project NIN
project NIN
Postby ulis_m86 » Sun Apr 26, 2009 11:06 am
hello fellow celica enthusiasts,
never got to introduce myself properly ive been a celica fan since i was in high school about 5 or 6 yrs ago started off buying a 91 gts for $300 and had to rebuild the engine. couple yrs later after a few more rebuilds headgaskets and new engine i decided id do a 3s swap. saddened by the fact that i will never have awd drive i found an alltrac not too far from me for 4k and instantly jumped on it even though its in very poor shape. but at least being in cali it has no rust. ive been meaning to start a project page ive been taking pictures with my phone for a while now and im finally getting around to uploading them. theres really nothing special after being a poor hs student i became a poor college student and now that i finally got a good job im looking to buy a house and looking forward to getting married. so dont expect nothing fancy from me. a lot of things i learned are thanks to alltrac.net and celicatech.com. i thank you all! i may be an ass at times but my intentions are good any all trac owners are always welcome at my house and im more than willing to help others.
so now a bunch of very random pictures
back yard parking
my gts
straight from japan
the all track
ulis_m86
Postby ulis_m86 » Sun Apr 26, 2009 11:13 am
twm short shifter
ulis_m86
Postby ulis_m86 » Sun Apr 26, 2009 11:24 am
loving speed source
i need gauges
rain gaurd (jdm tight)
rain gaurd install kit
bought my top mount wta here still havent installed it
cobra heat exchanger
eclipse head unit wiring
ulis_m86
Postby ulis_m86 » Sun Apr 26, 2009 11:33 am
front left and right axle seperate them from the bolts and they are the same
seperate them from the tranny different
previous owner knew how to weld im not sure if it was a good thing???
dropped the tank 3 times already and hate it
ssac twin tip exhaust thanks to palladek i believe
must of installed in wrong place cause i havent felt the performace gain lol
ulis_m86
Postby ulis_m86 » Sun Apr 26, 2009 11:43 am
dont ignore your turbos please
the replacement a jdm ct26 from the mr2 boards
ceramic wheel ready to be shattered
ulis_m86
Postby ulis_m86 » Sun Apr 26, 2009 11:50 am
highly recommend this kit from toyota
throttle body gasket is cheap too
that clip ppl talk about
ulis_m86
Postby ulis_m86 » Sun Apr 26, 2009 11:59 am
and then theres the black and white pics of me i didnt know my brother was taking
i would have posed
no not really
thats it for now :smokes:
let me know what you guys think?
ulis_m86
Postby klue » Sun Apr 26, 2009 6:17 pm
hey where did you get the header for the 5sfe?
Postby ulis_m86 » Mon Apr 27, 2009 2:36 am
ebay link
got it on ebay from a seller named surewinproducts back then it was intended for the 6th gen celica but someone on celicatech found out it bolted up just fine. i recently removed it due to the raspy honda like sound it made combined with my catback pacetter exhaust that got rid of my resonator. maybe with a resonator it would sound cleaner. i also had to pass emmisions and the guy looked at the header and ask for a carb #.[/url][/list]
ulis_m86
Postby Terracar » Mon Apr 27, 2009 1:46 pm
Why have you had to drop the gas tank 3 times? (I'm almost scared to find out) Also that is a nice place (IMO) for the turbo timer display. Have you done a write up on it? Assuming just ran the wires though dash and bingo.
Are you running the stock TMIC right now or a FMIC ?
-Terracar
Terracar
Postby ulis_m86 » Tue Apr 28, 2009 6:55 pm
when i first bought the alltrac it would just turn off on me and leave me stranded at random. it felt to me like it had a fuel problem so i did a tune up and change the fuel filter. it continued to do that so i ordered a walbro pump but in the meantime threw in a 5sfe pump i had lying around i just jumpered the fuel pump relay at the diagnostic box like the swappers do. once the pump came in i installed it but a few weeks later it started making a really loud whining noise like it was going to blow. so i looked around and bought a supra denso pump on ebay (it was the cheapest) it was also a knock off. i installed it anyways but one day ill put a real one in there.
the fun part about all this is that it was probably just the relay cause without that jumper it will still turn off. :doh:
i could have sworn there was a write up on that turbo timer location but i cant find it. theres at least 4 other ppl on here that have it there i stole the idea from them. i bought the hks harness so it was very close to plug and play only two wires to wire up hand brake and rpm signal from ecu which was really easy with the directions. some have made a bracket to bolt up the turbo timer others have used double sided tape to hold it in place. way i did it was grind away at the hole where the clock is at. so the turbo timer barely fits forced into there. the turbo timer has a slot like where the case splits in two. thats where it is held on to. and its such a tight fit that it does not move at all.
right now im running the stock air to air top mount. im putting together the rc wta intercooler but dont want to install it untill i fix all the problems i have with it so i wont have to drain the coolant later.
ulis_m86
Postby ulis_m86 » Sat Aug 01, 2009 7:27 pm
ghetto rigging the diaphragm
home made egr block off
replace your crush washers
injector o ring replacement
ulis_m86
Postby ulis_m86 » Sat Aug 01, 2009 7:32 pm
broke down and bought a new tvis assembly
ulis_m86
Postby ulis_m86 » Sat Aug 01, 2009 7:34 pm
speed source fpr kit
still need to fab a mounting bracket but no leaks
ulis_m86
Postby ulis_m86 » Sat Aug 01, 2009 7:40 pm
now lets kick back and have some beers!!!
Hangar 24 Orange Wheat Beer (delicious)
Black and tan
Obama beer? lol
a sad looking 4th gen at the junkyard
purple seats!
thats all for now enjoy!
ulis_m86
