MWP's wannabe Tarmac Rally 5S-GTE ST185 (racing!)
Re: MWP's Australian ST185 (starting 5S-GTE build!!)
Postby GrpAGT4 » Sun Sep 05, 2010 1:04 am
And what was your address again? And what times of the day arnt you home? :D
'91 ST185 GT-FOUR Grp A Rallye
GrpAGT4
Postby MWP » Sun Sep 05, 2010 10:13 pm
Hah :twisted:
Postby MWP » Thu Sep 30, 2010 7:44 am
Engine build is go!
Specs for the new engine so far:
ST205 3S-GTE Head, Intake Manifold, Exhaust Manifold & Turbo (CT20B)
Camry SXV20 5S-FE Engine Block & Crank
CP Custom 10:1 CR Pistons
Eagle 3S Rods
ARP Main, Rod & Head Studs
Ferrea 6000 Series Valves (1mm OS)
Extensive Port & Polish
High Flow 5S Oil Pump
High Flow Resin ST205 Water Pump
Cleaned & Tested ST205 550cc Injectors
Extra RC Engineering 550cc Injectors on Custom Fuel Rail (for staged use)
Factory ST205 W2A Intercooler
Custom W2A Front Radiator
Hopefully a new ECU (Vipec V88 is looking good atm)
Bottom end and head valve work being done by Knight Engines (Tony Knight).
2.2L + 10:1 CR + E85 + Boost = fun (or so i hope)
Postby aus jd 2703 » Fri Oct 01, 2010 5:07 am
Awsome list so far I'm keen to hear about the 10:1 and the e 85. Should be very responsive. What turbo obviously down the track as that's an expensive build
aus jd 2703
Postby MWP » Fri Oct 01, 2010 6:18 am
Got the quote from the engine builder today... :shock: :shock: :owned: :bangshead: :cry:
Ouch.
Anyway... Itll be the CT20b for quite a while.
No plans for anything else as yet.
Hrm, 5S-GZE sounds like fun ;)
Postby toayoztan » Tue Nov 02, 2010 5:12 am
Pretty interesting project here, can't wait to see pictures of the motor from the builder.
Take some vids too when you're done, throwing the car around corners :)
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby MWP » Tue Nov 09, 2010 12:39 pm
My package from RaceEng arrived today as well :D
Cometic 5S (88mm x 1.43mm) MLS headgasket:
Eagle 3S rods:
CP custom 5S-GTE 10:1 CR spec sheet:
And one of the pistons:
Package also contained 3S ARP main and head studs.
Postby Hic » Sat Dec 25, 2010 10:47 am
if you want the best for the headstuds, use these:
http://www.raceeng.com/p-11936-super-al ... m-set.aspx
you need to retap the block for 11*1.25mm thread, but that is very easy for your machinist.
10mm arp's are not so good for the big power, the head lifts with no problem.
http://www.raceeng.com/popup.aspx?src=w ... ze%3dlarge
Hic
Postby MWP » Sun Dec 26, 2010 10:52 am
$430 head studs... hah, no way.
$$s could be better spent elsewhere.
Postby MWP » Sat Feb 19, 2011 12:08 am
One ST205 caliper painted...
Took 4-5hrs to clean & paint that one caliper :eek:
Ill also be ordering 2 or 3 new pistons ($30ea!) and a seal kit ($110) for em tomorrow.
Postby aus jd 2703 » Sat Feb 19, 2011 12:38 am
Hey how'd u fit the 205 calipers to the 185?
aus jd 2703
Postby sleeper » Sat Feb 19, 2011 12:50 am
Where you the one who got the center diff modded?
sleeper
Postby MWP » Fri Feb 25, 2011 1:53 am
sleeper wrote:Where you the one who got the center diff modded?
Nope, not me.
Postby MWP » Fri Feb 25, 2011 1:54 am
Engine plan now looks like this....
ST215 (Caldina) head + intake manifold (port clean up, match & polish)
ST205 exhaust manifold + CT20b turbo
Camry 5S-FE engine block (strong version) + crank (resized big end journals)
CP Custom 10:1 CR pistons
Eagle 3S rods
ARP main, rod & head studs
High flow 5S oil pump
5S or 3SGTE (gen2) sump
ST205 (if it fits) water pump
Current large A2A IC
Xtreme 5S Chromo (or Ally) flywheel + Xtreme 3S 6 puck cushioned clutch (DSBHD)
Injector Dynamics ID1000 (or ID1600) injectors + custom fuel rail + turbosmart FPR
Custom laser cut crank trigger wheel + Solaris 5S crank position sensor
MegaSquirt 3 (v3.0 PCB), with MS3X
... my head is about to explode :eek:
So i finally got a chance to look at the ST215 head stuffs today.
Gave it all a good clean so i could properly inspect the head and make sure everything needed was there.
Comparing intake manifolds (ST205 left, ST215 right)
Comparing valve covers (ST205 left, ST215 right)
And again. Timing belt covers will be an issue :(
Pile o ST215 valve gear
Cleaned up ST215 head
ST215 cams
All looks ok :)
