project st205 engine swap.
Re: project st205 engine swap.
Postby sMARTINside » Mon Feb 14, 2011 6:22 pm
Here is a link to my Excel files, if you want to modify them or view them in a different way.
http://cid-b87f477dfc4ebc07.office.live ... 05-185.xls
http://cid-b87f477dfc4ebc07.office.live ... %201-5.xls
sMARTINside
Postby sonochevelle » Mon Feb 14, 2011 9:46 pm
sMARTINside wrote:Here is a link to my Excel files, if you want to modify them or view them in a different way.
cool thanks!
brian
st185 All Trac -st205 swap, Berk downpipe, 2 inch lowering springs.
sonochevelle
Postby sonochevelle » Wed Feb 16, 2011 3:24 am
MORE PARTS
water heat exchanger for intercooler
all new motor mounts
new intake gasket
brian
sonochevelle
Postby aus jd 2703 » Wed Feb 16, 2011 5:40 am
hey whered u get the heat exchanger?
where ya gonna mount it? piks when ya get to it
aus jd 2703
Postby sonochevelle » Wed Feb 16, 2011 6:44 am
aus jd 2703 wrote:hey whered u get the heat exchanger?
its an ebay heat exchanger i got for 80 bucks, only thing that sucks is that you have to find fittings for hoses. i plan to mount it infront of the a/c condensor. hopefully it fits.
brian
sonochevelle
Postby sMARTINside » Wed Feb 16, 2011 8:27 am
Where did you get these motor mounts? I need some too.
sMARTINside
Postby sonochevelle » Wed Feb 16, 2011 12:15 pm
sMARTINside wrote:Where did you get these motor mounts? I need some too.
i got the left and right from partznet.com for $180 and i got the front and rears from speed-source
brian
sonochevelle
Re: project st205 engine swap. heat exchanger installed!
Postby sonochevelle » Thu Feb 17, 2011 10:52 pm
removed the bumper and mounted the heat exchanger with some garage door opener hanger/straps to the bumper support.
with bumper off
with bumper on
brian
sonochevelle
Postby krogers128 » Sat Feb 19, 2011 8:01 pm
where did you get the manifold gasket? i didn't replace mine when i had it off, but i could probably use a new one anyways... i'm doing the same swap but in an st165.
1989 Toyota Celica GT: SOLD
1988 Celica All-trac JDM st205 swap: (project)
krogers128
Postby sonochevelle » Sat Feb 19, 2011 9:18 pm
krogers128 wrote:where did you get the manifold gasket? i didn't replace mine when i had it off, but i could probably use a new one anyways... i'm doing the same swap but in an st165.
i got it from a dealer. they said it was the only one in the U.S. but idk how accurate that is.
brian
sonochevelle
Postby krogers128 » Fri Feb 25, 2011 3:25 am
whats the reason for the heat exchanger? thogught about getting one on before for my st205 swap. as well as a new radiator..
krogers128
Postby sonochevelle » Fri Feb 25, 2011 3:42 am
krogers128 wrote:whats the reason for the heat exchanger? thogught about getting one on before for my st205 swap. as well as a new radiator..
its for the intercooler i didnt get one when i purchased my engine plus its kindof an upgrade from the factory one
brian
sonochevelle
Postby krogers128 » Fri Feb 25, 2011 4:01 am
oh i see so yours didnt come with the top mount, makes sense lol
krogers128
Postby sonochevelle » Fri Feb 25, 2011 4:23 am
krogers128 wrote:oh i see so yours didnt come with the top mount, makes sense lol
the intercooler is still mounted on top
its a water to air intercooler. the hot compressed air is cooled by water, and the heated water is pumped to the heat exchanger to be cooled by air
brian
sonochevelle
Postby sonochevelle » Tue Mar 08, 2011 12:10 am
today was very eventful! lol
i drilled and tapped the coolant housing for the 3rd coolant temp sensor.
routed the wiring harness.
remounted the heat exchanger b/c i didnt like how low it would be to the ground, i did this by notching out the bumper support from the backside with a plasma cutter and welded in supports.
installed the intake manifold
installed berk downpipe.
installed 2" lowering springs on front struts (didnt feel like taking apart the rear suspension yet..)
installed new WIX fuel filter
swapped the fitting on the power steering pump
and i ordered new front cv shafts.
brian
sonochevelle
Users browsing this forum: Google [Bot] and 4 guests
