l00k0v3rth3r3's '90 All Trac
Postby celigts » Mon Oct 22, 2012 2:31 am
How was it taking the subframe down to put the bushings in.? I wanna do this when I get my kit from Klue. Is it pretty easy?
3SGTE project motor very slow
celigts
Re: l00k0v3rth3r3's '90 All Trac
Postby l00k0v3rth3r3 » Mon Oct 22, 2012 2:35 am
i started it late on saturday and finished it mid afternoon sunday.... so its not terrible i was planning on doing a how to write up on it... but it would have taken me forever to get it done in time.... this trac being my daily
** also if you dont have a shop press i highly recommend it, the actual job took me next to no time, but my PO had installed the stock bushings upside down which caused me to install mine upside down then i had to basically to the job again... lame but shit happens
Gabe
1990 Maroon Audi 90 Quattro
1998 Toyota 4runner Limited
1991 Mazda Miata 1.8l
l00k0v3rth3r3
Postby celigts » Mon Oct 22, 2012 3:38 am
That's not too bad then. Just like dropping the tranny. Wasn't too bad for to do the poly fill like I see you did ;) my car is also my daily driver.
Can the bushings be installed and removed without a press? I keep thinking that it can be done with a hammer and a piece of wood pressed on the bushing to get it in. Or is it far to hard to do a press is pretty much mandatory.
celigts
Postby l00k0v3rth3r3 » Mon Oct 22, 2012 3:44 am
its do-able, i actually abandoned the press for a few of them...the angles didnt work out, but if you are going to go hammer method get a mini sledge aka an engineers hammer, and a bushing bearing driver kit...its cheap and will help a ton also grease the shit out of them.
word of advice when getting the old ones out, burn them with a torch, and use a small knife to cut the rubber around the metal sleeve...slam it out and then use a flat head screw driver and a hammer to get the 2 metal halfs out...clean the inside of the cradle and grease it slam the bitch back together. when you do it, if you have any questions feel free to pm me
Gabe
l00k0v3rth3r3
Postby celigts » Mon Oct 22, 2012 4:01 am
Definitly might PM you :) if I get the kit this week as I should be, I might install it next weekend
celigts
Postby l00k0v3rth3r3 » Fri Dec 14, 2012 3:23 pm
BC BR-type coilovers installed in the maroon one.... I feel like a rag doll being tossed around...damn you michigan roads!!! But I am happy about being back at stock ride height.
...more updates to come
Gabe
l00k0v3rth3r3
