BRD st185 hoping for 400bhp now mapped at 397bhp 370ft/lbs
Postby tubasteve » Sat Aug 15, 2009 11:25 pm
what about this wrc? does it have the manifold aswell? or just the wrc turbo?
tubasteve
Postby bozo-merlin » Sun Aug 16, 2009 7:37 am
wrc not from rallye, wrc from 205 wrc means registration model
and as it is a gen2 engine the manifold are gen2 too.
Jérémy
ex 91 RHD ST185 - 2.94kg/BHP
93 RHD ST185 - 2.71kg/BHP
98 RHD SW20 NA
bozo-merlin
when the engine went
Postby whitest185 » Thu Aug 20, 2009 9:25 pm
You said the oil blew through the seals was it the cam seals because my 92 st185 had oil in the timing cover and the belt was walking off the gears. i think the walking was beacuae of a bad idler pully but im alittle baffled on the oil i bought new seals for cams and crank do you think there could be something else internally wrong with the engine??
whitest185
Postby mixer72 » Mon Aug 31, 2009 5:06 pm
bit more to be dun on the car :)
i have just finished striping down and painting the frount wish bones
and now thay are ready to have the new poly bushes fitted
i have all so just fitted a 12v superdharger to my cold air feed that goes to the cold air box
sorry this pics not very good, but it works very well and keeps a constant air flow to the filter witch when you are now moving will kepp the air temps down at the filter :)
i have all so added a bit of Co2 to help with the cooling :) what do you think?
mixer72
Postby MWP » Tue Sep 01, 2009 10:08 am
That oversized hair-drier will use more power than youll gain from the extra cold air.
Remove it.
Postby mixer72 » Tue Sep 01, 2009 11:24 am
the over sized hair dry as u call it is not even pulling 2amp so wont make any power loss, u will lose more power from having the rad fan on all the time :)
mixer72
Postby gt4tified » Tue Sep 08, 2009 7:31 pm
mixer72 wrote:the over sized hair dry as u call it is not even pulling 2amp so wont make any power loss, u will lose more power from having the rad fan on all the time :)
Really? Why is that? I thought the alltrac/gt4 came with a very capable alternator?
gt4tified
Images: 5
Postby mixer72 » Wed Sep 09, 2009 7:34 pm
a few more pics of the wish bones with the polly bush's fitted read to go on the car :D
mixer72
here is an upto daet lis of what i had dun to the car,
JDM ST185 353BHP 300FT/LBS AT 1.2BAR
MODIFICATIONS TO THE CAR
ENGINE MODIFICATIONS
 CYLINDER HEAD SKIMMED.
 VALVES RE-LAPPED.
 NEW VALVE STEM SEALS.
 BRAND NEW METAL 1.4MM HEADGASKET.
 HEAVY DUTY RACING SHELLS.
 FORGED 86.5mm CP PISTONS AND RINGS.
 FORGED ‘H’ BEAM RODS.
 BLOCK REBORED TO 86.5MM CLEANED & HONED.
 ARP FASTNERS.
 CRANKSHAFT REGROUND AND BALANCED.
 CT20 TURBO.
 FORGE ADJUSTABLE ACTUATOR.
 JUN 264CAM’s.
 JUN VALVE SPRINGS.
 HEAD PORT MATCHED AND POLISHED.
 PORT MATCHED AND POLISHED INLET MANIFOLED.
 PORT MATCHED AND POLISHED EXHAUST MANIFOLD.
 TRD THERMASTAT.
 MOCO 13 ROW OIL COOLER WITH RELOCATION KIT AND THERMOSTAT.
 HEAVY DUTY HKS TIMING BELT.
 HKS ADJUSTABLE CAM PULLEYS.
 540CC INJECTORS.
 WILBRO FUEL PUMP.
 HKS AIR FILTER.
 HKS F-CON V-PRO GOLD ECU.
 MAGNICORE HT LEADS.
 FULL 3” EXHAUST SYSTEM.
 3” DECAT.
 COLD AIR BOX.
 ELECTRIC SUPERCHARGER (FEEDING COLD AIR BOX)
 EVO VIII INTERCOOLER.
 2.5” INTERCOOLER PIPEWORK.
 HKS DUMP VALVE.
 BATTERY RELOCATION (IN BOOT).
 GROUNDING KIT.
DRIVE TRAIN MODIFICATIONS
 ST205 GEAR BOX.
 QUICK SHIFT.
 RPC 6 PADLE CLUTCH.
 D2 8-POT FRONT BRAKES WITH 330MM ROTORS.
 DRILL AND GROOVED READ DISK WITH RED EBC PADS.
 GOODRIDGE BRAIDED BRAKE HOSE.
 D2 RS COILOVER SYSTEM.
 POLYURETHANE ANTI ROLLBAR KIT FRONT AND REAR.
 POLY BUSH FRONT WISHBONES.
 POLY BUSH REAR SUBFRAME AND WISHBONES.
 BK 17” RACING ALLOYS.
 235/40/17 AVON ZZ3 TYRES.
INTERIOR
 EVO IV RECARO SEATS.
 52MM DIAMETER BOOST GAUGE.
 52MM DIAMETER OIL PRESSURE GAUGE.
 CHARGE TEMPERATURE GAUGE.
 AIR FILTER TEMPERATURE GAUGE.
 VISUAL PERFORMANCE PLASMA DIALS.
 BLITZ BOOST CONTROLLER.
 BLITZ TURBO TIMER.
 SPORTS STEERING WHEEL.
 SPORTS PEDALS.
ICE
 SONY MP3 HEAD UNIT.
 SONY 10 DISC CHANGER.
 350 WATT AMPLIFIER.
 500 WATT 10 INCH DIAMETER SUBWOOFER.
 PAIR OF REAR INFINITI GOLD 6.5 INCH ROUNDS.
EXTERIOR
 CARLOS SAINZ FRONT BUMBER
 RISING SUN GRAPHICS ON REAR ARCH.
mixer72
Postby mixer72 » Thu Sep 17, 2009 7:03 pm
sum pics of my evo 4 recaro seats
a few pics of the das at night
mixer72
Postby mixer72 » Sat Oct 10, 2009 12:40 pm
bin doing a bit more to the car today fitted my wish bones with the poly bush's and polly bush the anterollbar, and here are the pics
mixer72
Postby MWP » Sun Oct 11, 2009 2:15 am
mixer72 wrote:the over sized hair dry as u call it is not even pulling 2amp so wont make any power loss,...
If its only pulling 2A, it wont move anywhere near enough air for the engine.
If it worked, dont you think more people would do it??
Postby mixer72 » Sun Oct 11, 2009 8:58 am
its only there to feed the cold air box with cold air when you at stuck in traffic, it brings the temps down by about 10c witch is all i want it to do, it was never intendid to be the engine supply just to help with cold air to the air filtted.
mixer72
Postby mixer72 » Sun Oct 11, 2009 9:00 am
i would ay there arnt may people that have thought of trying this so i thought id give it a go to see how it worked, and i happy with it and it dose the job :)
mixer72
Postby JSchlaff » Thu Oct 15, 2009 2:57 am
Almost there man. Keep it up.
A9LTRAC
JSchlaff
