Grand Turismo - Aussie ST185 - track day found the weakness
Re: Grand Turismo - Aussie ST185
Postby MWP » Sat Aug 14, 2010 11:33 pm
Adelaide Jap have 205 gearboxes for $950.
Postby GrpAGT4 » Sun Aug 15, 2010 5:39 am
SERIOUS!
'91 ST185 GT-FOUR Grp A Rallye
GrpAGT4
Postby MWP » Sun Aug 15, 2010 10:25 pm
Hah, yes :)
Leave one for me though... i might need it if i cant rebuild mine (dead output shaft bearing) :(
Postby redGT4 » Tue Aug 24, 2010 9:49 am
I got my helmet for the track day. Just, just fit in the car with it with the seat a comfortable position. GrpAGT4 sent me some pics of his old wheels. They're white, which would look shit on my car, but i'm sure(fingers crossed) they could be sandblasted and powdercoated. :shrug:
I gotta quit smoking too. I've got a shopping list as long as my arm for this car, so its time to trade one addiction for another (i'm not sure which one the missus would prefer either!).
54 trim hiflowed ct26; Custom top mount;2 1/2" exhaust; Turbosmart boost controller(not fitted); Autometer CF series; Everything else stock; The Haunter of the Hills.
redGT4
Postby redGT4 » Mon Sep 06, 2010 8:30 am
Damn voltage leaks. Been chasing it down for a some time and thought i had it, but i did some voltage monitoring at the battery and sure enough it still there. Batt was 11.8v at 1230pm, then 11.49v at 1.30pm then 9.53 at 230pm. When the last owner put in the stereo they did a hell of a spaghetti hatchet job was well. :bangshead: :bangshead: :bangshead:
redGT4
Postby MWP » Mon Sep 06, 2010 10:44 am
Pull fuses and measure the current across them.
Will help track down the leak.
Postby redGT4 » Sun Sep 12, 2010 10:32 pm
So i got the car all cleaned up yesterday and went for a nice hour long drive by myself around McClaren Vale and Kangarilla. With no stereo it was good to listen to the engine, as i'm still not familiar with its particular sounds. Still having elect problems though. I pulled in to the shops after the cruise and turned the car off, put alarm on, came out, turned alarm off, go start and nothing. No electrical power at all. A quick disconnect and connect of the neg terminal got me going though. :shrug:
redGT4
Re: Grand Turismo - Aussie ST185 - track day found the weakness
Postby redGT4 » Mon Oct 25, 2010 7:42 am
If your car has a weak point the race track will find it. It was track day, so i did push the car hard, but somewhere on a clunky gearchange i must have over-revved - street driving i only go 5000, but i must have went to the redline or past it. There was a tinkle and i did feel something wrong so i headed in and that ended the day(morning :( ). Leaving the track, about 10k's down the road something went. I couldn't get it past 40kph, clutch in stalled it so i motored along to the main road which is has hi-speed trucks on it, pulled it up and waited around 1 hour for towtruck.
Once home i started it up and you should have seen the towtruck drivers eyes bulge out at the noise of it! Now its in the garage safe and sound. Tomorrow i shall drain the oil and see if i get metal.
redGT4
Postby MWP » Mon Oct 25, 2010 11:11 am
Ouch :doh:
The squealing was loud, but i imagine its unrelated.
Hopefully its not bottom end damage.
If it is though, as i said on the CCCSA chat, I have a ST205 gen3 block (pistons, crank, etc all in it, have not been touched) left over that i need to sell.
It would get you going again fairly quickly.
Postby redGT4 » Fri Oct 29, 2010 12:34 am
Cheers for the offer Mark. Money is a bit short at the moment and i'm sure the missus wouldn't be to happy about me splashing cash onthe car before xmas. I pulled the plugs and had a peep into the chamber - Covered in oil on cyl 1(closest to alternator or is it cyl 4?) the others were normal. Intercooler and turbo were free of oil.
redGT4
Postby MWP » Fri Oct 29, 2010 1:32 am
No probs. Shit time of the year for something like this to happen :(
Closest to the alt is Cyl1.
You might as well start stripping it down, find out exactly what the damage is. Pull off the head first.
With any luck youll be able to get it running again with a few new parts... though it sounds like itll be a full rebuild jobbie :(
Postby redGT4 » Sat Nov 20, 2010 5:54 am
Basic plan of attack (so far) -
Rip engine out of car and strip it down to find the problem. Fingers crossed it repairable for less than $1500. :rofl:
New engine mount rubber all around at the minimum.
Dress the engine bay
Drop engine back in and get it going again.
If it is a serious problem then get 205 half cut (hopefully).
If i have to go a 205 engine then i'll consider getting a vipec ecu and e85.
Oh well i guess my interior will have to wait another year. :bangshead:
edit - Then there is the gearbox - which is why i favor a 205 half cut. At the least i'm assuming my syncro's need replacing as well as the cables, bushings, rubber etc.
redGT4
Postby MWP » Mon Nov 22, 2010 1:18 am
Aim straight for the 205 conversion.
I know its difficult since the car is a daily, but itll very much be worth it in the long run.
Might be a good idea to get in contact with Lawrence from the club.
He'll be doing a 205 into 185 conversion sometime in the next month or so.
Might be a good idea to observe how it goes so you can pick up some tips for if/when you do yours.
Postby aus jd 2703 » Mon Nov 22, 2010 2:41 am
Ifi was to do it again I'd go patch harness as much as possible though some sensors need to be swapped so ya have to cut and solder. But u want to use the 185 harness. I got an Aussie bgb I can photo copy the stuff I used if it helps u?
aus jd 2703
Postby MWP » Mon Nov 22, 2010 4:16 am
Oh really, so you would'nt use the 205 loom?
Why is that?
