ATX CS.
Re: ATX CS.
Postby CSAlltrac » Sat Jul 09, 2016 2:06 am
88st165 wrote:
CSAlltrac wrote:
Currently only have EBC Yellow stuff in stock brakes. They are next on the list, once I have confidence with my brakes I'm guessing I'll be a couple seconds quicker. The brakes are THE biggest weakness on track, stock brakes suck ass.
Darn that sucks to hear the stock ones aren't even the slightest bit ok haha. My plan was to "upgrade" my 165 brakes to the 185 setup and run carbotech xp12/10 and hopefully that would work for a while. I wouldn't be happy if I burned up $400 worth of pads in a single track day. I run on a local track that is known for being one of the worst on brakes. Looking forward to what you decide for brakes.
Im going with the Porsche setup with STI front rotors, already have the brackets. Then ST205 rears, havent decided on pads yet since Ill actually have options.
Re: ATX CS.
Postby CSAlltrac » Wed Sep 28, 2016 2:22 am
Pretty big update for the car, finally hustled up enough to get my brakes. I had a lot of ideas of what direction I wanted to go but in the end I wanted a bolt on kit that was offered off shelf. Really did not like that all DIY options had some flaw. Anyways, went with K-Sport and do NOT regret it one bit. Went with the 14" kit with 8 pot calipers in Black. Wanted a color that wouldn't change after being baked at the F1 Curcuit. Their kits are all forged one piece calipers now with two piece rotors. Went with the race pad option so now the car makes awesome school bus sounds. Initial impression is "HOLY FU**" I have yet to track them but will in December. Petal is a bit softer but has insane power now. All my wheels fit thank god but I did have to pull off all the wheel weights, there's about a credit cards clearance. Onto the photos!
Re: ATX CS.
Postby underscore » Wed Sep 28, 2016 4:11 am
Those are beautiful! How much did they run if you don't mind me asking?
Re: ATX CS.
Postby FC Zach » Wed Sep 28, 2016 6:10 am
Very nice!
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Re: ATX CS.
Postby pintoBC_3sgte » Wed Sep 28, 2016 7:46 am
Wow! Looks great!
pintoBC_3sgte
Re: ATX CS.
Postby CSAlltrac » Wed Sep 28, 2016 1:23 pm
underscore wrote:Those are beautiful! How much did they run if you don't mind me asking?
This kit will set you back about $1800. There's a ton of options all of them bigger except one smaller option.
Re: ATX CS.
Postby pintoBC_3sgte » Wed Sep 28, 2016 5:17 pm
Just noticed they're 14"... Lol an inch smaller then my wheels... They must get you to a stop pretty damn quick!
pintoBC_3sgte
Re: ATX CS.
Postby FC Zach » Thu Sep 29, 2016 2:57 am
CSAlltrac wrote:Onto the photos!
May be a dumb question but is that rotor backwards? Edit: by that I mean, is it on the wrong side?
FC Zach
Images: 9
Re: ATX CS.
Postby fussellbug » Fri Oct 28, 2016 6:29 pm
FC Zach wrote:May be a dumb question but is that rotor backwards? Edit: by that I mean, is it on the wrong side?
The direction of the slots on the face of the rotor does not matter for the proper direction of rotation. The internal cooling vanes (between the front and back faces of the rotor) determine the correct direction for rotor rotation.
https://www.zeckhausen.com/catalog/index.php?cPath=6446_6515
fussellbug
Images: 36
Re: ATX CS.
Postby FC Zach » Sat Oct 29, 2016 2:54 am
fussellbug wrote:The internal cooling vanes (between the front and back faces of the rotor) determine the correct direction for rotor rotation.
I knew that was important but never stopped to think that the internal vanes could go opposite direction of the slots/holes
fussellbug wrote:The direction of the slots on the face of the rotor does not matter for the proper direction of rotation.
Noted, thanks!
FC Zach
Images: 9
Re: ATX CS.
Postby FC Zach » Sat Oct 29, 2016 3:02 am
FC Zach wrote:I knew that was important but never stopped to think that the internal vanes could go opposite direction of the slots/holes
With that being said. . I need to double check my rotors LOL :)
FC Zach
Images: 9
Re: ATX CS.
Postby pintoBC_3sgte » Sun Jun 11, 2017 2:37 am
So, anything new with your build?? :)
pintoBC_3sgte
Re: ATX CS.
Postby CSAlltrac » Mon Jul 03, 2017 1:27 pm
So as you can see I am a victim of the photobucket ransom. I do apologize guys, pretty much makes my whole build thread suck. I know Im not the only one that is highly upset.
Re: ATX CS.
Postby CSAlltrac » Mon Dec 04, 2017 9:33 pm
Photo Dump. Also, Screw Photobucket
Re: ATX CS.
Postby GT4times2 » Mon Dec 04, 2017 10:54 pm
Nice pics!! Screw Photobucket!! Which hosting site do you use now?
Frantz
12 Toyota Sienna LE
12 Toyota Camry SE
90 ST185 Gen4
88 ST165 Gen3-The works
89 ST165 Gen4-on the way
GT4times2
