Project Stormbringer - Slightly less disassembled! (07/29)
Postby wakkjobb » Thu Oct 02, 2008 2:03 am
I got another set of stands today so tomorrow looks more better (yes I said that) for changing axles. Work today kicked my ass all around the block so I just wanted to go home and drink beer with my dog. Luckily he's not a drinker, so more beer for me!
He's my designated driver too... can't work the clutch that well though.
Dan
MFIC at Rainbows and Unicorns Fabwerkz :D
Old build:
http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=27648
New build:
http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=42305
Go-Fast parts:
siliconeintakes.com
wakkjobb
Postby Dracov » Thu Oct 02, 2008 2:05 am
So does that make you his designated drinker?
1988 Toyota Celica Alltrac
Dracov
Postby wakkjobb » Fri Oct 03, 2008 2:21 am
yes, it's a great relationship we have.
D-hiccup-Dan
Old build:
New build:
Go-Fast parts:
siliconeintakes.com
wakkjobb
Postby Dracov » Mon Oct 06, 2008 12:53 am
Aggravated with my boost controller, I decided to venture into new unknown waters and attempt to solve that annoying problem of the front wheels rubbing against the fender arches on hard cornering (and hard bumps).
Going in are a set of OEM springs off a certain ST185 from here.
Not a huge improvement in spring rate, but anything will help at the moment, and really couldn't beat the price. So with a set of spring compressors I spend my afternoon battling the front suspension. After finishing with the fronts I did a quick run around to see how things have changed.
Luckily I didn't seem to noticeably alter the alignment any; I really don't feel like paying for another one. Unfortunately, despite the springs being decently stiffer and offering a lift of a few mm, sharp rights can still make that wonderfully horrible scraping noise I've come to despise so much. Lefts however seem to be almost completely cured. At the moment I'll probably forego doing the rears; might get some SW20 springs at some point, and try something for the fronts.
...that or just buckle down and shell out the cash for a coilover set, assuming I can find one that can do something other than make her ride even lower than she is now. I want to be able to play on mountain trails for Pete's sake, not see if I can bottom out on a stray quarter sitting in the street. :P
Dracov
Postby Dracov » Wed Dec 31, 2008 3:39 am
Been quite a while since I've done anything to my dangerous combination of daily driver and project. But that's not to say I haven't been busy planning...scheming...depleting my bank account...and teasing wakkjobb whenever I can :)
My main concerns as the year has been coming to a close was to get her prepped for winter playtime, so my efforts have been put toward that end.
The main thing, of course, is the tires. While I like the all-seasons I picked up, I don't like having to rely on them to keep me from gliding straight into the fat ass of some SUV going 10MPH with their hazards on simply because there's some mountain dandruff on the ground. So I picked up a set of steelies and went with some General Altimax Arctic studded tires. Their tread pattern is nearly identical to what I originally wanted; Pirelli Winter Carving, but they ended up costing me alot less.
At the same time, I've been growing to dislike the mixture of lowered-ness and extreme softness of OEM springs. The fender rubbing was bad enough on the all seasons, but with the winter tires on the studs were just slowly remachining the fender liner unless I drove depressingly slow over bumps and corners. While the Megan coilovers would have been nice, they were too expensive for me to afford, and there wasn't any good data on what their -maximum- ride height was. So, I took the route of going with the Ground Control set with the adjustable height collars.
The spring rates aren't quite what I asked for, but I decided they were close enough, and had about the right ratio; 430lb/in in the front and 300 lb/in rear. The other problem was the fact of an unheated garage. That was dutifully resolved with a nice kerosene heater that I managed to get at a discount since it was Home Depot's floor model.
Over the course of three days - not counting a very big Yule Feast held at my house the other weekend - I tore into the suspension. I did the fronts first since I was familiar with that routine, and that was where the troubles all laid with respect to handling.
The weird and almost-no-information-available-about-them front struts that she came with:
Now with new spring :)
Rear strut with its new spring
And how she currently sits:
I did also intend on getting to the differential for some work there, but the rear end was very thoroughly seized with rust to where I couldn't get at much of anything, except to wrap the tailpipe with some insulation where it goes over the right rear halfshaft, since the heat has baked the boot there to where it's half missing.
But a couple people have offered to help one of these weekend so even that'll be soon taken care of, then I can put in a little acquisition I've had sitting around for the last few months ;)
Dracov
Postby Rick89GTS » Wed Dec 31, 2008 5:10 am
^C'mon, what's in the box?!
Rick89GTS
Postby Dracov » Wed Dec 31, 2008 5:55 am
...stuff :)
Dracov
Postby wakkjobb » Thu Jan 01, 2009 12:54 am
stuff, or things?
Did ya score an ST 205 IC???
Another turbo?
Toothless 4-yr old Korean boy in a sailor suit?
Wait, that was my box...
Dan
Old build:
New build:
Go-Fast parts:
siliconeintakes.com
wakkjobb
Postby RedCelicaTRD » Thu Jan 01, 2009 1:17 am
st205 lsd rear diff is my bet.
Postby Rick89GTS » Thu Jan 01, 2009 4:10 am
wakkjobb wrote:.......Toothless 4-yr old Korean boy in a sailor suit?
Dan
LOL :lol:
Rick89GTS
Postby Dracov » Sun Jan 04, 2009 8:03 am
Sure enough, it is indeed an ST205 torsen. Snagged it off Rinkya for $150. And I of course tore it open to make sure it was the real thing;
And with some invaluable help we were able to get all the nasty rusted bolts broken in short order. Swapped the Redline 75-90NS over into the torsen and bolted her back up with new fasteners in just a couple of hours. Also tossed in a new cushion since mine was trashed and allowing for bothersome clunking noises.
And then it snowed! ...but only a half inch or so. Need to figure out how to summon blizzards on command now :D
Dracov
Postby wakkjobb » Sun Jan 04, 2009 5:36 pm
...so this Torsen diff is like a locker or posi? Or is it just stronger/better than stock 165 units?
Dunno :shrug:
Dan
Old build:
New build:
Go-Fast parts:
siliconeintakes.com
wakkjobb
Postby Dracov » Sun Jan 04, 2009 6:01 pm
Torsen, short for "torque sensing" is a type of limited slip differential that uses only gears to prevent wheel slippage regardless of how much or little traction is available to both wheels. It truly doesn't lock the wheels together like a clutch pack, viscous coupling or a 4x4 locker does, but it will automatically distribute torque between the two wheels to maintain full traction on both. It's sort of a bizarre hybrid of LSD and open. Here's an article from the 80's going over its creation and showing how it works:
http://members.rennlist.com/951_racerx/PS84Gleason.html
It only has two weaknesses; it doesn't like shock loading very much (clutch dumps at 6k, etc), and if one wheel is off the ground, it will behave exactly like an open until that wheel makes contact with the ground again. The HMMWV and Audi S1 Group B car both used them to much success.
Dracov
Postby ___Scott___ » Sun Jan 04, 2009 6:29 pm
Dracov wrote:and if one wheel is off the ground, it will behave exactly like an open until that wheel makes contact with the ground again.
...or until you pull the park brake a little.
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Postby Rick89GTS » Sun Jan 04, 2009 6:48 pm
Good read, but I'll have to read it a few times to fully understand it :doh:
Rick89GTS
