fastest alltrac record
and the fastest 4cyl in alberta wich i have to beat 10.586@121mph
personaly im going for 9 secounds
i expect to be in the 700awhp area with the spray at 9000 ish rpm
at the moment my trac weighs 2700lbs ive removed 200ish more lbs
then adding the cage so i expet to be 2900lbs race weight (with me in it)
running on 8" wide slicks
lemme know what you guys think
i expect to be done at the end of febish hopefully if maching and parts come in as planed 8) :shoots:
No longer a member of the AWD club
just a powerglide and rwd for me
"breaking records and breaking parts go hand in hand"
stevo27
Postby 88st165 » Wed Dec 26, 2007 2:57 am
ummm wow :shock:
looks like you put alot of work into it.... i predict that you get some good results.... i might have to start looking at your 165 for some inspiration! keep up the good work 8)
get some more pics of the whole car...
Black st165 - gone
2011 FA5 - Family Truckster
88st165
Images: 2
Postby stevo27 » Wed Dec 26, 2007 3:27 am
it's easy man if a kid that just turned 18 can do it anyone can haha
but on a serious note yea if you have any questions i can help with no probs
good results im realy hoping for haha i wanna hold some records
i wanna steal pats fastest alltrac in north america
and its gonna be a battle with ron and his dsm he's going for 850+awhp
but refuses to run slicks so i should destroy him he has a best of 10.6@141mph
well see what happens but i actully have to finish my car first
i would go with a bigger turbo but i want decent spool since im gonna be doing some road racing also :D
more pics tomorow
stevo27
Postby lumbercis » Wed Dec 26, 2007 3:41 am
I'm no expert, and have never built a car like this, so take my opinion with a grain of salt...but...
I think you don't have near enough clutch for what you are trying to do. I'd look at some of the better twin-disk clutches. Jeff Fazio and his "Hyde" racecar was running less power than you will be, through a RWD platform, in a lighter car, and he was primarily a road racer, and he eventually had to go to a Tilton Twin-disk. Some of the high-horsepower supra guys use RPS carbon-carbon. HKS also makes a twin disk for the 3sgte.
I wouldn't put a BBK on a drag car. It is really just extra weight for that application. Alot of Drag Supras actually downgrade their beefy turbo brakes to stock NA brakes for this reason. Good pads, rotors, lines and fluid is all you really need. If you are going so fast that you can't stop within the allotted space, you need a parachute, not a BBK. :evil:
Coilovers aren't really necessary either. In general you want alot of "squat" in a drag car to help weight transfer and traction. So you don't generally run super-stiff suspension. Darin from Titan Motorsports (TitanDarin on supraforums) was running low 9's/high 8s on STOCK suspension. OTOH, coilovers probably won't hurt you, they just aren't totally necessary for the application. Might want to pop on over to DSMtuners and see what the AWD guys in the 10's are running for suspension.
Unless you just want it for looks, you really only need one race seat. You can remove the passenger seat entirely when you go to the track. Passengers generally won't find race seats very nice to sit in.
If you are going to be running slicks, I'd ditch the Motegis (not great wheels anyway) and get some proper drag wheels such as Weld or Bogarts. MUCH lighter. But you can't use them on the street. I'd also probably drop down to 15" size. If you want to save money here, I saw a thread on the DSM forums where some guys were using Rota Slipstreams in 15". $500 for a set of four and weigh about 11lbs ea.
Lastly, this is really a personal thing, but I would get different gauges. I had an autometer fail on me. ProSports look good and aren't as pricy as the high end Defi/Greddy stuff. Although it really isn't a big deal for a track slut.
Well, I'm looking forward to seeing you break that record! Good luck!
J.
Caldina powered...
lumbercis
Postby stevo27 » Wed Dec 26, 2007 4:02 am
well i forgot to mention this is also a daily driver hahaha i know it's not the best but its my passion but being 18 and a welding apprentice i cant afford 2 vehicals especially dumping nearly 40k into my trac hahaha and the 95% of these parts are already bought including the gauges
and i cant afford higher end gauges as of right now
and previously stated i will also be in a time attack comp i like road racing
so i need the big brakes id and thats why i went with the 35r instead of a 40 or 42r for road racing i need the somewhat quick spool and the stiff suspiension im going to be buying some softer coils for the rear aswell
and for the clutch i didnt plan on making so much power so soon haha
so ive alreay bought the clutch im going to run it seen if she blows
i will be upgrading to an exady triple disk carbon on carbon clutch eventully or i might sell the act and buy it right away but money's tight ill see
and for the track i will have the passenger seat removed :D
and for the slicks im buying a set of centerline 15x8 =)
and im trying to get my pro license and get into some real racing maybe get some sponsers (fingers crossed)
i hope my gauges dont fail
and yea it's not the most practical daily driver
and thanks for the support
stevo27
Postby lumbercis » Wed Dec 26, 2007 4:39 am
Sorry, I didn't see your post about using it for road course work. Well, dual-use setups are a little harder to manage because you have to make some compromises and spend more money.
I'm not sure how money can be an issue when you are blowing 40k? :shrug: If money is an issue, should you, well, not be spending 40k on your car?
Anyway, even though the clutch is brand new, I'd take a loss and sell the clutch and put in an RPS twin disk. The ACT WILL fail at those power levels.
If you are going to be building it for road course work, you need to decide what class you will be running in and make sure your car meets the class requirements. There can be alot of little things that can trip you up. For instance, alot of classes don't allow lexan. Also, road course racing can be expensive even at the hobbyist level. You will go through tires/brake pads and rotors/fuel at an astounding rate. Not to mention track fees. Have you budgeted for this?
J.
Caldina powered...
lumbercis
Postby Red Rabbit » Wed Dec 26, 2007 2:48 pm
All i can say is WOW! I wish i had 40k to dump into a car when i was 18, but sadly im 20 now and am broke lol. But anywho's are you going to follow Klas' example with his st165 and get some fiberglass fender's and hatch?
1984 Mustang Beater- Blew up
1988 ST165- Project
1992 ST184- Totalled
1993 S13 Turbo- Sold
1995 Impreza Outback Sport- Other daily
1997 S14 Kouki- Might sell might project
1991 Turbo MR2- New daily
Red Rabbit
Postby Trumanpriest » Wed Dec 26, 2007 4:51 pm
Wow, that looks fantastic. You may have already had it translated or don't care but in Latin Left hand of god is "Sinistra Dei." Good name for a car. :) because in Latin left handed can almost mean something evil hence sinister....However it can also mean unlucky, or having to do with sexuality..... Yes I'm a dork. Sorry. Great project though!
Trumanpriest - 1990 ST185 | 2010 Tacoma 2.7 SR5 | 2009 Yaris
Trumanpriest
Postby stevo27 » Wed Dec 26, 2007 4:54 pm
40 k is around what i will have spent when im finished prob a bit more
but that's not having a life at all so i can build(afford) the car :D
working 120hours every 2 weeks doesnt hurt either
but anywho i bought myself some late christmass presents
RCI aluminum fuel cell
aeromotive a1000 fuel pump
secondary holly fuel pump for the nitrous
aluminum battery box
10,000rpm monster tach with shift light
external killswitch
waiting for my 1600cc injectors to come in
waiting for my internals to come in so i can send out my block for machineing head to be cleaned so i can port it
waiting for my rmr intake to come in
waiting for my 75mm bbk throttle body to come in
im pretty sure i will eventully go all fiberglass
but not till i can afford it :P
stevo27
Postby stevo27 » Wed Dec 26, 2007 4:56 pm
Trumanpriest wrote:Wow, that looks fantastic. You may have already had it translated or don't care but in Latin Left hand of god is "Sinestra Dei." Good name for a car. :) because in Latin left handed can almost mean something evil hence sinister....However it can also mean unlucky.... Yes I'm a dork. Sorry. Great project though!
awsome thanks dude thats the cars name as of now hahaha 8)
stevo27
Postby Red Rabbit » Wed Dec 26, 2007 5:15 pm
I wonder who will have the fastest 165 when this is all said and done between you and Klas. :roll: Definately this will be a car worthy of being on the cover of a mag.
1988 ST165- Project
Red Rabbit
Postby stevo27 » Wed Dec 26, 2007 5:39 pm
im hoping to be "THE" fastest alltrac 8)
i dunno if klas is going for a sub 10 second pass
but i dont think my trac will see a mag right away there is some cancer
i have to remove well i need new fenders and rear quarters :oops:
stevo27
Postby Red Rabbit » Wed Dec 26, 2007 6:43 pm
So your goin for pat's record. Please video tape and popst when you make your run it will def. be worth saving. :D
1988 ST165- Project
Red Rabbit
Postby magnum » Wed Dec 26, 2007 6:48 pm
Why didn't you clock your turbo compressor so you would have a shorter hot pipe for you IC?
magnum
Postby stevo27 » Wed Dec 26, 2007 6:51 pm
oh there will be LOTS of video 8)
oh and yea when i buildt my exhaust manifold i moved the postion of the turbo 1/2" to far to the drivers side and when i clock the compresser down it hits the clutch slave :P my bad hahaha
stevo27
Users browsing this forum: No registered users and 7 guests
