OKC Project-8/1/15-Another fun car!
Postby toayoztan » Mon Mar 15, 2010 8:01 pm
I am in the process of rebuilding my Alltrac. I like to use a lot of pictures, so for those that love pics, you won't be disappointed!
Thanks for checking this out!
UPDATES
7/24/10 - Page 1
Parts
10/01/10 - 1
Motor and tearing/stripping down the car to prep for full body/paint job
10/05/10 - 2
Motor disassembly
11/08/10 - 2
Parts
3/06/11 - 3
Body prepped and painted
3/10/11 - 4
Interior cleaning, before and after
3/14/11 - 4
Engine bay cleaning, before and after
3/24/11 - 4
POR15 on front of car
4/10/11 - 5
More parts and OEM stuff
5/09/11 - 6
Fender-well and rear-underside cleaned, before and after
10/22/11 - 6
More parts and motor build
10/23/11 - 7
Block build and powder coating work
11/04/11 - 7
OEM parts, rebuilt alternator and starter, ASI radiator, Tein SS
11/07/11 - 8
Oil Dip Stick with Plasti Dip and teardown of the suspension/spindle stuff
12/24/11 - 9
Rear drivetrain parts coated and cleaned
12/30/11 - 10
Front suspension parts coated, SuperPro Bushings installed
1/16/12 - 12
Front and Rear suspension installed
6/02/12 - 15
Rear exterior stuff installed.
6/10/12 - 16
Rest of the rear together with ebrake installed.
7/21/12 - 18
Pics of the ACPT CF DS and sunroof drain tubes rerouted.
8/05/12 - 19
Freshly waxed with Collinite 915 and pics of wheels.
10/14/12 - 20 and 21
Door and interior stuff put back together.
11/08/12 - 24
ABS and Cruise Control wires removed.
12/20/12 - 24
AC removal complete. New windshield. Dash and rear speakers installed.
1/11/13 - 27
Carpet, rear seats, rear passenger and trunk panels installed. Front end stuff installed.
1/19/13 - 27
Hood latch assy, power steering, and windshield wipers installed.
2/21/13, 4/12/13 - 29, 30
Wheels!
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Re: The OKC Project
PARTS - these will on my alltrac and the 93 motor it was pulled from. I have a 92 motor around that I may throw a stroker in later or do something different with. I'm a proponent of keeping the original motor/block with the car so I probably wouldn't use the 5s block, but I'm not looking for insane HP either with this car. Enjoy!
CP 9.0:1 86.5mm Pistons
Eagle H-Beam Rods with ARP Rod Bolts
Main and Rod ACL Race Bearings with ACL Thrust Washers
ARP Main and Head Studs
ARP Flywheel Bolts
ATS 170-degree Thermostat
ATS GM Knock Sensor Adapter and Pigtail
Ferrea 1mm Oversized (OS) Intake and Exhaust Valves
Ferrea Valve Seals
Ferrea Keepers
HKS Valve Springs
Brian Crower (BC) Titanium Spring Retainers
HKS 272 Intake and 264 Exhaust Camshafts
Fidanza 4-point Adjustable Cam Gears
Speed Source Top Feed Fuel Rail (TFFR)
Aeromotive Adjustable Fuel Pressure Regulator (FPR)
Walbro 255lph Fuel Pump
Precision 750hp Bar and Plate Intercooler
Straight Pins (I forget where these go exactly, but I'll figure it out)
Key (Crankshaft Gear)
Key (Crankshaft Pulley/Harmonic Balancer)
Crankshaft/Timing Belt Guide
Crankshaft Bolt
Idler Pulley 1
Idler Pulley 2
Idler Pulley 2 Bolt
Cam Gear Bolts
Timing Belt Tensioner
Toyota Oil Filter
Toyota Waterpump
"3SGTE" Upper Timing Cover Sticker
"Spark Plug Info" Upper Timing Cover Sticker (I don't know why I got this...probably won't put this on)
Speed Source Shift Cable Bushing Kit
Speed Source Shifter Base Bushing Kit
TWM Performance Short Shifter
TWM Performance A6 Leopard Shiftknob (Gun Blue Finish)
Speed Source Crossmember Bushing Kit
Speed Source Polyurethane Engine Mounts
Mario's Solid Aluminum Rear Differential Cushion w/ Solid Rear Differential Mounts
Mario's Solid Rear Subframe Mounts
These show the descriptions of the following bushings with part numbers for anyone that's curious (these bushings can be found at rocketeerperformance.com or 185performance.com):
Whiteline Rear Adjustable Sway Bar
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Re: The OKC Project
Postby toayoztan » Sat Jul 24, 2010 7:48 pm
Sorry, I know it's a lot of pictures to load up.
If you see "red x's" then you can either just refresh the page or right click on the "red x" and click on "show picture" when the menu pops up.
If there's still problems loading, i may just switch to photobucket. Once the pictures are loaded up though and you revisit, there shouldn't be problems having them load up again since more than likely your internet settings have cookies enabled.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Re: The OKC Project
Postby gt4gordon » Sat Jul 24, 2010 8:49 pm
Lilking the look of this project what's your plans for the car?
Love to see loads of pictures. Look forward to see the build start.
gt4gordon
Re: The OKC Project
Postby Meurz » Sun Jul 25, 2010 1:10 am
This is going to be EFFING good. Please continue posting such crisp and large pics. This is how a project thread needs to be imo, while I'm planning my own big build, I'm all ears. Well, eyes. Love it!
:notworthy:
Turbocelica.nl
Meurz
Re: The OKC Project - UPDATE: pics posted on pg.1
Postby toayoztan » Tue Jul 27, 2010 4:40 am
gt4gordon: Plans are to add a better turbo (nothing HUGE) with an EMS tune and see what happens. Then I'll adjust and tweak or change out what I need/want when I have more money, time, and experience with the setup. In terms of numbers, not really shooting for a specific HP goal at the moment.
Meurz: Thanks! Yeah, I'll definitely keep this updated with plenty of pics!
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby SleepingTurbo » Thu Aug 12, 2010 10:49 pm
where can i get the solid aluminum diff mount and rear subframe bushings? all the marios stuff?
May be moving on from the All Trac world.
SleepingTurbo
Postby turbo4wd » Fri Aug 13, 2010 3:21 am
SleepingTurbo wrote:where can i get the solid aluminum diff mount and rear subframe bushings? all the marios stuff?
This is the only email I can find.. its old so I don't know if it still works, but it wouldn't hurt to try: mario.koenig@gmx.at
Here's his profile on the forum: (but it looks like he hasn't been around in a while so not sure if a PM would get answered quickly)
http://www.alltrac.net/phpBB2/memberlist.php?mode=viewprofile&u=29
Like everyone has said in the past, fair prices, quick shipping. Hopefully he's still making them, or has some new old stock on hand..
Dan
Undercover Moderator
turbo4wd
Postby WarTowels » Tue Aug 17, 2010 8:50 pm
Looks like a sick start. :D
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby Autobot » Sat Aug 21, 2010 11:37 pm
I like where this is going. Keep it up. :)
Autobot
Re: The OKC Project - UPDATED - Read first post for description
Postby toayoztan » Fri Oct 01, 2010 6:29 am
Everything on the exterior was absolutely removed. The exterior, all jambs, behind door panels, behind front fenders, engine bay, etc will be painted. The interior will be left untouched. I plan to just wipe up the interior really well. Here ae some pics throughout the tear down process. In total, I took about 1100 photos to ensure I don't miss where a single bolt goes (yes, I am OCD about certain things! :lol: ).
Here's the car in it's "raw/original" form right before I started tearing her down. At this point, the car was still running perfectly fine.
First off, drop and pull the motor! Here's the motor before I started on it. Dirty, but over the years it's been freshened up and tuned, so it still pulled its weight!
Lifting up the car to clear the motor. I find it's always easy to pull the motor from the botom (and put it back through from the top...).
Do we have enough clearance? I think it's ready to be pulled out!
Here's the back of the car at the time...the rear is pretty slammed, but with ample room if needed to raise the front higher...
Here's the engine bay, minus the motor/transmission. Wow...talk about grime, debris, dirt...unsatisfactory!
Next, pulled a few things off, including the front bumper skin/fascia. This will be replaced with the CS bumper and skin.
Also pulled a few other things around the car, including the headlights and bumper itself. Looks pretty cool to me actually...the car's nose doesn't look so pointy/flat anymore!
Also, got some of the interior pulled (I ended up pulling the dash and a lot more after the picture was taken). The brown stuff on the floor pan wipes off with a rag+cleaner. No nasty surprises or rust that I've found under the carpet! I'll probably end up leaving the original sound deadening in there...unsure yet...
Another view of the interior...
Here's a view of the rear with the panels taken out. Again..no rust or nasty surprises. You can't see the left and right bank of the trunk area, but there's no rust there either. Relatively clean for its age!
You can see here, the entire sunroof assembly has been removed to ensure this area gets hit with fresh paint and to remove any dirt/grime/surface rust/etc.
The frame is ready for body/paint work and on the trailer to be hauled over to the shop!
Rear view...
Front view...
Other things you didn't get to see removed are the windows, side view mirrors, front fenders, rear bumper, rear diff assembly, gas tanks, EVERYTHING under the car except rear subframe and ebrake cables, every single clip/bolt/plastic piece on the outside, etc. I really don't think it was possible to strip it down further on the exterior (yes, OCD in me!).
Thanks for looking!
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Re: The OKC Project - UPDATED 10/01/10 - Refer to the first post
Postby MWP » Fri Oct 01, 2010 11:43 am
:shock: i would hate to see what this is costing you!!
Postby Meurz » Sat Oct 02, 2010 10:58 pm
Awesome. :D
Turbocelica.nl
Meurz
Postby GT4times2 » Sun Oct 03, 2010 12:27 am
Now that's how You do a strip down for a rebuild. What color are you planning to paint it? These days when it comes to Alltracs, I'm more into restorations along mild engine/suspension mods, than all out hp quests (while neglecting the rest of the car).
I'm keeping an eye out for this thread. Good work so far.
Did you pressure clean/degrease the engine bay btw? Are you going to respray it?
Frantz
12 Toyota Sienna LE
12 Toyota Camry SE
90 ST185 Gen4
88 ST165 Gen3-The works
89 ST165 Gen4-on the way
GT4times2
Postby darthripley » Sun Oct 03, 2010 4:14 pm
GT4times2 wrote:Now that's how You do a strip down for a rebuild. What color are you planning to paint it?
+1 really good prep is one of the biggest keys to a paint job coming out nicely.
we'll have to meet up once you get it painted & going on the road again :)
87 AW11 MR2 "Super 2" 4AGZE
99 SXV20 Camry "Maul" 5SFE
Female Moderator
darthripley
All Trac Goddess
Users browsing this forum: Baidu [Spider] and 3 guests
