The Gen 3.5 swap
Re: The Gen 3.5 swap
Postby CMS-GT4 » Thu May 30, 2013 1:41 am
Looking good. I'll be referencing this thread if I ever pull my engine out again.
Postby l0ch0w » Thu May 30, 2013 2:07 am
Corey Darling wrote:Fantastic work!
Looks great. Which brand of CF hood do you have? Looks like it uses the OEM trim piece?
Its a VIS hood, fitment is pretty good, the gaps arent as nice as I would like, but its about as good as it gets for CF since it flexes quite a bit... Also still need to get the hood pins. It does not latch all the way down because the catch hook is not quite long enough... The center section is removable just like the OEM hood as is the rear hood spoiler, but the side vents are non-removable.
CMS-GT4 wrote:Looking good. I'll be referencing this thread if I ever pull my engine out again.
Speaking of dropping in... I found the easiest method by far...
I set the motor/trans on a pair of wheel dollies I had. Put the rear wheels on some ramps and the front end on jack stands. Then, I lifted the whole front end of the car with the engine lift attached at the front bumper support bolts, about 4 feet up. Rolled the engine under the car through the wheel wells (front suspension removed), set the car back down on jack stands over the motor, and then lifted the motor up through the engine bay. It was super painless, cant recommend the method enough after having cherry-picked this motor ~5 times. Even did it with the garage door up and it didn't interfere because I never had to lift the crane that high. I know it sounds like more work, but if you are taking out your engine, remove the front suspension (a-arms and spindles) and drive shaft, the extra bit of work saves hours of headache and busted knuckles. Oh, and air tools are a plus too...
Andrew
1991 Red Alltrac
l0ch0w
Postby jaydog82 » Fri Aug 09, 2013 3:39 am
Yup that is the best way of installing the motor. Way easier
jaydog82
Postby 801Alltrac » Thu Aug 22, 2013 4:14 am
Very nice love the white IC
I think I'm going to do a 3gen swap myself
Great work keep on keepn on
801Alltrac
Images: 13
Postby l0ch0w » Mon Mar 10, 2014 4:04 am
Sorry Ive been out so long. Stuck in Afghanistan... Anyway, Build will likely resume Jan 2015 :)
Andrew
1991 Red Alltrac
l0ch0w
Postby Dan McBoost » Fri May 15, 2015 3:12 am
So very pretty! Love the attention to detail! White IC is a great idea on the red car.
Dan McBoost
McBoost.comMA70.COMFB: DanMcBoost
Dan McBoost
Postby l0ch0w » Mon Aug 24, 2015 3:13 pm
Still in a holding pattern...
School, then heading to Germany. Then buying a house... Best estimate on resuming the build will be Spring of 2017. :(
Andrew
1991 Red Alltrac
l0ch0w
Postby 2of81 » Fri Apr 01, 2016 2:26 pm
You're about as bad as me. I swear this spring I'm gonna dive back into my All-Trac.
Justin
1972 Corolla TE27
2of81
Users browsing this forum: Baidu [Spider] and 5 guests
