BRD st185 hoping for 400bhp now mapped at 397bhp 370ft/lbs
Re: st185 hoping for 400bhp now mapped at 397bhp 370ft/lbs
Postby mixer72 » Sat Sep 19, 2015 5:40 pm
got the Beast running today so happy with that :)
then onto more cooling mods with uprated power steering cooler fitted
than I needed a Boss for the water temp sensor to be fitted in the water elbow, so what do we do we just made 1
then fitted some heat management to the turbo
mixer72
Postby mixer72 » Wed Sep 23, 2015 6:39 pm
bit more heat management
and last for the intercooler pipe work finished
mixer72
Re: BRD st185 hoping for 400bhp now mapped at 397bhp 370ft/l
Postby mixer72 » Thu Oct 01, 2015 5:14 pm
so had to find a way of getting the oil out the exhaust this seemed to work
now that all the oil is now out the exhaust it back on the car, and if more or less finished every thing off, its all up and running now
mixer72
Postby underscore » Thu Oct 01, 2015 6:59 pm
That's quite the way to remove the oil, normally I use gasoline but for the volume of an exhaust system it might be a pain to do.
Postby mixer72 » Thu Oct 01, 2015 7:13 pm
I did flush it 3 times with petrol but still lots of oil in it so just used the blow torch to set it a light ;-
mixer72
Re:
Postby mixer72 » Sun Nov 08, 2015 6:44 pm
YerRandO wrote:Nice build!
Is there an advantage to running a 205 WRC oil pump?
is a 5sfe oil pump from ATC Racing witch gives better flow
mixer72
Postby mixer72 » Sun Nov 08, 2015 6:45 pm
well that's is more or less done, nice to see it out side, still smoking a but from the oil in the exhaust but that will go over time, MOT next Friday
mixer72
Postby underscore » Sun Nov 08, 2015 8:26 pm
Having the CF headlight covers looks so much better than painted ones with the CF hood.
Postby mixer72 » Thu Dec 03, 2015 8:16 am
well bit of bad luck with the new turbo :( the seals have gone in 80miles
and I was all so not happy with the compression so doing a strip down hone and new rings
think I may have a few 2 many pistons and rods ;)
mixer72
good new turbo being repaired for free :)
heard dropped off to Autocraft-Midlands for more mods and under bucket shims to be fitted https://www.facebook.com/Autocraft-Midl ... 575049429/
and have new CP rings ready to fit
mixer72
any 1 would think I build engines
mixer72
Postby mixer72 » Thu Dec 17, 2015 10:15 pm
bit of head work and cleaning up with TVIS deleted ready to fit back on
putting the rods and pistons back together ready to fit the rings and back in the block
and a bit of engine loom modding
mixer72
Postby mixer72 » Tue Mar 15, 2016 8:56 pm
getting there
mixer72
Postby ST185l » Fri Dec 09, 2016 11:17 pm
What is that part / black valve that is in the upper left part of the intake manifold?
Great project, I have had a lot of fun watching all the modifications. Precious GT4
ST185l
Postby mixer72 » Sat Dec 10, 2016 8:03 am
hi mate on the far left side on the front of the manifold? that is my MAP sensor for the ECU as I do not have the AFM any more, its all MAP pressure, im still working on it need to do some update lol
mixer72
