abraxxa's ST205
Postby Meurz » Wed Nov 19, 2008 8:26 pm
Nice Alex. What's next - 400/500? 8)
Turbocelica.nl
Meurz
Postby Autobot » Wed Nov 19, 2008 8:44 pm
Looking good.
Autobot
Postby syko says » Wed Nov 19, 2008 10:51 pm
those are great numbers! Cant wait til you start buildng up another engine.
Aloha,
Evan
syko says
Postby abraxxa » Sat Nov 22, 2008 11:34 am
Meurz wrote:Nice Alex. What's next - 400/500? 8)
pistons as soon as they break. :(
facelift ST205
abraxxa
Postby abraxxa » Thu Mar 26, 2009 9:00 pm
It's always different than you think...
I've swapped my ecu from this...
...to this!
yes, it's a bit smaller, but not that much.
Importing the mapping from the E8 was successful, I just had to adjust the trigger calibration because the engine stalled right after starting.
Next weekend my tuner duo will check if everything is ok when the next Haltech software release (1.03) is out.
Asap after that my new brake discs (Endless 6 slotted) are going onto the car (front & rear):
facelift ST205
abraxxa
Postby abraxxa » Sun Apr 05, 2009 6:26 pm
I've installed the Endless brake discs today, the OEM fronts where worn down approx. 2-3mm, the OEM rears where the same width.
If your interessted in more pictures check the gallery on my homepage: http://abraxxa.zorro.at/gallery/main.php/v/GT-Four/2009-04-05_Endless_brake_discs_installation/
I like the look of the Four a *lot* now! :)
facelift ST205
abraxxa
Postby Corey » Sun Apr 05, 2009 7:49 pm
Nice 8)
Corey
Images: 50
Postby CSAlltrac » Mon Apr 06, 2009 4:16 am
Its beautiful!
Postby Wicked Toys » Mon Apr 06, 2009 11:32 pm
Awesome work done, Car looks great.
Wicked Toys
Postby Autobot » Fri Apr 10, 2009 5:08 am
Very nice.
Autobot
Postby Evo_VIIIMR » Mon Apr 13, 2009 11:23 pm
Image[/quote]
Are those headlight washer nozzles?
Laramie
2005 GG MR
300+@24psi stock turbo(old)
now going for 400awhp(stock turbo+E85)
Evo_VIIIMR
Postby abraxxa » Tue Apr 14, 2009 5:59 am
Yes, never used them ;-)
facelift ST205
abraxxa
Re: abraxxa's ST205
Postby abraxxa » Sat Aug 06, 2011 9:15 pm
Project direct fire ignition was launched some weeks ago and here is the progress so far:
Todays work:
facelift ST205
abraxxa
Re: abraxxa's ST205
Postby l0ch0w » Sun Aug 07, 2011 6:05 pm
What kind of coils are those? And is that bracket bolted to your LH engine mount? Im doing something similar with GM LQ4/LQ9 coils and I could use some ideas for mounting locations.
Andrew
1991 Red Alltrac
l0ch0w
Re: abraxxa's ST205
Postby abraxxa » Sun Aug 07, 2011 8:20 pm
Those are Haltech sources LS1 couilds and yes I mounted them with an aluminium bracket onto the gearbox mount where the intercooler water pipes are also mounted to.
facelift ST205
abraxxa
