Tubasteve - **update** 10-3-2015 -new pictures
Postby Kcman91gts » Thu Jul 23, 2009 4:12 am
I also have a caldina ecu input / wiring diagram if you need it , actually i believe i may have 2 . but very impressive build , im glad to see another person actually giving this particular engine/generation a chance.
Kcman91gts
Postby tubasteve » Fri Aug 28, 2009 4:58 am
So while my caldina is on her holding skids, got the celica fixed up with some new parts. new p/s rack with new tie rod ends, took me forever cause it looks as if it was the factory one, so bolts were "welded" on there. put in new injectors, modified my fuel rail to the "8mm" side feed, 205 pressure reg. and all that stuff. when i had it dynoed it went lean for the first 1.5k rpm, it also felt as if i had vtec when boosting...was the injectors, was going to have them flow tested cause they say 6XXcc on the top....but i dont think thats the flow, or they are way dirty. car seems so much better. smooth and no lag feel.
on the caldina motor, still waiting on the harness and ecu. dont really have the means of putting it in right this min. so im buyen stuff for the stockie for now which is working out so far. wanting to do mls head gasket here next month...haha that's in four days. my new "big"...ger turbo will be here tomorrow after noon sometime. very happy with this guy knew his stuff very well, i will post more once i get it and install it. factory rebuild on ct26/20b is $275...upgrade to ct27 and bigger is $475 free clipping if you ask. and this is on exchange ONLY. cores i dont now
tubasteve
Postby tubasteve » Fri Oct 02, 2009 7:24 pm
UPDATE ON MY LITTLE CAR. GOT A CALL TUESDAY SAYING THE MOTOR SUP. CREITED BACK MY CARD AND I WAS TO KEEP THE MOTOR! SO NOW IM ORDERING PARTS TO COMPLETE THIS. MORE INFO THIS WEEKEND WHEN IM OFF
tubasteve
Postby celicast184 » Fri Oct 23, 2009 8:58 am
so you got the caldina motor for free??
I <3 MY ST214
celicast184
Postby tubasteve » Sat Oct 24, 2009 4:03 am
yes. and not so yes. in the fact that i took hours of on the phone crap.....it was not the motor i orderd......and the place would not take it back...
tubasteve
Postby tubasteve » Wed Oct 28, 2009 4:50 am
along came a clutch, and then...
i pulled my motor to do a basic clutch, bought the rear main seal thinking it would be a good idea....from 800 ish to well i thnk im upto 2000 before the engine build now.
clutch and fly was $744
rear main seal and plate gasket $30
all factory timing stuff, tbelt water pump seals ect. $197
head gasket $250 with arp studs
completed bottom end build........NO idea as the guy just got it today. he is the local builder for trd -baja. i honestly dont mind spending the money, but this all started with a clutch
long story short, did the timing belt back in july and NOTHING under the timing covers were leaking...every seal, water pump and bearing is BAD. lol i always tell my customers that this happens. it all started with i got a wild hair and wanted to look and see how everything looked under there cause the cover was wet. turned out the two cam seals i didnt touch or have issues were coming out. then i thought time to install the cames, shoot having those off might as well pull the head for the mls head gasket. called my machine guy..."why not do the pistons and rods ect" all i see is nothing in my hand....money and car. and here i was to be getting a house. :cry:
well the st215 motor will not be used.
tubasteve
Postby celicast184 » Wed Oct 28, 2009 7:00 am
what???? st215 motor not going to be used?? i was looking forward to this project man..
I <3 MY ST214
celicast184
Postby tubasteve » Wed Oct 28, 2009 3:48 pm
this post was not me...
edited for someone using my computer(i dont own a white car)
tubasteve
Postby tubasteve » Fri Nov 06, 2009 2:12 am
until i can get a car going im a little stuck. my very rare of a swap accord was totaled last night with a 50' rv. guy comes into my lane as im locked up and just takes her out. after the 10k in motor and work IVE done, im very upset. my girl was more upset when she found out. called the builder and told him two cars in peices and one....well totaled. orderd pistons today he said so hopfuly i can start again monday as the huge bills stock up.
tubasteve
Re: TubaSteve's - FROM CLUTCH TO ENGINE BUILD
Postby tubasteve » Thu Mar 11, 2010 3:42 am
DID not realize i hadnt posted on here after i finished the minor build.
running 9.0:1 mahle pistons
262 cams
i think its a 96 camry pump.
exedy stage 2, 3 puk clutch with fi. fly wheel.
i will give a full run down with pictures tomorrow, currently waiting on the 50trim turbo and some parts
tubasteve
Re: TubaSteve
Postby tubasteve » Tue Mar 16, 2010 5:16 am
#deleted pix links as they are no longer good...#
this is some pictures from my engine rebuild project. bent the down pipe when off roading.(using the car)
this shows the center feed issue when i pulled the turbo off. cyl 2&3 showing lean...
getting tired of people wanting to street race, and dont want to hack up the dash(near perfect) and having issues turning the wheel with the gauge pod in the way.
the front mout was great looking and worked well, but where i drive it took too long to cool at times, and is huge and bolted up with minor mods
ill post the pictures from my blue berry in a min.
tubasteve
Re: TubaSteve
Postby tubasteve » Tue Mar 16, 2010 5:53 am
tons of photos...i will resize later
the trip
the guarges i changed spots(still finishing)
right before my clutch let go.
stopped to see what was the matter with the exhaust
pulled the einge in 2 hours 5mins 36 sec.s
the reason she came apart
all side by side
old vs new
g]
then came the oil pump
then my machine guy came by and said "you have your head off...." 550 later for the mahle pistons
new head gasket
the all famus everyone takes this shot
and this one
six attempts later
tell me what else?
tubasteve
Re: TubaSteve - pictures update, and smaller in size
Postby tubasteve » Sat Feb 25, 2012 2:28 am
bumping back to top, as ive started again, this time the right way. thanks, sorry for the false boner that i did do this
tubasteve
Re: TubaSteve - ....."its coming"......
Postby tubasteve » Mon Feb 27, 2012 4:19 am
Here is my first picture post of old stuff after finding photo bucket
Test...more to come.
-jr
tubasteve
Postby tubasteve » Mon Feb 27, 2012 4:37 am
How my car currently sits while i an at work
The stuff piled inside while i was moving (everything was put in with care)
Bumper is fine.
After going through car project threads here i decided it was time i start up again.....my car has been non-OP for under a year, and i have never been happy with the status my car was in when i finished. granted, it ran strong, looked like do do....here is the start of My project again....this time cleaning is where i will start....
After 2 hours of scrubbing....i came to realize something. The paint here was shot.
tubasteve
