88gt4de Project ... Just enjoying her when I can 11/21/15
Re: 88gt4de Project ... MORE gauges ! Dash mat ... 3/30/14
Postby 88gt4DE » Sun Apr 06, 2014 4:44 pm
So I have been seeing alot more oil in my intake than normal and I figured it was normal but its worse now than it was before. Thinking back to my engine problems we had changed the intake setup prior to the test drive. I had asked myself this question before and never took the time to re-search it. Why would an oil catch can NOT have and inlet and outlet. Because its a cheap POS that's not actually working. After seeing exactly the one I have cutaway it makes perfect sense now ... More to come later ...
Re: 88gt4de Project ... oil catch thoughts ... 4/6/14
Postby 88gt4DE » Sun Apr 13, 2014 2:32 pm
Fredericksburg VA last weekend and Maple Grove raceway in Mohnton , PA ... Car ran great .. I think I logged 500 miles between both weekends. Everything felt good. I will have to replace the sperical bushings in the back due to some slight play. So I think that's next followed by my mid pipe modification and install ....
Re: 88gt4de Project ... Rear bushings , catch can ... 8/9/1
Postby 88gt4DE » Sat Aug 09, 2014 8:51 pm
So I haven't posted for awile. Car is running very good which I prol shouldn't say too loud cause she can hear you ... :twisted: Anyway ... I replaced all four rear spherical bushings , both left and right rear tie rods and cam adjusters. Suspension feels absolutely great and firm. I wasn't happy at all with the oil catch can performance so I up graded to a baffled oil catch system instead. We will see how that one pans out. Have been having issues with window switches yet again but I know its contact issues and swapped out the passenger switch today so the passenger window stops getting stuck down. 8) Headed to the car show in Glen Burnie MD this weekend. I know I haven't posted pictures lately but they will be coming soon. Been way to busy to do the camera and phone updates .... Last piece of exhaust is next in line ! Has to be !! :smokes:
Postby ___Scott___ » Sun Aug 10, 2014 12:37 pm
If you carefully take the window switch apart, you'll find a copper rocker in there that bends very easily. If you bend it back, the switch will work more reliably again.
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Postby 88gt4DE » Sun Aug 10, 2014 10:36 pm
___Scott___ wrote:If you carefully take the window switch apart, you'll find a copper rocker in there that bends very easily. If you bend it back, the switch will work more reliably again.
yup ... did that the last time to both sides. I wanted to have extras and make them serviceable too without tearing door panel off. So passenger side is now done. Going to get another one maybe and do the auto up mod and do drivers ...
Postby 88gt4DE » Thu Sep 18, 2014 12:30 pm
Pictures as promised 8)
Right rear bushings and Tie Rod
VMS baffled oil catch can ....
I've hated these spacers since the day I put them on .... the one on the right .... Gooodbye !!!!
Re: 88gt4de Project ... Spherical bush and more .. PICS 9/18
Postby 88gt4DE » Thu Sep 18, 2014 10:08 pm
Car has been running very well ... I get a little smoke under high boost but I'm not too concerned with that at the moment. I have FINALLY started to fit my larger mid pipe that a got from my brothers 165. He was running a different downpipe (custom) and he had to cut it to fit his car. As I recall it was one of the SSauto midpipes that was advertised to fit but did not. So I chopped it and have been working on getting the front part to clear the oil pan. It ain't pretty but here's the progress ....
Starting point ....
Prior to chopping. My brother had to cut this pipe twice to get it to fit his 165 and he still wasn't happy with it. I'm going to attempt to get it in there with one cut ...
Decided on my chop spot and went to work on clearance.
So after all the messing around I did with it and I'm NOT exhaust guy by any means .... here's the remaining gap to fill ....
I took the front cut off part to an exhaust shop and had them do a slight bend to the right and down on the end that goes over the cross member. Test fit day #2 in a couple weeks. Gotta make some money. At least now I have my own bay at work and a 2nd to work in most the time so I don't have to beg and plead for space to work on the car anymore ....
Re: 88gt4de Project ... We moved ! 12/28/14
Postby 88gt4DE » Sun Dec 28, 2014 3:13 pm
Been awile since I've been on here ... The Trac is offically Garage kept ;) Still have to finish exhaust and Leather seats will soon follow in the new year. I think the turbo is starting to leak. Under high boost I get some smoke , not alot , but enough that I and others notice it ... still runs ok for now :)
Re: 88gt4de Project ... Just enjoying her when I can 11/21/1
Postby 88gt4DE » Sun Nov 22, 2015 1:01 pm
Been a long time once again. New house has really changed the amount of time I have to work on the car. However its still running and I take it on as many long drives as I can. I still have not finished the exhaust but I ended up waiting cause I wanted to see how registering the car as an antique would go and that is complete. Apparently this deletes the emissions check in my state so I can do the exhaust and get it to where I'm happy with it and leave it alone. Instead of always having to put the cat back in and then right back out ... sucked ... In 2 years we will see. Leather seats still not done and I have a set of folding UK mirrors painted and ready to go on. Still looking for that GT-Four emblem for the front of the grill ... Hope everyone is doing well out there ...
Postby Bempa » Sun Nov 22, 2015 4:51 pm
I know what you mean with time and house. Good to hear that you are using the car. :)
AE92 4age 20v Engine rebuilding
KE70 4age 16v In progress
ST165 3sgte Brum Brum
ADT251 2ad-fhv Daily
AE92 4age 16v Bigport What to do with this one?
ACM20 1az-fe Wife´s daily
Instagram Benny_Gustavson
Bempa
Postby 88gt4DE » Sun Nov 22, 2015 5:49 pm
Love driving it but for me weather has to be just right ... No snow, rain and temps above 90 outside forget it ...
Postby Bempa » Sun Nov 22, 2015 5:55 pm
You are really taking care of your ST165 :) I'm not that god, I'm really looking forward to the snow and driving on ice lakes. But atleast i have the car well protected underneith
Bempa
Postby 88gt4DE » Sun Nov 22, 2015 5:58 pm
It has previous repair spots on drivers side that have a little rust starting. Trying to keep that to a min before the holy shit overhaul begins in a few years.
Postby Bempa » Sun Nov 22, 2015 6:02 pm
Ah ok i understand that you dont want to make it worse.
Bempa
