MWP's wannabe Tarmac Rally 5S-GTE ST185 (racing!)
Re: MWP's Australian ST185 (starting 5S-GTE build!!)
Postby MWP » Mon Jun 20, 2011 7:39 am
Some updates....
MegaSquirt V3.0 PCB built with attached MS3 processor board:
JimStim V2.0 built (used to test the MegaSquirt on the bench):
Testing with my DIY MS3X status/testing board:
MS3 and MS3X 12 foot long wiring loom bundles:
Postby MWP » Mon Jun 20, 2011 7:40 am
Oh, and i also painted the gearbox :)
The engine block will be done with the same paint.
Postby MWP » Mon Jun 20, 2011 7:41 am
Engine bay cleaned & painted...
Before:
After:
Underbody sealer (tar) + chassis-paint + sand mix brushed on:
Postby MWP » Mon Jun 20, 2011 7:42 am
Next is to start cleaning up the factory wiring, removing whats not needed.
Also still looking for a SXV20R block :(
Postby aus jd 2703 » Mon Jun 20, 2011 9:40 pm
what valves and size valves are you using?
im having a browse at valves for my engine as the heads the next thing. and ive read ferrea valves wont fit gen 3+ engines any truth to this?
also ko racing sell ferrea valves in 2 and 2.5mm over size so might be worth the extra cash to get it from ko for the extra flow.
nice progress, let me know how u go with the megasquirt ive heard good reviews but then a mate had one and swapped to vipec so im curious how u find it.
aus jd 2703
Postby MWP » Mon Jun 20, 2011 10:47 pm
Stock valves.
The EPG does list a different part number for the valves, but they are the same size, so they must have changed material or something else small.
Did your mate get the MS installed and working?
Postby aus jd 2703 » Mon Jun 20, 2011 10:51 pm
yes in a turbo'd mx-5 was running a t-25 not sure what model it was.
he sold it shortly after blowing a turbo due to the crank angle sensor moving or something and it dumped fuel retarded timing and blew the turbo apart when it back fired, i guess like anti lag but worse. not saying it was the ms, it was the crank angle sensor. im curious on another opinion. he thought it was good for the money. it was probably an old model as he bought it over 2 months ago
aus jd 2703
Postby MWP » Mon Jun 20, 2011 10:59 pm
There are 3 base models of MS, and you can still buy all three.
Then there are a lot of variations on top of that.
Latest and greatest is the MS V3.0 mainboard with MS3 processor card and MS3X expansion board, which is what i have.
Very powerful lil things.
Vipec's are awesome ECUs though.
If i wasnt going with an MS, i would buy a Vipec V88.
Postby aus jd 2703 » Mon Jun 20, 2011 11:10 pm
ill have to look into it cause i have been looking for a haltech 1000. i like the option of a dash display and the little hand controllers that wolf and microtech sell look like ass lol.
im not sure if im electronically enclined enough for a ms but ill look into it. i want an ems so i can go e85 :) try and run 20psi on a stock gen 3 lol
aus jd 2703
Postby MWP » Tue Jun 21, 2011 12:05 am
To run a MS you really do need a decent clue about automotive wiring, and fuel tuning theory.
You also need to take the time to read all the manuals.
To keep it cheap, you need to be able to tell a dyno tuner how to use the tuning software, otherwise they will spend days ($$s) trying to work out how to use it.
I was going to go with a Vipec V88, but the MS3 + MS3X has as many features for 1/3rd the price.
You can see the kinda features they are working on for it in here: http://www.msextra.com/forums/viewtopic ... 25&t=38967
Postby Klas » Tue Jun 21, 2011 5:45 am
I run Haltech in my st165 and MS3 in my Jeep wrangler.
I think both of them are easy to work and tune with and good info and support is avalible online.
If you are on a tight budget, the MS can´t be beaten.
Keep in mind that MS uses serial port, so a adapter is recuired if using an modern laptop.
1/4 in 12.577s 176km/h so far
If you can turn, you drive to slow!
Now on youtube!
http://www.youtube.com/watch?v=hSD6LlwS830
Klas
Postby MWP » Tue Jun 21, 2011 6:13 am
MS1/2 are serial.
MS3 has a USB port.
Postby Klas » Tue Jun 21, 2011 6:29 am
Sorry, You are correct!
Now on youtube!
Klas
Postby alltracst185 » Tue Jun 21, 2011 8:21 pm
Get ridd of the ABS! It's an eyesore...other than that, very clean bay :wink:
alltracst185
Postby MWP » Wed Jun 22, 2011 1:14 am
Yeah i know... but ive been in an accident recently where ABS probably would have saved the car, so i would like to keep it :(
