Project Autobot
Postby smog7 » Sun May 11, 2008 10:50 pm
good to see that you chose rebuild it instead of parting it out.
poor bear cub....
-omar
rally tarmac 1990 st185
smog7
Postby Autobot » Sun May 11, 2008 10:59 pm
I toyed with the idea of buying Lamard's car when he was thinking of selling. Pretty sure the bear cub died so the All-Trac could live!
Autobot
Postby Autobot » Sun May 11, 2008 11:17 pm
Polished my RC intercooler. Still needs a bit of work, but it'll do for now.
Autobot
Postby Autobot » Sun May 11, 2008 11:46 pm
The shop now has all the parts I've ordered. I forgot to snap pics of: 1.4mm TTE head gasket, ATS CT27 turbo, NGK spark plug wires, NGK Iridium spark plugs, new Toyota distributor rotor & cap, Greddy Type RS BOV, new Toyota speedometer cable, ST205 heat exchanger, pump and lines, H&R 25mm rear wheel spacers, Toyota turbo gasket kit, HFH, HFHOE, TWM short shifter, ARP flywheel bolts, extended clutch slave cylinder pushrod...might still be forgetting something.
Anyways, more pics of parts. :D
ACT 6 Puck Unsprung Clutch & PP
ARP Head Studs
ASI Performance Radiator
Speed-Source Crossmember Bushings, Stainless Steel Clutch Line
Autobot
Postby Autobot » Sun May 11, 2008 11:50 pm
Speed-Source Oil Level Sender Block Off Plate
Fidanza Lightened Flywheel
Moroso Oil Pan
Speed-Source Polyurethane Engine Mounts
Samco Radiator Hose Kit
Autobot
Postby Autobot » Sun May 11, 2008 11:52 pm
Still have this sitting in my basement. Toyota Rear Hatch Visor:
Autobot
Postby Autobot » Sun May 11, 2008 11:56 pm
This is the car now as it sits in the shop. Can't really see the rain guards all too well, I'll have to snap pics next visit. Still has the winter tires on, wasn't really expecting it to be summer before I get the car back. Good thing Jon took the car for a bath before I took this pic. However, he forgot to mention that the hood was off the hinges as I tried to pop it to take an engine bay shot. No damage done, just gave me a little scare.
Autobot
Postby Autobot » Mon May 12, 2008 12:12 am
Also got this fuel system from tjdouble07. It includes:
Modified stock fuel rail bored to 8mm and twin/dual fed
All Earl's Plumbing SS lines and swivel fittings
Almost new fuel filter with metric to -AN adapter to run SS lines
4 800cc SARD side feed injectors
Walbro 255lph fuel pump
Probably just gonna use the fuel pump for now, the rest with round 2 of mods. :)
Autobot
Postby smog7 » Mon May 12, 2008 1:00 am
nice collection of parts. plan to do anything with the suspension? also where did you pick up your hatch visor?
-omar
smog7
Postby Autobot » Mon May 12, 2008 1:38 am
Suspension was actually next on my list. Kinda disappointed that Teins went up in price. :doh: Also would like a C-One rear swaybar and a J-Speed front tower brace. Conrad at ACE Engineering mentioned fabbing up a brace similar to the J-Speed so we'll see what happens. After that I would like to address the stock brakes. I picked up the rear visor on eBay. First time I've seen it for sale, used Buy It Now and snatched it up. :wink:
Autobot
Postby maleek » Mon May 19, 2008 2:53 am
nice car! I'm also from manitoba...winnipeg to be exact.
maleek
Postby Kcman91gts » Mon May 19, 2008 5:17 pm
that fuel system is rockin , can you take some closer picks of the connections on them , thats really a work of art .
Kcman91gts
Postby Terracar » Mon May 19, 2008 5:46 pm
I just want to comment - black 'trac = shear sexiness. Great recovery on the car.
-Terra
Terracar
Postby Autobot » Wed May 21, 2008 11:35 pm
Thanks for the comments. I'll snap some more fuel system pics when I check out the car. Hopefully it should be done in the next week or two.
Autobot
Postby Autobot » Wed Jul 16, 2008 6:29 am
By week or two, I actually meant month or two...or three. Still waiting... :(
Autobot
