LegacyofDan's 4 ST165s: gruesome guts NSFW :P
Postby LegacyofDan » Thu Aug 21, 2008 5:30 pm
Postby LegacyofDan » Fri Aug 22, 2008 2:51 pm
Postby klue » Sat Aug 23, 2008 3:33 pm
spray the alcohol/water after the intercooler core, or it will condense on the core's fins
Postby LegacyofDan » Sat Aug 23, 2008 4:48 pm
i did take that into consideration, but the reason i put before the intercooler like that, so that the cold methanol of which is extremely volatile would cool the intercooler core even more, hence colder air
Postby 88st165 » Sat Aug 23, 2008 5:45 pm
^when you spray it before the core it will condense on the core fins like klue said and pool on the bottom of the intercooler. run it like that at your own risk, especially with meth. plus you are not introducing as much liquid in the combustion chamber (where the heat transfer is the most effective) as you normally would b/c some is condensing on the int core. anyway, keep up the good work.
Black st165 - gone
2011 FA5 - Family Truckster
88st165
Images: 2
Postby LegacyofDan » Thu Aug 28, 2008 1:27 pm
/\ yeah that does make sense, just the bitch is...that i already drilled into my intercooler...we will see how well it works, and if it totally sux ass, then i will do just as u guys say...
updates:
i have pulled that "decal plate" off from my intercooler and painted everything else all black, sorta like the ST205 W2A's...but mine will be cooler....i'm having my metal specialist, cut me out a piece of Mirror-finished steel to replace that one plate, and then i'm going to stick that TRD emblem and intercooler emblem on there...and its going to look sick.
my friend finally brought the last drilled rotor he sold to me, and i started the installation yesterday, but the bitch is, i keep chipping my red calipers, and its really starting to piss me off...on top of the fact, that my calipers are really starting to to piss me off more, since once i pulled them, re-aligning those two damn @#^%@%$ bolts is really a bitch for me...
pulled the stockie oil cooler, i'm begun the fabrication process of my ram air oil cooler, caped off the hoses from hell, never have to worry about them again
i'm now setting up up my oil pressure and oil temp gauges too, and finding their location where i want them in my cabin
almost done welding my frame for my new seats too
looking at a couple things now to purchase since i get paid soon...walboro pump, and some whiteline springs from 935, poly bushings from 935, and looking at the prices of bigger injectors...hmmm...lol if only i were to win the lottery :P
haha and i keep bleeding for this car like no other, i split my finger nail down the center, and that hurts alot every time i type...damned rusty bolts...
i will have pics up prolly later today...maybe, if it rains, then no. lol.
like before def open to comments, suggestions, constructive criticism and ideas. thanks guys :D
Postby Kcman91gts » Thu Aug 28, 2008 9:21 pm
Whats that electric exhaust thing you have .. would that be like a y pipe on a muscle car for straight pipe ?
Kcman91gts
Postby LegacyofDan » Thu Aug 28, 2008 9:25 pm
yes :oops: ....i like it...and it impresses the piss out of the girls and my ignorant guy friends....and i cant wait until i can pull up to a light rev the engine in stealth mode...and the person beside me thinks it just a late 80's NA celica....and then open her up....green light.... VROOOMMMMM....i dream of the day....
Postby etantshi » Fri Aug 29, 2008 3:31 am
I hope you have a lot of sucess with the cut out. Many electrical ones have been sketchy in the past with premature failure. Vacuum operated ones are more reliable, but let us know how it goes.
I have some of those same patches BTW.
André B.
1991 ST185 (down but not out)
1996 RZN140 (the daily)
etantshi
Postby LegacyofDan » Fri Aug 29, 2008 12:06 pm
well for the brief amount of time i got to use/enjoy/love my car, i did experience one problem to a some degree...once i closed it all the way i would need to a C-Clamp or someone ready to push the button as i pushed on the butterfly valve to open....and as i said, to some degree...look at the picture and u should note that the entire thing is covered in carbon...i was running REALLLLLLY rich, and all that crap built up and sealed her shut....some times if i was boosting, and i were to hit the button it would pop open...but my problems were all due to my richness and the carbon build up...but other than that i loved it and was worth every penny to me :D
Postby LegacyofDan » Sat Aug 30, 2008 11:15 pm
as you can see he finally brought my rotors, yay..lol
thank you 935 Motorsports
the only flaw with the radiator is that it appears to b used maybe since i found rust under the new coat of paint...the pic is blurry but u can see it
alright the brakes are being a serious pain in my ass right now...
i cant seem to make them clear the pads at all...
no matter what amount of effort i put into it...this is sorta starting to piss me off lol
any ideas guys...what do u guys do? like what could i be doing wrong? help please lol
edit:
btw i found out who makes them...ACE performance? i have never heard of them...so they are DEF NOT brembo's at all...but w/e we will see how they hold up
Postby Rick89GTS » Sat Aug 30, 2008 11:40 pm
^Get one of those brake piston tools to push the brake piston back into the bore. It's a simple little tool but works like a charm. I got mine for only $4.99 and it's great to have in the toolbox.
PS - Do you still have the AC compressor and (non-seized) AC clutch?
If so, PM me and lemme know how much you'd want for it.
Thanks, Rick
Rick89GTS
Postby LegacyofDan » Sat Aug 30, 2008 11:52 pm
yeah i have both pistons compressed as much as i can, its just on the slider rail device, thats where its compressed too much, but i will buy the right tool for the job lol, maybe the c-clamp just cant cut it...
and i still have the compressor in, i will get it out eventually, just want to get the right belts first before i puller the compressor, but like everything else is pulled out tho...and excuse my ignorance but what is a AC clutch?
Postby Rick89GTS » Sat Aug 30, 2008 11:55 pm
^AC clutch is just that grooved wheel at the end of the compressor; it's the part that contacts against the AC belt. It's all together.
Was your AC compressor still working?
Rick89GTS
Postby LegacyofDan » Sun Aug 31, 2008 12:03 am
honestly i dont think it was, maybe it just needed to be recharged, but i dont want to sell it to you only to find out that it doesn't work, i would feel like a douschebag, but when i pull the compressor i can sell ya the AC clutch to ya :), i'm sure that is fine condition but i will let you know once i pull it
