Project - 205/TDO6/HALTECH ST165 - The Saga Continues
Postby GT4_DRED » Wed Feb 03, 2010 5:54 pm
I've followed this car for quite a few years now, so I'm posting this page to continue documenting it's various stages - For those interested.
Previous stages can be found posted here http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=16890
And here http://www.alltrac.net/phpBB2/viewtopic.php?f=6&t=19940
So I finally had time to drive up and pick the car up from Georgia to Nebraska - what a drive! So 19 hrs going (due to a snow storm) and 14 hrs coming back. A buddy and I tag teamed the driving so it wasn't that bad.
Initial plan is to replace the piston(s) and get it running with the 3rg gen it currently has. Get it to the dyno for some tuning in time for some mountain runs once spring rolls around. From there I'll be replacing the 3rd Gen with something better - a 2nd Gen of course :D ! I'll also be pulling the td06 setup, haltech, and atw cooler hopefully by end of summer. I post updates as they happen.
Leaving for the new home:
Currently how the she sits:
More to come as I begin tearing into her...
'88 ST165 - project "Rahtid"
'91 MR2
GT4_DRED
Re: Project - 205/TDO6/HALTECH ST165 - The Saga Continues
Postby GT4times2 » Fri Feb 05, 2010 3:37 pm
Looking sweet (I see it's already washed). I'm loving the pics, especially the last one (with the Lex). I wish I could have made the trip with you guys. Glad you got this car. It went into the right hands.
Frantz
12 Toyota Sienna LE
12 Toyota Camry SE
90 ST185 Gen4
88 ST165 Gen3-The works
89 ST165 Gen4-on the way
GT4times2
Postby alltracst185 » Fri Feb 05, 2010 4:59 pm
love the sc300!! :D
alltracst185
Postby GT4_DRED » Sat Feb 13, 2010 6:47 pm
GT4_DRED wrote:Initial plan is to replace the piston(s) and get it running with the 3rg gen it currently has. Get it to the dyno for some tuning in time for some mountain runs once spring rolls around. From there I'll be replacing the 3rd Gen with something better - a 2nd Gen of course ! I'll also be pulling the td06 setup, haltech, and atw cooler hopefully by end of summer. I post updates as they happen.
So 10 days later and plans have changed.. LOL.. After a bit of research I'm gonna keep the 3rd gen, stroke the bottom end, and massage and play with the head a bit - hey I'm lonely :shrug: ..
Bottom End: I've picked up a 5s crank, CP stroker pistons, and a set of Cunningham rods (3sgte).
Head: Got a set of stainless 1mm os valves, ATS springs, and I'm looking for a set of HKS 264s or Kelford 268s along with a set of adjustable gears... I'm contemplating doing a custom plenum on the factory runners.
Fuel/Mgmt: Got a set of 780's for now and I need a top-feed 3rd gen rail... I'm not completely sold on the Haltech E6k, so I'm looking at some other options.
Drivetrain: Picked up a CM FX700 for the 205 tranny and I'm still researching whether or not it's worth installing the 205 rear diff..
Misc: Still need to install the 205 rear brakes, front mount IC and piping, build a 3" turbo-back exh, put interior together, yada.. yada.. yada... There quite a bit to do..
'91 MR2
GT4_DRED
Postby the-jr-man » Mon Feb 15, 2010 12:41 am
sounds like its going to be sick when you get it running
the-jr-man
Postby GT4_DRED » Mon Feb 15, 2010 7:53 pm
the-jr-man wrote:sounds like its going to be sick when you get it running
It's def. a solid car to build on.. How is the Cressida project going?
'91 MR2
GT4_DRED
Postby the-jr-man » Tue Feb 16, 2010 1:21 pm
still waiting on the kid to send me the title back
the-jr-man
Postby GT4_DRED » Sat Apr 17, 2010 3:59 am
Picked up the parts from the machine shop after getting:
multi-angle performance valve job
seats cut for 1mm o/s valves and assembled
BC springs installed
new guides and seals
5s crank cut/polished for 3s rods
rotating assembly fully balanced (pully, crank, rods, pistons/pins, f/w and p/p)
Finished the welding on the intake manifold.. got the fuel rail and 880cc inj.. pe intercooler.. and some other stuff.. seriously considering doing tubular twin-scroll manifold - instead of the adapter.. anyway, just a bit of an update as I continue to gather parts.. should be pulling/sending the block to the machine shop in a few weeks and still deciding on what cam set to go with - the 3rd gen gsc 268's are tempting..
'91 MR2
GT4_DRED
Postby GT4times2 » Sat Apr 17, 2010 8:55 am
Looking really good!!! The machine shop did some nice work.
I'm sending some heads your way, (3S heads that is).....You know what I mean. :P
I'll drive up with one of them to have them look at it when I go up there. You're moving along faster than expected. (somewhat of rarity around here :| )
Show pics of the crankshaft.
Frantz
12 Toyota Sienna LE
12 Toyota Camry SE
90 ST185 Gen4
GT4times2
Postby GT4times2 » Sat Apr 17, 2010 9:09 am
Here are some of the pics I took a few weeks ago of the car.
Frantz
12 Toyota Sienna LE
12 Toyota Camry SE
90 ST185 Gen4
GT4times2
Postby 5speedGT4 » Mon Apr 26, 2010 1:19 pm
wow, looks like its coming along well
thank god someone that gives a shit about this car bought it.
LMK if you need any help/have issues with it. Im the original owner... still have a few parts laying around.
Andrew
ST165<----Sold
5speedGT4
Postby 3sgtenavyman » Mon Apr 26, 2010 8:09 pm
WOW, looks awesome just as good as I remember in high school.
LMK if you need help, I helped Andrew build the car twice, mostly over the phone the second time
Just glad the car went to some one that’s going to respect the car
Jon
st165/Black
2008 Matrix XR/ speedway blue <~the wifes car
01 ford focus/blue <~ daliy driver <~sold thank god
00 Mercury Mountaineer <~ the one doller suv
3sgtenavyman
Postby GT4_DRED » Wed May 12, 2010 1:00 am
5speedGT4 wrote:wow, looks like its coming along well thank god someone that gives a shit about this car bought it.
It's def. coming along and I'll probably be reaching out to you as I begin to reassemble things and put the a/c back in - this is HOTlanta. Shoot me an IM on what you have left.. I think the prev. owner had good intentions with the car, but I can see how it could be overwhelming.. Do you still have pic of the car on the track?
3sgtenavyman wrote:WOW, looks awesome just as good as I remember in high school. LMK if you need help, I helped Andrew build the car twice, mostly over the phone the second time - Just glad the car went to some one that’s going to respect the car
I'll def be reaching out for help when the time comes. I gotta say that the work done to the car was pretty good, so it's making my job a lil easier. Just getting parts together for now, but hopefully within the month I'll be ready to assemble the motor.
'91 MR2
GT4_DRED
Postby GT4_DRED » Tue May 25, 2010 3:31 pm
So I decided on the GSC Power-Division S1 3rd gen cams since they were running a really nice group buy on the mr2 forums. I heavily considered the S2, but decided that the lift on the S1 was enough for my current goals (these would also be really nice in a gen2 head). I cant wait to see what this head does with the HX40pro, but I'm wondering if the stock turbo manifold may be a bottleneck? Here is what the head looks like so far..
Head: 3rd Gen
Cams: GSC-S1 (In-268 Duration, 10.5mm Peak lift/Ex-268 Duration, 10.2mm Peak lift)
Valves: 1mm o/s stainless
Springs: Brian Crower
Ports: Sort radius modded for o/s valves, but otherwise stock
I decided to go with a 5s block after all, so it's at the machine shop along with the pistons. I sure wish there were some E85 station local, oh well it's getting there..
'91 MR2
GT4_DRED
Postby GT4times2 » Tue May 25, 2010 4:01 pm
Dude, you are on your way to a very nice build. At this rate, I'd have to put the Alltracs aside and get that Evo or STi to run with you. :notworthy:
Frantz
12 Toyota Sienna LE
12 Toyota Camry SE
90 ST185 Gen4
GT4times2
