BRD st185 hoping for 400bhp now mapped at 397bhp 370ft/lbs
Re: st185 hoping for 400bhp now mapped at 397bhp 370ft/lbs
Postby mixer72 » Fri Nov 08, 2013 6:09 pm
some videos of me completion at shelsley walsh on the 6th July
first run of the day
http://youtu.be/5yk1rSb7IZY
run 2
http://youtu.be/zwM7xo1zNvk
last run and got me 3rd place
http://youtu.be/2R6NWGwbXJs
http://youtu.be/ZewbB5EWu3g
few more vids
http://youtu.be/xu5HJbGtjY8
http://youtu.be/E05Bwpas6WA
http://youtu.be/ZGdB9cKyqsQ
mixer72
Postby mixer72 » Fri Nov 08, 2013 6:10 pm
the Beast is getting a lighter rear end
took the rear bumper off and you have a bloody big steel bar hanging over the rear end
so I took it of
then rear fit the bump without any of the heavy steel
job done and now with a lighter rear end
mixer72
the start of some rear end bracing
40mm cage tube that will bolt to the rear sub frame
need to cut the cage tube and fix it from the bottom legs to the rear brace just by the top mount
http://i521.photobucket.com/albums/w332 ... 3e1dc2.jpg[/img][/url]
finished the new rear end bracing
mixer72
Postby mixer72 » Fri Nov 08, 2013 6:15 pm
been getting the lamp pods ready for the winter
Image[/URL
[url=http://s521.photobucket.com/user/gt4louis/media/20131016_094140_zpsa7161d65.jpg.html]Image
some old photos of the pods when I first got them about 5years back
mixer72
Postby mixer72 » Fri Nov 08, 2013 6:17 pm
all so starting to make my polly rear diff mount
first polly rear diff mount made
it will have a thoroughly testing on the Beast
polly bush made just goto paint it now then fit it to the Beast
mixer72
all so im just started to make 2.5" throttle body plats for the 185, this will help if you doing FMINC set up as it means you can use 2.5" pipe work
mixer72
Postby mixer72 » Fri Nov 08, 2013 6:19 pm
fitted new part the dash and just finished the flocked dash ready for the new wiring and switches and fuse box to go in :)
mixer72
Postby sinerasis » Fri Nov 08, 2013 7:18 pm
lol. I totally dig your project... but I had to laugh at your description of removing the bumper... you took the cover off and ripped out the actual bumper (the "bloody big steel bar"). The cover doesn't do anything other than make the car look pretty, that steel bar saves your life. I know it doesn't matter as much to you since you're putting a cage in, but that's kind of an important distinction. People that aren't building caged track cars should definitely leave that bloody steel bar in there. What would normally be a small accident requiring a new bumper cover could easily total the car out without a real bumper in there.
Jeff
1989 ST165 Black
sinerasis
Postby mixer72 » Fri Nov 08, 2013 7:48 pm
yes a agree with you for a road car but what you can do to make the car lighter on the rear end is swop the stock metal bumper for a RC or CS bumper as it is a single skin bar in stead of a double skin
mixer72
Postby 4rsnduction » Fri Nov 08, 2013 9:57 pm
sinerasis wrote:What would normally be a small accident requiring a new bumper cover could easily total the car out without a real bumper in there.
Old generation car.....fuel tank under boot.
Rear end accident with no metal reinforcing bar could lead to massive fireball on impact.
4rsnduction
Postby mixer72 » Fri Nov 08, 2013 10:12 pm
As i said not for a road car. Mine is used on track. Ane if you have ever seen crash testing of car when in the rear then you will know the it is nerly inpossable to to set on fire in a crash you can fire a bullet into a fuel tank and it will not set fire.
mixer72
Postby celicadude93 » Sat Nov 09, 2013 2:58 am
love the way your project is coming along man! really like the carbon fiber trim around the hvac controls. never seen that before. It looks good
1990 celica alltrac (restored)
2005 toyota 4runner
1990 celica alltrac (daily driver, trusty rusty)
celicadude93
Images: 13
Postby sinerasis » Sat Nov 09, 2013 3:21 am
I didn't even think about the gas tank. Are you using a fuel cell mixer? I'd be surprised if they let you on a track with the bumper removed and the factory fuel tank.
I love your thread by the way, tons of pictures! :)
Jeff
1989 ST165 Black
sinerasis
Postby underscore » Sat Nov 09, 2013 5:58 am
As long as the tank is outside of the cabin it should be okay. It would make a huge mess and likely light on fire if the rear end was impacted, but at least it'd be outside of the car.
Postby mixer72 » Sat Nov 09, 2013 8:40 am
thanks for all the comments :) all car’s a tested for rear end crash’s to see what will happen in every event, the chances of a rear crash making the fuel tank set on fire are very remote, like I said you can shoot at a tank full of fuel and it will not sot on fire, I’m still using the stock fuel tank at the moment as to have the fuel in the car needs a lot of work, you have to have it all sealed in a fire proof sell, and have all the fuel lines running in braded Teflon pipe which is not cheap, all so there is nothing in any race regs to say you can’t run without a rear bumper, my car has to go throw msa scrutineering ever time I go on track to make shore it is safe and passes every time, and if you’re worried about the car being totalled then you can say that about the front end as well as the RC or CS front bumper is just a sill bit of aluminium bar witch in any impacted will just fold up and this is a stock set up from manufacture all so most newer car's don't even have any steel bumper in them at all it all plastic and foam so you could say you could have the same problem with any car on the road
mixer72
