sMARTINside - New Wheels
Re: sMARTINside - Front Axle replaced, received Midpipe
Postby sMARTINside » Fri Nov 18, 2011 8:41 am
Good, so I won't worry for the stiff joint.
Yes, the brand new hub looks so nice, at 220$, it is better to look good!
ABS is gone and won't come back! With the Wilwood adjustable proportioning valve, I love how the brakes are distributed. :lol: Why do you think I would put it back?
sMARTINside
Postby sMARTINside » Sat Nov 19, 2011 12:55 am
I fitted the axle back and the vibration is still there. I will have to dig deeper into it, when I get the chance.
The midpipe is now installed.
I cleaned the weldings using pickling paste (nitric acid) and a scotchbrite:
BEFORE:
AFTER:
Here is a comparison between the stock midpipe and the Trackforged one:
The pipe is passing close everywhere, but it doesn't touch!
I went for a ride and I have to say that I feel a little more power, especially at low RPM. The sound is rich and deep. It sounds more massive at idle.
My car is now having a burnt smell. I guess that driving it in the next days will help to get the pipe hot and stop smelling.
Thanks to Terracar and sentraman for starting this groupbuy and thanks to Trackforged to make a 3'' midpipe that is easy to install and doesn't hit anywhere.
sMARTINside
Re: sMARTINside - Last drive before winter storage
Postby sMARTINside » Thu Dec 01, 2011 8:03 pm
Yesterday I brought my Alltrac to the place where I store it for winter. I am always sad to be apart from that car. In my mind, this car would be the best one around to pass through winter easily, but because I want it to preserve its shape, I take it away from this insane snow and salt that our roads get in winter.
This year was the year where my Celica had the most work done to it. ST205 swap, new brake lines and proportioning valve, new steering wheel, etc... Hope in this car grew up a lot in me. I love it more and more. I also got injured pretty bad, working on it.
Yesterday was my last drive with the car for this year. I enjoyed it and my girlfriend took videos of it so I could listen to its new sound when I get thoughtful about the Alltrac during the next months.
You can listen to it too!
A little acceleration:
Idle sound:
Giving it some throttle on neutral:
sMARTINside
Re: sMARTINside - Restoring the rear end - Torsen surprise
Postby sMARTINside » Sat Mar 17, 2012 9:32 am
Here are a few news. I have taken out the rear subframe to change the suspension, differential and subframe bushings. I took my stock differential apart and was pleased to see that it was a Torsen unit. I always had in mind that my rear differential was open. So I had bought a Torsen LSD from a member here. So, now I have a spare Torsen rear diff. That was a fun surprise that explains why my Celica had such a good control over drifting in snow or dirt.
I also put down the gaz tank to swap it over with a brand new one that I bought from BoostedBlueToyotas on this forum.
When I get some pictures, I will shoot them, here.
sMARTINside
Re: sMARTINside - Restoring the rear end - Subframe ready
Postby sMARTINside » Fri Mar 30, 2012 6:00 pm
Here is where I am in restoring the rear end of the car:
sMARTINside
Postby toayoztan » Sat Mar 31, 2012 3:27 am
what are you going to replace the bushings with?
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby sMARTINside » Sat Mar 31, 2012 9:14 am
I am replacing them with the Super Pro Polyurethane bushings. I already had changed 8 of them, because when I bought the car, the rear end would swing from left to right when driving in a straight line. There were still 4 other bushings to change (Toe adjustment and front trailing arm. Almost all of the bolts holding them are rust welded to the inner metal tube so they have to be cut to be taken out. I take my time and do one thing at a time...
sMARTINside
Postby sMARTINside » Tue Apr 10, 2012 11:38 am
So I got a brand new OEM gaz tank from BoostedBlueToyotas, on the board. I swapped the filler tube, the pump the vent and the level sender from the old rusty leaking tank. I broke and brushed the rust from the flanges and painted them. Then I installed them back with brand new gaskets. 1 funny fact is that you can get all the new gaskets from Toyota, BUT not the one for the fuel level sender as it comes in one kit with the sender. So I made myself a gasket with a sheet of gasket stuff.
I also had to reinforce the straps, as they were getting weaker in certain spots and all the supports for the gaz tank protector were getting weak or were already ripped off by rust. So I made myself some U's in sheet metal that I welded a nut inside them to replace them all. I welded them to the straps. Then, I painted them black, like the rest.
Here are some pics of the tank, ready to install.
I had to weld a couple plates to reinforce some weak spot on the chassis.
Being there, I decided to brush the underbody to remove the rust and paint it, to make it last longer. I thought it was the right moment for this, having the subframe and fuel tank out.
The subframe:
So today, I will put some rust treatment oil on the underbody and put back the subframe and fuel tank.
sMARTINside
Re: sMARTINside's ST185 - Coming back to life
Postby sMARTINside » Thu Apr 12, 2012 7:41 am
So a little update:
The subframe is in the car:
And the fuel tank too:
Now I have prepared the rear knuckles. I had one bad wheel bearing in the back that I didn't really suspect from being bad, so I changed both, being there.
sMARTINside
Postby Terracar » Wed Apr 18, 2012 3:32 pm
Nice work. Inspirational.
-Terracar
Terracar
Postby sMARTINside » Thu Apr 19, 2012 5:33 pm
Thanks a lot. With a lot of effort and money, this project will go where I always dreamed it would.
Now I am replacing the front passenger side wheel bearing for a brand new one. I had a weird vibration since last year, and now I think I have spotted the problem. After all, I have changed 3 of the wheel bearings already (Toyota Genuine $$$). My two front hubs where ground down by the inner race. I have replaced the two front CV Shafts (they gave me some with M22 Threads, so hopefully, they will be tougher). The car is getting in a much better shape than before. Tonite, I will have changed all wheel bearings, so it should roll very smooth. I will keep you updated.
sMARTINside
Postby sMARTINside » Fri Apr 20, 2012 7:36 am
Update: I replaced my last wheel bearing yesterday afternoon and it fixed vibration issue. I double checked that ALL my axle nuts were well tightened. Instead of 137 lb-ft, like the BGB says, I tightened them to 150 ft-lb on dry threads, to make sure that they don't slack off.
I am so happy, the car seems to run so smooth. I feel that there is a lot less rolling resistance than before. I think I will be able to use this car to go in my vacation trip, this year. It feels reliable enough.
sMARTINside
Postby Terracar » Fri Apr 20, 2012 12:36 pm
Glad to hear it. So out of curiousity, where did you get the replacement axles? I replaced both mine with aftermarket since Toyota no longer makes/sells the front axles. I now have an annoying leak that I can't fix lol. Just asking for future reference since I still need to get Demon fixed lol.
-Terracar
Terracar
Postby toayoztan » Fri Apr 20, 2012 3:03 pm
Should be able to get replacements at Napa or just have a shop rebuild them.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby sMARTINside » Fri Apr 20, 2012 5:24 pm
That is where I got mine, at Napa. They are rebuit Cardone axles. The second one that I received was brand new, not rebuilt, so it might be new or rebuilt.
sMARTINside
