Grand Turismo - Aussie ST185 - track day found the weakness
Re: Grand Turismo - Aussie ST185
Postby redGT4 » Wed Dec 30, 2009 10:59 pm
MWP wrote:What area of Adelaide are you in?
Down in Hackham
sleeker162 wrote:still smoking? might have just been the turbo seal bedding in
Yeah, the outer film on the turbo has burnt off, i was thinking the turbo might have to break in for a bit. Too damn hot to take it for a spin at the moment, forecast for 40c today.
Also is there a safe way to remove the carbon from the oxy sensor. Mine is fairly well covered. I was thinking maybe carby cleaner or something. Toyota want like 275+ up to 320 depending on which store you call for a new one, is there a generic brand of them available?
Happy New Year to everyone :D
54 trim hiflowed ct26; Custom top mount;2 1/2" exhaust; Turbosmart boost controller(not fitted); Autometer CF series; Everything else stock; The Haunter of the Hills.
redGT4
Postby MWP » Fri Jan 01, 2010 1:40 pm
You cant drive it in 40degC temps?
Not going to of much use in Adel then :doh:
I was a little surprised by mine, no problems in hot temps at all, even when giving it some stick :)
Carb cleaner (and almost any other cleaner) will kill an Oxy sensor.
Dont need a genuine Toyota unit.
Any O2 sensor that will bolt in will do the job... might need a little wiring work though.
Postby redGT4 » Sat Jan 02, 2010 6:00 am
Good to know on the oxy sensor, i'll have to start hunting around.
As for the 40c temps, its me rather than the car, though i don't have coolant in it yet, just water (with a little left over toyota red). With the toyota red coolant, it takes 40 + in peak traffic temps just fine.
Otherwise it runs fine, idles okay, no ecu codes, i took it for a spin for about 10-15 ks yesterday, no probs, smoking is minimal, pulls hard at 10psi. Seriously though, it needs a straight road to get up past 150 kph for it to really stretch its legs, i'm up to the limit so quickly i can't get a feel for the turbo's new lungs and teh zorst will make a difference as well which i'm hoping to get done in the next week, or at least a quote and then get it in within 2 weeks.
I still have quite a lot to do.
redGT4
Postby MWP » Sat Jan 02, 2010 12:53 pm
Not too far away then.
Might have to meet up for a drive along Piggott Range & Main Rd sometime :)
Willunga Hill is a good place to give the engine a work out, bit of a drive to get out there though.
I go out there to do some engine tuning now and then.
Classic Celica Club has a cruise coming up on the 9th (this Sat) if your interested.
Decent length drive out to Tanunda and back.
Postby redGT4 » Thu Jan 07, 2010 9:39 am
arrgggh! I work on weekends 'cause its an 3 days pay for 2 days so no can make it. Forecast for 41c though, thats gonna be a killer for those underbonnet temps.
redGT4
Postby MWP » Thu Jan 07, 2010 2:33 pm
We have changed the cruise to 7pm on Sat night to avoid the heat.
Meet at Bunnings Mile End.
PM me if you want more info, phone nums, etc.
Postby redGT4 » Fri Jan 15, 2010 12:41 am
^ i'll be on of these cruises one day....
Got the zorst booked, 2.5 stainless, mandrel bends, hi flow cat, resonator and oval twin tip rear muff, getting that done on 4 feb then a dyno tune to check my afr's and get a power reading, on the 11 feb. Honestly, if it is above 130 kw at the wheels, i'll be fairly happy.
Though it is running at 9psi at the moment, its dropped one psi since the turbo rebuild, but seems to pull harder. :shrug:
redGT4
Postby MWP » Fri Jan 15, 2010 2:40 pm
Shame you didnt make the cruise, it was a good run though the hills.
Here is a bit of vid from it taken on a RA23.
http://www.youtube.com/watch?v=umR-pskUScE
Im in front of him heading down chain of ponds. Brakes went soft, so i had to back off for a bit :(
Youll see a backfire from my exhaust at the end too :)
You exhaust sounds good!
Ive got my GT4 booked in for exhaust for next fri too.
From dump pipe back to the rear muffler, 2.5in, mandrel, mild steel, flex, no cat, hotdog for $500.
Apparently AAA exhausts have a good rep, we'll see.
You should feel what its like up at 18psi then :evil:
Still only takes a week or two to get used to that, then want to wind it up further :(
Im not going any further than that though on stock internals and CT26.
Postby redGT4 » Thu Feb 04, 2010 9:30 am
Pic of the new zorst rear muffler. Sounds good. I think the twin tip looks good.
Rejuvenating the trim panel. All of the panel was like the top section; sun faded and ugly. Some Mothers Naturally Black brought it back to respectability. Though having done it, i would maybe wet sand with a fine grit first to reduce the scratches or just paint it.
Starting to detail engine bay A cut and polish of the strut tower to see how it came up. You can see how it was before just above the power steering reservoir.
Well, thats my major outlays for the car done for now. Next week it goes on the dyno, just for a check. Before hand I'll have to put it back up on the stands and tighten a couple of leaks, a bit of a clean.
redGT4
Postby redGT4 » Tue Feb 09, 2010 11:17 pm
There are some days you wake up and hate your cars. Today is such a day.
Daily driver: I had my radiator replaced a while back because of road debris (a sliver of glass) that pierced the fin and f**ked it. Even since then, cooling problems. arrrgghhhh! Checked the coolant today and lost around 2 litres - somewhere. I have no idea where as there is no apparent leaks. :pissed:
GT4: A shitty old battery and not much driving and a possible drain somewhere is pissing me off. I have found the door open light switch on the drivers door is faulty, so i've got a replacement from the wreckers, but some DMM troubleshooting is in order. arrrgggh! and it is leaking oil after i got the exhaust put on. No leaks before hand, i made sure of that. :pissed:
f**king cars :bangshead: f**king workshops :bangshead: F**K! :bangshead:
Tommorrow is dyno day as well. I wonder just how much power she'll put out?
redGT4
Re: Grand Turismo - Aussie ST185 - dyno results in
Postby redGT4 » Wed Feb 10, 2010 11:56 pm
Okay. Had the bitch dyno'd this morning. First of all the oil leak was fixed up, just a matter of tightening the T oil feed banjo.
Well. Remember this is a stock engine, just the zorst, a tmic, and the turbo flowed. Unfortunately the bitch is running very rich, actually it is extremely rich my AFR's run around 10.7 for the entire run. Toyota's like to overfuel!
The results (drum role please):
Max torque: 188.2nm @ 144kph
Max Power: 103.5awdKW @ 148kph.
Dyno was running 2.31 SAE j607 correction, ambient temps were 24.5c with 82% humidity
The torque ran a nice flat line through out the run but it isn't on the printout. The power, well, at the start of the run the AFR was okay,then it dumped fuel and the power suffered. If the AFR's we're better, power would easily climb.
Anyway, am i happy about the power - not really, some work to be done. A new ecu with fuel control should see a pretty good result for power - maybe the vipec plug n play unit.
Once i get the scanner from my dad, then i'll post up the actual sheet. I took some pics on my phone so'll might post those as well.
There was also another '185 there getting a new jdm engine from a half-cut and a new clutch put in it.
redGT4
Postby MWP » Thu Feb 11, 2010 10:32 am
What workshop was it at for the dyno?
Thats a pretty low dyno result :(
I would expect higher than that on factory boost and ECU.
New ECU should make a world of difference :)
Have you entered ToyoShow?
Postby redGT4 » Thu Feb 11, 2010 10:48 am
That was at Classic performance in Hackham.
I've been thinking about it all day. I suspect my oxy sensor maybe to blame, its old and covered in crud - i did post somewhere about cleaning it. I'll pull it tomorrow and give it another inspection. Stock intake with a cheapo Ryco filter is of course some restriction as well.
Hadn't heard of Toyoshow before - but i just googled it. Have to work those days - except for the friday. Should make it after work to glenelg for a quick view. Maybe will join up the cruise.
redGT4
Postby MWP » Thu Feb 11, 2010 11:48 am
EGO sensor wouldnt cause the problem. Its only used during cruise.
You cant clean them either, they need to be replaced.
We (Classic Celica Club) will be on the Friday night ToyoShow cruise too.
See here: http://www.classiccelicasa.com/forum/vi ... ?f=3&t=109
We will also have a club display at the Show & Shine on Sunday.
Postby redGT4 » Tue Feb 16, 2010 8:05 am
Well, My mates looking to buy Group A number 5. White. Serviced and maintained by Neal Bates Automotive in ACT. Fairly well stock. Interestingly it does not have the gold plate on the radiator support. This was only put on for specific customer orders, some Group A's sold off the dealer floor, and hence not spec'd by a customer did not have them (although i have yet to see a group A that has been spec'd up like mine)
Found a replacement EGO sensor as well - 1/3 of toyota's bullshit price. NGK 4 wire w/plug. Will help out my enrichment problem, not saying it will cure it, but we'll see what happens.
redGT4
