The Gen 3.5 swap
Re: The Gen 3.5 swap
Postby l0ch0w » Sun Feb 17, 2013 4:16 am
Subframe is in, installed a new hood latch cable, cleaned up the e-brake cables, reinstalled a few bits on the fire-wall, bought a whiteline rear sway bar, a new A/C condenser, and my new coils (yes 4 of them) came in (pictured below)
Andrew
1991 Red Alltrac
l0ch0w
Postby l0ch0w » Mon Feb 25, 2013 9:36 pm
PS Pump Rebuilt!
More pictures tonight, I have fixed my engine mount dilemma. Rear end is about complete, two of the spherical bushings when I was freezing/heating them in didn't go in all the way, so I'm searching for an appropriate sized press to finish putting them in before I can finish. Anyone got any good ideas? I really don't wanna dig through Toyota SPX to spend $150 for a stupid spherical bushing press...
Andrew
1991 Red Alltrac
l0ch0w
Postby Meenya » Wed Feb 27, 2013 1:07 am
l0ch0w wrote:PS Pump Rebuilt!
This link http://www.planetcampbell.us/SphericalBearingReplacement.html has some good notes and tips. One of those days I'll be doing it myself.
Mike
93 Turbo 4WD
91 GTFour RC
07 R6
Meenya
Images: 19
Postby l0ch0w » Wed Feb 27, 2013 2:13 am
I tore up one bearing already trying it that way and had to buy another, turns out that sockets have a nice little tendancy to slip and tear the rubber boot. I may head to ACE hardware tomorrow to try and find a better fitting socket, but my hopes arent high.
Andrew
1991 Red Alltrac
l0ch0w
Postby phattyduck » Wed Feb 27, 2013 4:49 pm
I believe I used a 3-jaw puller instead of the 2-jaw one, which keeps things in line much better. Good luck!
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby l0ch0w » Wed Feb 27, 2013 5:11 pm
Yep, 3 Jaw also, Ive just got to find a socket i guess that doesnt tear them up. I got 2 of the 4 in all the way by heating up the spindle and freezing the spherical bearing then tapping them in. Worked like a charm except I wasnt fast enough with two of them...
Andrew
1991 Red Alltrac
l0ch0w
Postby l0ch0w » Wed Feb 27, 2013 6:19 pm
Relocating the PS reservoir too... not sure why they didnt put it here from the start tbh... I have to make an ACE hardware run for some sheet metal screws to attach it... hence the duct tape.
Andrew
1991 Red Alltrac
l0ch0w
Postby l0ch0w » Tue Mar 05, 2013 2:50 am
Dodged a huge bullet....
Andrew
1991 Red Alltrac
l0ch0w
Postby 801Alltrac » Tue Mar 05, 2013 3:39 am
:shock: WTF !
801Alltrac
Images: 13
Postby toayoztan » Tue Mar 05, 2013 3:40 am
Yikes, that would definitely be scary!
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby l0ch0w » Tue Mar 05, 2013 6:33 am
Turns out we had the springs replaced two years ago and the retard installing them put in two that were mismatched and the wrong strength. It wore out the door unevenly as well as overworked the lifting mechanism. A few months back the lift motor broke, we replaced it, then this happened...
Andrew
1991 Red Alltrac
l0ch0w
Postby BADNEWS » Tue Mar 05, 2013 11:21 am
I can just imagine what was being said right after that happen. And it's not PG rated.
865AWHP, 591 torque
BADNEWS
Postby GT4_DRED » Tue Mar 05, 2013 11:48 am
l0ch0w wrote:I tore up one bearing already trying it that way and had to buy another, turns out that sockets have a nice little tendancy to slip and tear the rubber boot. I may head to ACE hardware tomorrow to try and find a better fitting socket, but my hopes arent high.
Maybe an impact socket, which without the plating is less likely to slip; maybe even cut the end off so it sits flat? Appropriate sized Shed-10 pipe? The picture in the link looks like the socket could possibly rotate as the puller is being tightened. I shaped and center punched some 1/4" steel stock to sit over the hole and apply pressure to that. Just some thoughts of the top of my head.
'88 ST165 - project "Rahtid"
'91 MR2
GT4_DRED
Postby l0ch0w » Tue Mar 05, 2013 7:56 pm
I got it figured out... A 1 1/16th 12 point socket fits best...
Plus I figured out how to remove and install the rubber bush without damaging it...
Andrew
1991 Red Alltrac
l0ch0w
Postby GT4_DRED » Tue Mar 05, 2013 8:53 pm
l0ch0w wrote:I got it figured out... A 1 1/16th 12 point socket fits best...
Cool.. Did you ever get a chance to finish the pwr steering reservoir? Curious to see how it came out as I'm trying to figure out a solution for the 165s as well.
'91 MR2
GT4_DRED
