BRD st185 hoping for 400bhp now mapped at 397bhp 370ft/lbs
Postby mixer72 » Tue Jul 07, 2009 3:53 pm
a bit about me and my car, i have a st185 JDM 1992 J, im am rebuilding the engine as we speak as it went pop on me last year :( i was runing 286bhp and 315ft/lbs of torque :D witch is pritty good for a few mods,
hear are a few pics of he car.
this was befor it went pop
and now for a few of the rebuild
hi every 1, well im hopeing to get mt st185 to 400bhp+ if i can, its away having a fully forged rebuild and with the list of parts that i will be fitting it shoud make the 400bhp+ here is a list of what i will be having fitted
CYLINDER HEAD SKIMMED, VALVES RE-LAPPED, NEW VALVE STEM SEALS
PRESSURE TESTED, SHIMS CHECKED, DEGREASED, CLEANED & PAINTED
BRAND NEW METAL 1.2/1.4MM HEADGASKET, NEW TIMING BELT KIT,
NEW OIL FILTER AND WATER PUMP
OIL PUMP
NEW H/DUTY RACING SHELLS
NEW PISTON RINGS
FORGED 86.5mm PISTONS
FORGED ‘H’ BEAM RODS
BLOCK REBORED TO 86.5MM CLEANED & HONED
ARP FASTNERS
CRANKSHAFT REGROUND AND BALANCED WITH RODS & PISTONS
JUN 264 cams
HKS 3S-GTE Valve Springs
HKS Duralumin Adjustable Cam Pulleys
HKS F-con V-pro GOLD
Forged Rebuild
Parts
Block ‘TORQUE PLATE’ rebored to 86.5mm & honed
Forged (cp) piston set and rods to suit
Crankshaft reground and racing shells
Balancing
Arp Bolts - Main and Rod
Cylinder Head Refurbishment
MHG Kit
Heavy Duty HKS timing belt
New st185 oil pump
Oil Filter
Water Pump
Engine gaskets and seals
540cc injectors
ct20b
evo 7 intercooler
2.5" intercooler pipes
here are a few pics of the engine starting to be striped down and the piston that was the problem
here you can see wher all the oil had bin blown out the seals
and the number 4 piston
here are a few more pics of the head build
a few more pics of the build :D
cam gear cover with clear windo so you can see the cam gear
and the cam cover
and my cam gear cover with clear lid so you can see the cam gear
update on the build, things are now coming to gether nice and looks like it will be ready bey end of next week :D
i was not happy with the hot pipe rought of the intercooelr so i red did it today.
and as you can see in thsi pics i have relocated the expation bottle
a few updated pics of the car all nice and clean
and a new mod to the back brakes
just got back from having the car maped and here is the result
at 1.1bar
at the fly wheel
at the wheels
so pritty happy with at for now, next job is to save and get me nice big turbo and injectors to go with it, then 380-400bhp here we come :)
air fuel and boost
power graff
full forged engine , 540cc injectors ct20b JUN264cams but not set up yet, full 3" exhaust and decat, HKS airfilter and with no air flow meter now, and was runing just over 1.1bar, the full spec if the engine is on the first page of the build
just finished making and fitting my cold air feed box, here as sum pics
first I made a cardboard template of the cold air box
then after I had coverer it on fibreglass resin I then raped it in heat reflective shield
then fitted to the car with a cold air piping going in to the box
not shore weather to fit a lid on it as it is a good fit to the liner under the bonnet which is acting like a lid plus I and benefiting from the vent on the top.
what do you think?
mixer72
Postby mixer72 » Tue Jul 07, 2009 4:23 pm
now with oil cooler
oil cooler just be hind the intrecooler
relocation plate were the oil oil filter went
thermostat and take off plate with oil filtter on shase leg
mixer72
Postby wakkjobb » Tue Jul 07, 2009 10:13 pm
Holy crap that is a long post.. but so much eye candy! Great looking build; I love the rally lights and oil filter relocation job. Also neat paint on the rear half there... haven't seen that before.
Pretty dang 8) 8) man!
Dan
MFIC at Rainbows and Unicorns Fabwerkz :D
Old build:
http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=27648
New build:
http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=42305
Go-Fast parts:
siliconeintakes.com
wakkjobb
Postby timmey » Tue Jul 07, 2009 11:40 pm
Hey,
Your quarter paint job is awesome, I really like it.
Cool build!
Timmey
timmey
Postby mixer72 » Wed Jul 08, 2009 4:29 am
did i for get to show you these
mixer72
Postby mixer72 » Sat Aug 08, 2009 11:41 am
just a bit of an update, I went back to Weston performance today to get the map looked at and they found it to be over fuelling lots :( but the good news is that they have now remapped it and it is pushing 353bhp and 300ft/lbs of torque at the fly wheel :twisted: :twisted: and all this power gains is from having an alternator that works :)
mixer72
Postby redGT4 » Sat Aug 08, 2009 12:06 pm
:notworthy:
54 trim hiflowed ct26; Custom top mount;2 1/2" exhaust; Turbosmart boost controller(not fitted); Autometer CF series; Everything else stock; The Haunter of the Hills.
redGT4
Postby DudeMan » Sat Aug 08, 2009 3:28 pm
Awesome job man.
How much faster does the car feel over stock? My HP goal is right where your sitting so I'm just wondering how it feels. Easy to drive around on the street?
DudeMan
Postby WarTowels » Sat Aug 08, 2009 4:06 pm
Great work man. Very impressive stuff.
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby mixer72 » Sat Aug 08, 2009 5:00 pm
it a very nice drive and id say stock is like walking compaired the the power i have now :D
mixer72
Postby pit_celica » Sun Aug 09, 2009 3:18 pm
how much boost and what was the AFR on this 352 HP dyno run?
Great car BTW!
Sam
1991 Toyota Celica GT-S ST184 with 3SGTE gen4 ST215 swap, Megasquirt 3 + MS3X, t3/t4 turbo, 3" full exhaust, front mount intercooler and more for fun !!!!!
pit_celica
Postby mixer72 » Sun Aug 09, 2009 5:05 pm
that car is runing at 1.2bar as for the AFR thay are pritty much the same as the last mapping :D and im still runing the standerd ct20 turbo
mixer72
Postby SleepingTurbo » Mon Aug 10, 2009 5:04 am
I'd like to know how you got 315lbft of torque out of your first build. thats incredible.
May be moving on from the All Trac world.
SleepingTurbo
Postby mixer72 » Mon Aug 10, 2009 3:22 pm
i just all wasy sem to have a good mapper so i gess it was down to the maping and probly quit a bit of addvanced timing but i have to say it was no were neer as quick and as power full as what it is now :evil:
mixer72
Postby YerRandO » Mon Aug 10, 2009 3:57 pm
Nice build!
Is there an advantage to running a 205 WRC oil pump?
-James
YerRandO
Users browsing this forum: Baidu [Spider] and 4 guests
