Phattyduck's SV25/ST205 hybrid
Re: Phattyduck's SV25/ST205 hybrid
Postby phattyduck » Mon Sep 23, 2013 6:31 pm
Just passed over 156k miles. Still running great. 24mpg on average so far with the 3s-gte! (I was getting around that with the 3s-fe auto)
Needs a few little things here and there, but I'm enjoying daily-driving it. :D
I've only been able keep up with oil changes, etc. Otherwise, the new house is taking up all of my time.
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby phattyduck » Thu Jan 30, 2014 9:23 pm
Minor updates...
Just past over 160k miles. Changed the rear diff fluid, swapped power steering pumps, got new tires (215/45-17 Michelin Pilot Super Sports) Did an oil change - a Fram PH8A equivalent (Purolator) fits with the relocation kit. It holds almost a quart of oil! With the relocation kit and hug filter, I think the engine holds about 6 quarts now.
Also in process is installing an EBC. Old school Greddy Profec-B - fits the age of the car/engine well and works well too. I still need to wire it in and run the vacuum lines. And yes, the engine bay needs a cleaning! Here are the main parts mounted:
Otherwise, things are good...
phattyduck
Postby UtahSleeper » Fri Jan 31, 2014 3:22 pm
Love your car man!!! If I didn't love the Celica's so much, the Camry alltrac is what I would have for my winter ride.
UtahSleeper
Postby phattyduck » Mon Feb 10, 2014 6:31 pm
Finished installing the boost controller. Woo! Nice to get an extra 30-40hp. :D
I also ran the wiring through the fender for the wideband O2, so that should be an easier install when I get to it (soon, hopefully!).
phattyduck
Postby phattyduck » Mon Apr 07, 2014 7:57 pm
New gas mileage record!
7.35 MPG :twisted:
8.92 gallons burned in 65.6 miles - including 5.2 gallons of 100 octane at $9.50/gallon.
I took the Alltrac out to the Willow Springs Streets of Willow race track for a track day with a friend (he has a mildly modified '05 STi).
Cooling off after the first session:
I ran in the 'intermediate' group. Here's the view from the driver's seat in the pre-grid, so you can see the typical cars:
I ran about mid-pack through the day. Passing a few cars, getting passed by a few cars. Sadly, I broke my throttle cable on the second session, about halfway through - got to sit off the side of the track through the rest of the session with the car idling, ugh. I was able to bypass the cable (it was the secondary cruise cable that broke) and get back on the track for the afternoon sessions. The drive home was annoying without cruise control. :doh:
End of the day:
Turned the front brakes blue:
Chunked the tires nicely:
The good:
- 17psi and about 94 (91/100 mix) octane is AWESOME!
- Engine ran perfect, aside from the throttle cable (the one I made/shortened)
- Transmission was perfect (missed one shift, it went to go into gear even without double-clutching on high RPM downshifts when I messed up)
- A few good 'whoa, that thing's fast!' comments. :D
The bad:
- Broken throttle cable (missed half of a session!)
- Suspension/chassis weaknesses
- Need more supportive/sticky seats (leather slides!)
The car understeers at the limit, at least in the dry on a track, though I did get a small touch of throttle-life oversteer. My rear swaybar is adjustable, looks like I will be adjusting it one level stiffer. If I was better at suspension tuning, I could probably improve the suspension response, but I'll keep it how it is for now because it's still comfortable on the street.
I have a few short videos that I'll be putting together and posting up in the thread soon...
phattyduck
Postby phattyduck » Mon Apr 21, 2014 4:11 pm
Video from the track day:
http://youtu.be/ouy1FSEfOGA
phattyduck
Postby phattyduck » Fri May 16, 2014 4:37 pm
Late pictures from Toyotafest. No awards this year - there were a number of nice supercharged V6 Camrys... Next year - painted front bumper/nose panel and painted/installed euro Camry GLi spoiler!:
While cleaning up the car and painting the brake calipers for Toyotafest, I found this:
I thought the Camry (with its different ball joint design) had enough room to clear the ST205 disks... turns out I was wrong. I have since ordered new ball joints, the STi disks, new pads and the correct centering rings to get the disks on there... Hopefully I'll finish the install this week. That should be 6mm more clearance for the ball joint. Luckily, I have the clearance behind the wheels for everything to move out.
phattyduck
Postby athousandleaves » Fri May 16, 2014 9:37 pm
Yikes! Good thing you spotted that before it was too late!
Also, is that a SOARER beside your car?!?!? So much about the Camry reminds me of the Mk1 Soarer but with two doors less and more power! I'd buy an aerocabin soarer in a heartbeat if one came up near me... fortunately not a popular car with the importing crew around here so I may still get my chance at having one.
1992 Red GT-FOUR RC 626•1800
1992 White turbo4WD
athousandleaves
Postby soarer.jzz30 » Fri May 16, 2014 9:53 pm
There is one for sale right now for 8k in mint oem condition right now leaves
soarer.jzz30
Postby phattyduck » Fri May 16, 2014 10:09 pm
athousandleaves wrote:Yikes! Good thing you spotted that before it was too late!
Yeah, its an '87. US legal, registered in CA (and driven regularly - my friends have seen it around their area a few times). He had been judged in the Camry category for the last 4 years until this year they finally listened and put him with the SC's... so he took second over there. (I got second to him in the Camry/Solara category last year). For some reason, the person who categorized the cars thought that "Soarer" and "Solara" meant the same thing?!? The drivetrain is stock aside from a cat-back, so its pretty close to the factory 240-ish HP. So, faster than most/all stock Camrys, but not mine. :P The Soarer is for sale if anybody in California is interested...
Anyways... yeah. I think the interference with the ball joint happened mostly during the track day. It was never obvious, especially over the sound of a little tire rub (heavy braking + bumps = max suspension compression). I put 20k+ miles on the brakes the way they were, so its very good that nothing bad happened. I'll be glad to have it all fixed and running again.
phattyduck
Postby phattyduck » Mon Dec 07, 2015 11:16 pm
Its been a long time since any updates...
Well, the rear brakes finally wore out. I accidentally let the backing plate hit one of the disks, so I figured I should bite the bullet and get all new parts back there. New OEM discs and pads, shipped from Japan (Amayama). $300 in parts, $200 in shipping... :doh:
Old stuff:
New stuff:
Otherwise, the car has been running great. Just oil changes and gas, pretty much.
phattyduck
Postby CTechBlueDragon » Tue Dec 08, 2015 2:24 am
Weird I never saw this thread before... I didn't see the spoiler in any of those pictures. Also do you have more pics of the interior? What kind of bumper is that? Every Camry I have seen has a solid bumper... does that thing vent through? It also has different turn signal lights... interesting. Where did you get the side marker lights? Thanks for the info on the resistor for the tac also. The hood looks sweet.
CTechBlueDragon
Images: 50
Postby phattyduck » Tue Dec 08, 2015 4:49 pm
CTechBlueDragon wrote:Weird I never saw this thread before... I didn't see the spoiler in any of those pictures. Also do you have more pics of the interior? What kind of bumper is that? Every Camry I have seen has a solid bumper... does that thing vent through? It also has different turn signal lights... interesting. Where did you get the side marker lights? Thanks for the info on the resistor for the tac also. The hood looks sweet.
The spoiler has never been installed, though I have all the hardware... You can probably find pictures of what it looks like by searching for a Camry GLi though. Pretty much all of the pictures of the interior should be on this thread, I think. Aside from the seats, steering wheel and all the gauges, it looks mostly stock.
The bumper is a JDM Camry Vista bumper, the headlights, corner lights, grill and nose panel are Australian Camry (must all be installed together, you can go for the Euro version too). The lower valence is from a '91. The hood is carbon fiber, though it is covered by a vinyl wrap at the moment to reduce sun damage and oxidation.
phattyduck
Postby CTechBlueDragon » Thu Dec 10, 2015 1:28 am
Wow man where did you source those parts? I have been looking for a while and I can't find anything. I am not looking to do the front conversion you did, I hate to say it but I think the car looked a lot cleaner when you first got it. The bumper would be fine if it were painted to match. I guess the other stuff is up to your taste. I have been looking at pictures of the GLI and GXI and they have a really nice looking rear valance piece(s) we never got, any idea where I could source one? I would also like a GLi or GXi badge for the rear but I cannot even find that. lol It also looks like they had some sort of stock side skirts also... I am going to be working on fitting some Boomer skirts from ST205 on mine this summer, the hard part is going to be integrating and keeping the front mud guards which I really want to do. If the engine isn't ruined completely I should probably get a few pics of things to post up soon if all is solved by some new bearings. Hoping its only rod bearings so I do not have to remove the entire engine and trans and take the trans off to do the mains also.... sigh Atleast I have a spare crank if that is jacked up too so minimal down time I hope.
Any chance you want to sell the spoiler since your not EVER going to put it on!? lol jk
CTechBlueDragon
Images: 50
Postby CSAlltrac » Fri Dec 11, 2015 1:57 pm
What hose did you use for the remote filter? The blue stuff.
Users browsing this forum: Baidu [Spider] and 5 guests
