1026 GT-Four Normal Body
Postby Corey » Tue Jan 08, 2008 5:18 pm
Update: Went with MHG afterall - TTE 1.2mm with milled Cylinder head.
Update 2: Seems all the car's fuel/hesitation issues were due to a faulty AFM
Well, seeing as all my parts are just about here, I figured it would be a good time to finally start a project thread for my car. :wink:
Bit of history: :?
Car was imported by J-spec Imports of Austrailia in Feb 2007 with 40150km. I purchased the car while it was enroute for $6900 canadian.
Final total for car including intresest on loan was $8000.
Here are some of the pictures while it was waiting for an owner in Japan.
And here's a shot of the engine bay after a bit of scrubbing.
Much better :oops:
After putting a good 25k km on the car in the past year - and having paid off my loan - I decided it was time to get another loan, and buy some tune up and performace parts for my car.
The 1st modification I bought for the car was the Speedsource Brass cable bushings. Then came a C's Short Shift from Japan, and a Redline Goods Leather shift boot from Poland to go with it. 8) No more chicken leg :)
After that, i was set on improving the stance of the car, and wanted to buy it some new wheels. When Teamfaint put his OZ's up for sale, i had to get them. All i have to say is wow, I had to idea the wheels would sit out so wide. :D
Here is a list of the modifications that will be installed within the next week or so. EDIT: ....... HAHAHAHA :lol: :cry:
Driveline:
ORC Ogura 409 Silent
ST205 E154F Tranny 1998
ST205 E154F Starter
New Axel and Prop Shaft Seals for Tranny
New Slave Cylinder
Speed Source Extended Slave Pushrod
Speed Source SS Clutch Line
Motul 5.1 Brake Fluid for Clutch
RP 75W90 Tranny Oil
Engine:
New Cam shaft seals
New Rear Main seal
New Front Crank Seal
All 3 hoses from hell
New Timing Belt, Tensioner, Tensioner Pully, Idler Pulley, Powersteering and Alt Belts
New Thermostat and Gasket
New valve cover gasket from K-Box
TwosRus Valve cover Bolts
Painted Valve Cover - Black
New Distributor Cap, Rotor, Denso Leads, and NGK Plugs
New Fuel Filter
Black Silicone Vacume Hoses from Boost Controller.com
KO 2.5" Downpipe
New Exhaust Manifold to Head Gasket, New Manifold to Turbo Gasket, and New Turbo to DP Gasket.
RP 5W30 Motor Oil
Cooling:
Ron Davis Aluminum Radiator
Samco Coolant Hose Kit
Toyota Red Coolant
New OEM Exhaust Manifold, Ceramic Coated by Swain Tech
And when i have more cash, a Bay Area TMIC
Electronics:
When i have more cash, an HKS EVC 5 set to 10-11 PSI
Body & Weight Reduction:
RC Aluminum Front Bumper Bar. -30 lbs EDIT: Only weighs 25 lbs with Foggies. So Approx 20lbs reduction.
KO Downpipe. -10-15 lbs
ORC Clutch. - 7 lbs
Aluminum Rad - ?
ST205 Small Starter - ?
Removed front license plate holder, so now I'll take bumper to the shop to get the holes filled and repainted.
So estimated weight will be around 3205 lbs from 3262.
And that should pretty much cover it for a while :D
Eventually I will get some DMS 40mm Suspension and a 2.5 Exhaust from Rocket Rally. But maybe in a couple of years. Since they are a DMS dealer, while they install my exhaust and suspension, they can put the car on their dyno :)
I'll start posting up pics of all the work once my friend and i get started :)
thanks for looking
Corey
Corey
Images: 50
Postby st185rc » Tue Jan 08, 2008 5:51 pm
Hey Corey,
that's an incredibly neat and tidy car. Are you ever stopping by the main land? We should have a meet of some sort
st185rc
Postby Corey » Tue Jan 08, 2008 5:54 pm
Thanks :oops:
Absolutely i'd love to make a trip over. I actually wouldnt mind driving up to rocketrally early for a dyno run just to see where its at right now, or after all these parts go in and i get too caried away lol.
Corey
Images: 50
Postby CMS-GT4 » Tue Jan 08, 2008 6:18 pm
Your seats are in pretty decent shape. I would like to see your car on scales to see what it really weights.
Postby Corey » Tue Jan 08, 2008 6:38 pm
I had it on scales a couple months ago.
1480 kg, with about 20 lbs of fuel.
thats 3262 lbs
Front wheels : 910kg
rear wheels: 570 kg
And with about 25.86 kg off the front. it will be 884.14 kg and have a 60/40 weight distribution.
Corey
Images: 50
Postby gt4tified » Tue Jan 08, 2008 6:42 pm
no mhg???
gt4tified
Images: 5
Postby Corey » Tue Jan 08, 2008 6:51 pm
I've been considering it. How difficult is it to do? just need basic tools?
EDIT:
found this http://www.alltrac.net/phpBB2/viewtopic ... ad+removal
I guess at that point i might as well get the ARP head studs?
Corey
Images: 50
Postby CMS-GT4 » Tue Jan 08, 2008 7:15 pm
Corey Darling wrote:I had it on scales a couple months ago.
thats 3262 lbs
rear wheels: 570 kg
Interesting. My widebody weighed 3,280 w/ RC hood and bumper, teins, swaybar, a cat back and some heavy aftermarket wheels.
I expected the narrow body to be much lighter. I guess the standard narrow body had all the trim unlike the Rally model that came stripped.
Postby Corey » Tue Jan 08, 2008 7:18 pm
Yeah, mine is fairly loaded. only stuff it doesnt have is Cruise Control, EGR or airbags
Corey
Images: 50
Postby WarTowels » Tue Jan 08, 2008 7:25 pm
Oh noes! You made a poll!
Even after it's over, it never goes away from the topic heading... :doh:
Mines been over for months, and it never goes away... lameness.
Oh well.
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby CMS-GT4 » Tue Jan 08, 2008 7:25 pm
Hrm. Mine did have airbags and cruise, plus cruise. No ABS though. I home mine is much lighter next time I weigh it. That RC crash bar does save a lot of weight.
Postby Corey » Tue Jan 08, 2008 7:27 pm
Thats good to hear :) would hate to spend 200 bucks for nothing lol.
I would LOVE to get rid of my ABS. i hate it. along with a lighter odyessy battery.
But being RHD, finding the non ABS stuff to replace it is kindof tough from what i gather.
Corey
Images: 50
Postby Corey » Tue Jan 08, 2008 7:33 pm
Oh well.
-Towels
LMAO, oh poo. i was hoping i could get rid of it at some point :(
Corey
Images: 50
Postby Fourplay » Tue Jan 08, 2008 10:28 pm
Corey Darling wrote:I would LOVE to get rid of my ABS. i hate it.
If it makes you feel any better, despite not being the best ABS system in existance, mine has saved me twice in traffic from definite disaster.
Oh, and don't bother with a MHG for the power/boost level you are curently at/planning if your engine/current HG are in good conditon. Intercooler upgrade next priority :wink:
91 ST185 JDM Pre Facelift Widebody
Fourplay
Postby Corey » Tue Jan 08, 2008 10:44 pm
Well, im guess its okay in the dry. But in the snow/ice :shoots:
I think the only time its activated on my car was when some lady pulled out into an intersection in a minivan, cutting off 2 lanes of traffic.
I guess for the trouble of removing it, ill live with it. Just remove the fuse when it snows.
I beleive/hope my HG is okay. only has 65k km on it. but the security of a MHG would be nice. Just lots of work and money :(
I think i'll leave the headgasket till it really needs to be done.
Corey
Images: 50
