Tubasteve - **update** 10-3-2015 -new pictures
Re: TubaSteve - 2-26-2012
Postby tubasteve » Mon Feb 27, 2012 6:35 am
The reason my engine is out.....again. My black one had a bad knocking when i bought it, so....i put the engine in the black car for short term.....been almost a year....in Cali if you didnt know...non op a car, to reop you need smog. So I'm making a smog lgl engine for both.
Anyways
tubasteve
Postby 88gt4DE » Mon Feb 27, 2012 11:26 am
Keep us posted , wish I had the funds to rock two ... Maybe someday I can build another one :roll:
Postby tubasteve » Mon Feb 27, 2012 4:40 pm
I am planning on a third, has to be 93....& white, no repaints from another color.....going to be hard, but i got luck with the three i have bought.88 white, 90 red, 90 black.
tubasteve
Postby tubasteve » Tue Feb 28, 2012 6:45 am
Yard run....
i know about the valves just not in the picture, with also doing the abs delete im working on different brake upgrades between the two i have right now. Im setting up st205 fronts on this spindle, doing minor testing onthe rears also for the hub change to 5x114.7 for wheel options and brake discs that work out of the box as well.
Ill be posting my updates as they go.
tubasteve
Re: TubaSteve - 2-29-2012
Postby tubasteve » Wed Feb 29, 2012 5:50 pm
At work, but what i did yesterday.
before:
after pressure wash
fix some holes tonight and pull the harness as well.
-jr
tubasteve
Postby tubasteve » Sun Mar 04, 2012 4:36 am
while waiting on my engines to get started/done i started onto other features on the car.
this is a 5x100 hub to the rav4 hub ive been talking about:
with the supra rotor on, people have had issues with the rotors needing a hub centering kepper, id like to point out the stock celica rotor moves A LOT! compared to the rav4 hub and supra rotor.
celica rotor and hub:click for video of hub play
rav4 hub and supra rotor: click for video of hub play
neat huh? after all the "needs a hub center" not saying you dont, but kinda neat to see st185 stocks, vs my hopefully new setup.
more to come:
or
i have two alltracs, so i am trying multipul ideas.
also working on the rears, just no pictures of this yet.
tubasteve
Re: TubaSteve - 3-3-2012. starting the 5x114 with 205/ other
Postby CMS-GT4 » Sun Mar 04, 2012 3:04 pm
In the video it looks like the holes for the studs are larger on that tt rotors? Is it really loose?
Postby tubasteve » Sun Mar 04, 2012 5:11 pm
The lose one is the stock 185.....the tight one is the supra
tubasteve
Postby robolt » Mon Mar 05, 2012 3:13 am
If you have a minute could you take a couple of measurements?
What is the difference in outside diameter of the ST185 and rav4 hubs?
Curious to know if my rotor hats would fit over the rav4 hubs.
thanks..
......robert
'90 CS conversion
240Z, Super 7, + others...
You are in a maze of twisty little passages, all alike
robolt
Images: 2
Location: California, Long Beach, SF Bay Area, Foothills USA
Postby tubasteve » Mon Mar 05, 2012 3:32 am
ill do tomorrow morning and check, its at my shop, im waiting on the rear hubs as well, not for the rav4 though, make that clear.
tubasteve
Postby darthripley » Mon Mar 05, 2012 5:02 am
interested to see you go through with the 5x114.3 hub conversion w/Supra brakes.
i'm considering doing something similar on down the road mainly due to the lack of proper width/offset in 5x100 rims.
what hubs are you using for the rears?
87 AW11 MR2 "Super 2" 4AGZE
99 SXV20 Camry "Maul" 5SFE
Female Moderator
darthripley
All Trac Goddess
Postby tubasteve » Fri Mar 09, 2012 6:36 am
Teaser post, I've been working a lot on testing it in the computer. All the drawing takes time for me. That's supra rotor mocked up to half spindle. I'll be finishing it tomorrow. Decided to watch start wars 5 instead.
-jr
tubasteve
Postby tubasteve » Fri Mar 09, 2012 6:37 am
darthripley wrote:interested to see you go through with the 5x114.3 hub conversion w/Supra brakes.
When hub shows, and installed, you will know.
I can hardly wait, if Toyota didn't want 272(I think) per hub....
tubasteve
Re: TubaSteve - 3-8-2012. the 5x114 front & rear hubs.
Postby tubasteve » Fri Mar 09, 2012 5:42 pm
Spindle for used hub.....
These use the same size/part number parking shoes. The rotor will fit stock.
And let's you adjust the rear brake.
And... "new 5x114.3" on left, stock hub right.
Also a treat that was dropped off to me yesterday. St205 Trans:
-jr
tubasteve
Re: TubaSteve - 3-9-2012. the 5x114 rear hub here :-)
Postby temperacerguy » Sat Mar 10, 2012 2:02 am
GAR!!!!! The antici
PATION is killing me....
What is this from???? You said "Lexus"? RX of some sort????
temperacerguy
Users browsing this forum: zaluss and 2 guests
