MWP's wannabe Tarmac Rally 5S-GTE ST185 (racing!)
Re: MWP's Australian ST185 (starting 5S-GTE build!!)
Postby aus jd 2703 » Fri Feb 25, 2011 2:23 am
Will a 215 intake fit a 205 head? Wouldn't mind a side feed option is all
aus jd 2703
Postby phattyduck » Fri Feb 25, 2011 5:48 pm
aus jd 2703 wrote:Will a 215 intake fit a 205 head? Wouldn't mind a side feed option is all
It takes very minor mods to fit. The throttle body is the only major issue. You either have to mod the throttle body and manifold (205 tb on 215 im) or wiring (215 tb on 215 im).
I'm going to try to figure out a way to do it with the 215 throttle body and intake manifold. Others have done it differently.
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby MWP » Fri Feb 25, 2011 9:02 pm
Ill be modifying the 205 TB to fit.
I will be running a MegaSquirt though, so may also look for a larger aftermarket TB.
Postby bozo-merlin » Fri Feb 25, 2011 10:25 pm
phattyduck wrote:I'm going to try to figure out a way to do it with the 215 throttle body and intake manifold. Others have done it differently.
That was done in 2009, using the 215 throttle on the 215 nitake manifold is the easiest way !!
:P :P :P
Jérémy
ex 91 RHD ST185 - 2.94kg/BHP
93 RHD ST185 - 2.71kg/BHP
98 RHD SW20 NA
bozo-merlin
Postby MWP » Thu Mar 03, 2011 10:40 am
Started disassembly to get the engine out:
Postby MWP » Thu Mar 03, 2011 10:41 am
Started working on the ST215 Caldina head.
Still a lot more to do.
Postby sleeper » Thu Mar 03, 2011 2:17 pm
What did you use to polish the chambers?
sleeper
Postby MWP » Fri Mar 04, 2011 12:19 am
A Dremel.
Takes a while, but its much more precise than using a larger air die grinder.
Ill use a die grinder for the ports though.
Postby MWP » Sat Mar 05, 2011 7:55 am
So i just did compression ratio calculations using: http://www.zealautowerks.com/
Comp ratio is too high with the ST215 head :(
Code: Select all
Number of cylinders = 4
Cylinder block bore diameter = 87.5mm
Cylinder block deck height = 215mm (i think this is correct)
Stroke of the crankshaft = 91mm
Cylinder head combustion chamber volume = 47cc
Piston dish or dome volume = -8cc
Piston compression height = 1.275in
Connecting rod length = 138mm
Compressed headgasket thickness = 0.045in
Total amount the cylinder head has been milled and the block decked = 0.5mm
Maximum operating RPM to determine mean piston speed and max piston acceleration = 7000rpm
Operating elevation of engine to determine effective compression ratio = 0
Boost pressure to determine effective compression ratio = 8psi
Results are:
Code: Select all
Static Comp Ratio = 11.03:1
Effective Comp Ratio = 17.03:1
Displacement = 2188.8cc
Rod / Stroke Ratio = 1.52:1
Piston-to-Deck Height = -1.384mm
Mean Piston Speed = 1813 fps (552 metres per second)
Max Piston Acceleration = 112755 fps2
Postby CSAlltrac » Mon Mar 07, 2011 3:44 am
Could go all motor alltrac :shrug: kidding kidding boost is good.
Postby Hic » Tue Mar 08, 2011 5:18 am
you can use cometic up to 3mm thick. just buy it and it will lower your comp ratio.
Hic
Postby MWP » Wed Mar 09, 2011 11:04 am
Did more on the head this arvo.
Chambers are now finished. They did have a mirror finish before the cleaning stuffs + water tarnished it a bit.
Then started on an inlet port...
Before i started:
Port matched & knife edged (lots more to do though).
One valve seat & short side smoothed out.
Postby MWP » Fri Mar 18, 2011 12:59 pm
Some updates...
Head porting done :)
Inlet:
Exhaust, not as polished as i would like, but good enough:
Shiny :)
Getting there... just rear drive shaft, gearbox cables, PS, and some lil stuff left to disconnect before dropping it out.
Postby MWP » Mon May 02, 2011 7:51 am
Cracked JDM engine out:
Postby MWP » Mon May 02, 2011 7:52 am
More done over the weekend...
One very dirty 205 gearbox:
Now clean... what a PITA & messy job. Looks like its been rebuilt before too, so i wont be opening it up.
Cracks in the engine block:
