Magnum's ST185 project
Postby magnum » Thu Aug 07, 2008 10:48 pm
I started with a stock 90 GT-FOUR
added Volk GT-N 17x8+31mm front 17x8+25mm rear wheels with 215/40R17 Falken Azenis RT-615 tires, HKS Silent hi-power exhaust and Tein SS coilovers.
Next I decided to add some more power.
Garrett GT-3271 turbo, Tial 38mm wastegate, K&N filter with bell mouth, and parts for me to build a custom twin scroll turbo manifold.
Parts to build a custom surge tank intake manifold with a 70mm throttle body.
Spearco intercooler with pipe for me to make a FMIC kit.
Speed source TFFR, Aeromotive FPR and lines for the fuel rail, Walbro 255 fuel pump, 750cc RC injectors.
TTE head gasket, ARP studs, ATS cam gears GSC S1 cams and Engle valve springs.
EXEDY Hyper Single Clutch
Various parts from Speed source and a m300 wide band.
Parts for me to build a down pipe and mid pipe.
I also bought a ViPec EMS but have not received it yet.
I will update as I complete each part of my build.
magnum
Postby tjdouble07 » Thu Aug 07, 2008 10:59 pm
Very nice! Good luck man, and keep us updated. :)
Trevor
1990 Celica GT-Four, runs 10's
tjdouble07
Postby Meurz » Thu Aug 07, 2008 11:23 pm
Looking good man! I'm still not convinced to go Vi-Pec over Autronic, but I'd love to hear your findings.. Good luck with the project, seems you've planned a nice setup! 8)
Turbocelica.nl
Meurz
Postby magnum » Thu Aug 07, 2008 11:48 pm
Meurz wrote:Looking good man! I'm still not convinced to go Vi-Pec over Autronic, but I'd love to hear your findings.. Good luck with the project, seems you've planned a nice setup! 8)
Pick what you think is best for yourself.
magnum
Postby syko says » Fri Aug 08, 2008 5:48 am
I will very much so follow this thread all the way through and beyond! 8)
Also, have you begun building your intake and exhaust manifolds? I am very interested in both!
Aloha,
Evan
syko says
Postby etantshi » Fri Aug 08, 2008 6:09 am
Very nice. How do you like the exhaust.
André B.
1991 ST185 (down but not out)
1996 RZN140 (the daily)
etantshi
Postby magnum » Fri Aug 08, 2008 7:09 am
syko says wrote:I will very much so follow this thread all the way through and beyond! 8)
I have to get my garage wired so I can plug in my welder, hopefully I can get it done asap.
magnum
Postby magnum » Fri Aug 08, 2008 7:11 am
etantshi wrote:Very nice. How do you like the exhaust.
I like it a lot. It's not loud and obnoxious, just a nice low db note.
magnum
Postby Fourplay » Sat Aug 09, 2008 2:09 am
I like the wheels, do you know the weight? Car color is my favorite too, guess what color mine is :wink:
I'd recommend the RC front bar, will give you much more space work with.
Anticipating feedback on the vi-pec!
91 ST185 JDM Pre Facelift Widebody
Fourplay
Postby magnum » Sat Aug 09, 2008 3:03 am
Fourplay wrote:I like the wheels, do you know the weight? Car color is my favorite too, guess what color mine is :wink:
They are 18LBS a piece. Believe it or not but I don't like the RC front bar. I like the stock one I have but would like a lip to improve the looks a bit.
magnum
Postby tw2 » Sat Aug 09, 2008 5:59 am
Very nice collection of parts. Can you give any more info on the gt32? From what I can guess from reading up on it from garrett's site, it is only a mild upgrade and supports less than the gt30, t3/t4 etc. Is that right?
Thomas, JDM 90 185, 06 350z
tw2
Postby mx6er2587 » Sat Aug 09, 2008 6:20 am
magnum wrote: Believe it or not but I don't like the RC front bar. I like the stock one I have but would like a lip to improve the looks a bit.
go with a round fog front. 10x better then the stock :D
mx6er2587
Postby syko says » Sat Aug 09, 2008 7:00 am
tw2 wrote:Very nice collection of parts. Can you give any more info on the gt32? From what I can guess from reading up on it from garrett's site, it is only a mild upgrade and supports less than the gt30, t3/t4 etc. Is that right?
This is a link that magnum gave me a while back. It is an MR2 with a GT32 as well.
http://www.mr2oc.com/showthread.php?t=306348
I have one currently installed and I think it pulls quite a bit harder than stock (only by comparison with Nigel's car) in the upper end. There is a slight lag rather than somewhat 'instant' boost. It is signigicantly larger than a CT26, but nothing very large at all.
Aloha,
Evan
syko says
Postby tw2 » Sat Aug 09, 2008 8:17 am
Good choice, looks like a very nice sized turbo for some stockish spool with a heap more on top.
tw2
Postby magnum » Sat Aug 09, 2008 11:29 pm
tw2 wrote:Good choice, looks like a very nice sized turbo for some stockish spool with a heap more on top.
Yes that is why I choose it. It fits in the gap between the GT28RS and the TD06-20G.
magnum
Users browsing this forum: Google Adsense [Bot] and 4 guests
