Project-Heartbreaker 215/205 mash up
Re: Build ST-185-0004608 (another gen3 swap)
Postby soarer.jzz30 » Wed Apr 23, 2014 10:05 am
Took an led. A spare ecu pin and removed two of the injector pins. Tested both while cranking..... I have pulse... Sir... Fuel pump relay works and drops voltage, but i have to manually ground fpr pin while disconnected to do it.
I took a continuity beeper and checked fc to see if it delivered ground signal while cranking or putting over.. It never did... Tomorrow while residual fuel drains in and i get one good start i will disconnect the sta pin from the ecu so to trick it to turn on FC. This way the COR turns on so the pump will run full time but the ecu wont know its starting so hopefully i get the rpm's needed for the FC to signal.. I have not been able to find any info on what rpm the ecu actually gives thd order to send the fc signal, i need a donor to test this or ask ths community.
Also, i checked spark off of the main lead from the coil and it fired nice and hot very powerful spark indeed. Ive tested compression before and its all 168-170...
What does all this mean... Well, injectors are either clogged or just dont function. I will check resistance tomorrow to see, but i have a feeling they just jave sediment in them. Injector pulse- fuel pump operation - spark- compression -
soarer.jzz30
Postby phattyduck » Wed Apr 23, 2014 4:37 pm
The fuel pump gets full voltage for something like 10 or 15 seconds after a start. Guys that forget to plug in the fuel pump resistor still get a start, but then the engine dies after a short time.
Otherwise, keep up the good work. Frustrating stuff. :doh:
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby soarer.jzz30 » Wed Apr 23, 2014 6:57 pm
You are correct about the fuel pump operation at start, you can hear it click after it stops cranking, i assume that's the sta circuit's doing, the black wire to the COR and sta pin. I would have swore that was from a same circuit as the one that actually fires the starter solenoid but now i think not because the only other way to power the COR is the NE signaled FC. Yeah.
soarer.jzz30
Postby soarer.jzz30 » Fri Apr 25, 2014 1:50 pm
[attachment=-1]uploadfromtaptalk1398437426185.jpg[/attachment]
Side project sneak peak
soarer.jzz30
Postby CTechBlueDragon » Fri Apr 25, 2014 5:51 pm
Nice are you doing LED conversion? I want to do that too, I have to take my cluster out to put in a different resistor so my tach works with my coil conversion.
CTechBlueDragon
Images: 50
Postby soarer.jzz30 » Fri Apr 25, 2014 10:07 pm
The led was already done actually. I just fixed some stuff with it.. And.. If you really look youll see the lit up needle. Very very difficult pita
soarer.jzz30
Postby soarer.jzz30 » Sat Apr 26, 2014 4:39 am
[attachment=-1]uploadfromtaptalk1398490630579.jpg[/attachment][attachment=-1]uploadfromtaptalk1398490652420.jpg[/attachment][attachment=-1]uploadfromtaptalk1398490715933.jpg[/attachment]
It's hard to get the actual light color in a picture on my phone.
soarer.jzz30
Postby soarer.jzz30 » Sat Apr 26, 2014 5:25 am
[attachment=-1]uploadfromtaptalk1398493526861.jpg[/attachment]
soarer.jzz30
Postby CSAlltrac » Mon Apr 28, 2014 12:16 am
Cluster looks phenomenal, good job dude. The illuminated needles make it look 10 years younger.
Postby CMS-GT4 » Mon Apr 28, 2014 1:33 am
That glow is nice.
Postby soarer.jzz30 » Mon Apr 28, 2014 3:21 am
Its not actually that bright, just the camera really picks it up. I went to the junk yard and stripped like eight gauges for needles, i have orange white and these reddish ones. They are a light red but these are from a corolla i think "98 or so. Most of them fit on but some i had to use hot glue and super glue inside the needles to make them press on better. I still say it wasn't worth the time because it was six hours getting it perfect.. Smh, but im glad others appreciate the work. [attachment=-1]uploadfromtaptalk1398658829316.jpg[/attachment][attachment=-1]uploadfromtaptalk1398658848738.jpg[/attachment][attachment=-1]uploadfromtaptalk1398658866833.jpg[/attachment]
soarer.jzz30
Postby gt4lm » Mon Apr 28, 2014 5:14 am
doing well on this one
gt4lm
Postby soarer.jzz30 » Tue Apr 29, 2014 9:22 pm
[attachment=-1]uploadfromtaptalk1398810092494.jpg[/attachment][attachment=-1]uploadfromtaptalk1398810104783.jpg[/attachment][attachment=-1]uploadfromtaptalk1398810114985.jpg[/attachment]
Two sets of plates came in the mail wtf!! Oh well sounds good.
soarer.jzz30
Postby soarer.jzz30 » Thu May 01, 2014 12:50 am
While the car sat between the old engine and the swap.... Ants made a home in my oem fuel rail... New fuel line being fitted this evening... I'm going to say 99.999999% sure that it will start tonight, fuel injector operation confirmed
soarer.jzz30
Postby Chuck.hudson » Thu May 01, 2014 10:27 am
Good luck man I hope it fires up and purrs like a kitten
Chuck.hudson
