Tubasteve - **update** 10-3-2015 -new pictures
Re: 6/15/2012 - some goodies in
Postby tubasteve » Tue Jun 26, 2012 12:41 am
CMS-GT4 wrote:Ah, interesting they changed that. I plan on doing the opposite if I ever do any major overhauling to my suspension. I would like to raise the height of the strut top mount myself. Then again, if I was to go through that much trouble, I think I would just get a whole new suspension on my car.
thinking i should have gone somewhere else. my black cars Megans are happy, am actually happy with where it sits and adjustments. these tend to feel soft compared to the megans.
anyways setting up my car these next few months, so it might be a while.
-jr
tubasteve
Re: 6/15/2013 < almost a year ago today!
Postby tubasteve » Fri Jun 14, 2013 5:40 am
Car running with smog engine installed...going to be a good summer.
-Steve
tubasteve
Postby CMS-GT4 » Fri Jun 14, 2013 9:08 pm
Glad you still have it. I thought you might had gotten rid of it.
Postby tubasteve » Fri Jun 14, 2013 9:14 pm
Black one I did
tubasteve
Postby Tecker185 » Fri Jun 14, 2013 11:06 pm
You get it running on the ems-4? If you did mind sharing the calibration file? Also what are you useing for an iac?
89 ST165
89 SV25
86 AW11 2zzge swapped
86 AE86 1uz swap
89 AE95 sedan
89 AW11 Supercharged
17 4runner TRD Off Road
Tecker185
Postby tubasteve » Mon Oct 28, 2013 6:51 am
Smog readyagain
tubasteve
Postby tubasteve » Sun Mar 29, 2015 6:31 am
Humphrey dimly dump
tubasteve
Postby UtahSleeper » Sun Mar 29, 2015 8:41 pm
What a stellar update :rofl:
UtahSleeper
Postby tubasteve » Tue Mar 31, 2015 1:46 am
Sorry, I was pulling it to the top, been so long forgot it was in my tag.
tubasteve
Re: Project tubasteve - so many parts so little time
Postby tubasteve » Wed Apr 01, 2015 3:39 pm
okay, so I took a couple of years off and trying to get back on here to finish what ive been developing.
Update:
1) got a new job last year
2) car still runs tip top
3) engine/trans and brakes are setup for street use currently for smog in may
Plans over the next couple of months include
Brakes being ccompleted to be able to stop when being heavily used(currently on going testing for both 5x100/5x114)
Engine being refinished on the new block and completely re-doing another head with valve system gone through again.
Cams....this will be interesting
Put up the write up for aem ems+4 (also working on my own stand alone 32 bit ems). Will be running coil on plug. For the 3sgte only really with only tdc and cylinder ident.
Trans....eh nothing preitty
Turbo choice will depend on cam choice.
Complete the edfc conversion on suspension.
Install the new lsd
install all the bushings ive already had for 2 years.
Finish gauge mounting.
Install an actual functioning radio instead of dead space for gauges.
Im currently having to go through my stock of parts and invintory of new and used. Its taking some time coding and inputing the info into my data base. Im a horder of what I have, I take failed parts and find out why or how they failed to ensure it can be lessen issues in the future. I currently also have a back ground in the goto shop in so-cal for alltracs and took a step back this time last year in going another direction with the car again as well as just getting a b etter understanding what I wanted to do. If you are still reading to this point then youll know things will start getting posted on here for refference.
tubasteve
Postby tubasteve » Wed Apr 01, 2015 4:10 pm
tubasteve
Postby tubasteve » Sun Oct 04, 2015 2:29 am
Current engine shot (been cleaned since april though.
tubasteve
Postby tubasteve » Sun Oct 04, 2015 2:30 am
Old interior
tubasteve
Postby tubasteve » Sun Oct 04, 2015 2:37 am
Had system 10 stock, removed it due to messed up door panels and lacl of speakers to put in place due to the stock ones being wrecked. Here is before: the after is 75% done as i have to fix the speaker cover, get a new grill and fix the arm part better. Black insert is suade.
Speaker clears door, door also has been sound dead mat on the inside.
Speaker was $30 and quality feels better than i thought
tubasteve
Postby tubasteve » Sun Oct 04, 2015 2:43 am
Installed edfc system
tubasteve
