Phattyduck's SV25/ST205 hybrid
Re: Phattyduck's SV25/ST205 hybrid (12/28,pg.3 project on hold)
Postby phattyduck » Wed Jun 16, 2010 12:02 am
If you guys haven't done this to your car, you totally have to:
http://www.mr2oc.com/showthread.php?t=3 ... -up+window
Auto-up windows! Totally cool. The wiring is already there in the master switch other than a diode. A little filing of the switch to add the extra 'up' position, and it just works! I checked, and the window will stop rolling up <1 second after any obstructions, but it doesn't 'back up' for safety. So, don't stick your hands in there. :twisted:
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby phattyduck » Mon Nov 22, 2010 11:36 pm
The project is rolling again. After a 9 month wait for custom parts, etc. on my WRX along with break-in and tuning time, the Alltrac is back under the knife.
I finally finished pulling the motor out of the FWD Camry over the weekend so I can start getting it ready (mostly cleaning it up!) for the Alltrac.
Hopefully there won't be too many wiring changes in the harness. I am also going to be putting on the Caldina side feed manifold and I have to do the auto-manual swap at the same time along with other goodies. At least I can start updating this thread with my progress again! :D
PS. The WRX got 283whp on a fairly conservative tune... 2.2L stroker motor, 272 cams, oversized valves, ported, and a small VF30 turbo with STi top mount intercooler...
phattyduck
Re: Phattyduck's SV25/ST205 hybrid (11/22,pg5 project restar
Postby phattyduck » Mon Dec 06, 2010 9:58 pm
I bought the Porsche Brembo brake kit from gtfourtc, and started the install this weekend. I still need to install some updated hardware / spacers etc. to get it just right on the Camry. Luckily, the Camry front end has more ball joint clearance, so I don't have to run spacers behind the disk. :D
Here's the preview on the brakes:
The rears will be stock ST205 parts.
phattyduck
Postby phattyduck » Fri Feb 18, 2011 6:16 pm
Wow, time flies.
Anyway, another small update. I was able to sell the FWD transmission with KAAZ LSD to a local guy... and I was able to clean up and assemble ST205 transmission and motor. Mental note - make sure to use sealant on the flywheel bolt threads. I didn't last time and it was leaking.
Putting the transmission back on the motor is a HUGE pain! I was able to do it by placing the belhousing on few blocks of wood (3 2x6's stacked flat) and used a small jack to adjust the transfer case up and down as needed for assembly. The motor was hanging on engine hoist. Lots of grunting later, they were attached. Oh yeah, and check out the Caldina intake manifold. :D
phattyduck
Re: Phattyduck's SV25/ST205 hybrid (11/22,pg5 project restarted)
Postby UtahSleeper » Sat Feb 19, 2011 5:37 am
Love the project and the car! I may have to end up getting me an Alltrac Camry cause you made that thing look good.
UtahSleeper
Postby phattyduck » Mon Feb 21, 2011 4:59 am
The Alltrac grew an extra pedal today... :D
It was much easier than I was fearing... All of the necessary spots are there on the firewall and dash bar to help place the pedal assembly. Only one welded nut was missing, but it was in an accessable spot and I just used a normal nut instead.
phattyduck
Postby darthripley » Mon Feb 21, 2011 7:13 pm
looks like you're getting a lot of great work done there Charlie :)
the caldina side feed intake mani is a nice addition - i assume you're going front mount which will prolly help out a lot since the hood has zero vents on it.
looking forward to seeing the motor in the car 8)
87 AW11 MR2 "Super 2" 4AGZE
99 SXV20 Camry "Maul" 5SFE
Female Moderator
darthripley
All Trac Goddess
Postby phattyduck » Mon May 09, 2011 5:46 pm
Old motor coming out:
Shift cables in:
New motor going in:
And in other news, I just moved to a new house in Pasadena... It's a nice old (1911) Craftsman place, but the best part is that it has a big garage and huge driveway... :D I hope I didn't throw out anything important in the move...
I have to update the wiring (change from '90 base-model body plugs to '89 Alltrac LE plugs), do the exhaust (modify HKS cat-back and custom midpipe) and do an intercooler (looks like I'll be going Laminova! :shock: ).
phattyduck
Re: Phattyduck's SV25/ST205 hybrid (11/22,pg5 3s-gte in!)
Postby Awesome-Trac » Mon May 09, 2011 7:28 pm
Bro i love your car, not only is it AWD but you can carry people with you :D
•Daniel
Awesome-Trac
Postby darthripley » Mon May 09, 2011 8:25 pm
Looking great as always Charlie :)
The brembo calipers look real nice up front! 8)
Female Moderator
darthripley
All Trac Goddess
Postby phattyduck » Mon May 09, 2011 8:41 pm
darthripley wrote:Looking great as always Charlie :)
Thanks!
I still gotta paint the front and rear calipers black, but they still look decent as-is. The most important part is they work!
The first weekend I had them on, I was in blizzard conditions in the mountains... it was hard to not lock up the brakes (just a touch of my big toe was enough). It was a slip'n'slide fest - with the suspension setup and torsen diff, it is tail-happy, even with 115hp. I managed to keep it out of any snow banks or ditches though. :D
Back on grippy ground, things are pretty nice. I think there is still a bit of air in the system though.
phattyduck
Postby phattyduck » Wed May 25, 2011 4:13 pm
The ECU is wired up... Now I'm noticing all the the little things that need to be transferred/add to this car - turbo timer, boost gauge, boost controller, WBO2, hood pins, radiator fans, etc... It is all little stuff, but it all takes time.
phattyduck
Re: Phattyduck's SV25/ST205 hybrid (5/25,pg5 3s-gte in!)
Postby phattyduck » Mon Jun 20, 2011 4:33 pm
Radiator fans in!
My to-do list before starting/driving the car seems to be getting longer, not shorter. :shoots: I guess I'm still making progress, though its hard with the great weather and other stuff in my life to focus on the car as much as I would like too.
phattyduck
Postby darthripley » Mon Jun 20, 2011 8:31 pm
ooooh shiney new rad looks great - what brand is it?
i know all about the list getting longer & not shorter on Super 2. i get some things done & then before i know it there's more work to be done b/c i want gauges here or want to switch this or that out. a lot of it is just me shooting myself in the foot :shoots:
keep it up on the camry & you'll have it done real soon :)
Female Moderator
darthripley
All Trac Goddess
Postby phattyduck » Mon Jun 20, 2011 9:07 pm
The radiator is an ST205 Koyo and those are two 11" Spal fans. I used to run a stock ST205 radiator/fan setup on the FWD Camry swap. I didn't take a picture of it installed, but there is only like 1" of clearance between the fan and the downpipe. Let's hope they used some high temp plastic on those fans... at least the downpipe is wrapped.
phattyduck
