abraxxa's ST205
Re: abraxxa's ST205
Postby abraxxa » Tue Aug 09, 2011 6:31 pm
Yesterday I've added the power cables:
facelift ST205
abraxxa
Re: abraxxa's ST205
Postby Landon » Wed Aug 10, 2011 6:37 am
could you maybe fix the link or somethin so i could see the pictures? or maybe i'm just retarded... lol
White 1995 BMW M3
Black '90 st185 Sold :(
Landon
Re: abraxxa's ST205
Postby abraxxa » Wed Aug 10, 2011 6:47 am
Works for me.
facelift ST205
abraxxa
Re: abraxxa's ST205
Postby l0ch0w » Wed Aug 10, 2011 6:59 am
will you be shielding your 5v signal wires to the coil packs? Ive heard that ls1 coils are affected particularly badly by interference...
Andrew
1991 Red Alltrac
l0ch0w
Re: abraxxa's ST205
Postby abraxxa » Wed Aug 10, 2011 7:08 am
The 4 wire cable I bought doesn't have shielding, but thanks for the hint in case problems arise.
facelift ST205
abraxxa
Re: abraxxa's ST205
Postby Hic » Wed Aug 10, 2011 8:00 am
U don't need shielding at all.
I used these in Paris-Dakar MItsubishi Pajero 2010, and various other cars, never had a problem.
The problem is in bad ecu's, in 99.9% of cases.
Hic
Re: abraxxa's ST205
Postby phattyduck » Mon Aug 15, 2011 7:57 pm
Its a little late now, but the large crimp section of those wire ends should be around the shield of the wire, not the wire itself. It will help lower the stress that is put directly on the copper wire itself. Good job on soldering the connection though. :)
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Re: abraxxa's ST205
Postby abraxxa » Tue Aug 16, 2011 7:41 am
I know but I was unable to squeeze it into it with the shielding.
facelift ST205
abraxxa
Re: abraxxa's ST205
Postby MWP » Tue Aug 16, 2011 1:28 pm
Those are actually pretty average solder joints :(
The wire isnt clean enough, or you havent heated the join enough for the solder to properly wick into the inner strands of the cable.
You probably wont have any issues (in the short-med term anyway), but its something you should try to correct in the future.
Re: abraxxa's ST205
Postby phattyduck » Tue Aug 16, 2011 5:23 pm
MWP wrote:Those are actually pretty average solder joints :(
Heh, I was a bit unclear - I meant it was good he soldered them. Most (if not all) of those connections are crimped, then soldered, so it should be reliable, even if the soldering quality itself isn't perfect.
I'm just so used to the hack jobs on most cars (not on here, but in general). :bangshead:
phattyduck
Re: abraxxa's ST205
Postby abraxxa » Wed Aug 24, 2011 9:31 pm
I had lent my solder paste to a friend, seems this was the reason they aren't so well done.
Got it back today and the soldering went way smoother.
Yesterday I bought the last components and finished the loom today:
facelift ST205
abraxxa
Re: abraxxa's ST205
Postby l0ch0w » Sun Sep 04, 2011 3:20 am
In the future, I might recommend using no-clean solder next time :) Its not as friendly on the environment cuz it contains lead, but in all honesty... it makes life soldering a WHOLE lot easier, it flows into wires almost instantly and wont pool up like that.
Andrew
1991 Red Alltrac
l0ch0w
Re: abraxxa's ST205
Postby abraxxa » Mon Sep 05, 2011 2:54 am
I did use lead-containing solder but thanks for the tip!
facelift ST205
abraxxa
Re: abraxxa's ST205
Postby MWP » Mon Sep 05, 2011 10:03 am
Joints have just not been made hot enough. Flux would help too.
Re: abraxxa's ST205
Postby abraxxa » Sun Sep 18, 2011 12:15 am
On Friday I received the ignition cables:
Yesterday I've measured the last cable length and installed the harness:
Today I've soldered the four ignition wires to the Haltech and started it up.
Yesterday it didn't start because the batterie was too weak, but aber jump starting it and a short drive it fired up without problems today.
Conclusion: ignition problems are gone, it revs a bit better but the rev meter doesn't work because it's wired to an output of the stock ignition.
facelift ST205
abraxxa
