my 88 AllTrac ST165
my 88 AllTrac ST165
Postby jaydog82 » Fri May 27, 2011 3:19 am
here is my build thread
i got this 88 AllTrac for $900, it had a rod knock and outdated tags. the list starts with new motor-clutch-turbo-belts-hoses-gaskets and seals and tons more.
so here is my plan.
drop engine and trans
clean engine bay
drop fuel tank and send it for cleaning
send the injectors to witchhunter.com for cleaning and balance (thanks to joel/not12listen for reminding me
replace engine with a jdm gen 1 from josh at chico raceworks (http://chicoraceworks.com/) and replace turbo also from josh
flush fuel system and replace fuel filter, fuel damp, fuel reg and fuel pump
install new oem water pump timing belt main seals and thermostat
install spec stage 2 clutch kit
replace all belts and hoses
replace ignition parts oem plugs cap and rotor and magnecore wires
reinstall engine and trans
if i have the money install a down pipe
put everything togeather and drive her
install white motiege rims from my GT
stage 2 looks something like this
gen3-4 engine(with built internals and port n polish head with 1 mm over sized valves and maybe s set of cams) and ecu and trans
upgrade diff
t3/t4 turbo
water/meth injection
front mount intercooler with side feed intake
full 3 inch exhaust with electronic cut out
full msd set up
maybe a light weight flywheel and a shaved crank
full tune up the boost and have some fun
jaydog82
Re: my 88 AllTrac ST165
Postby 2of81 » Fri May 27, 2011 3:37 am
Fresh project! Sweet! Looks like you have a good plan going on there. Best of luck to you!
Justin
1972 Corolla TE27
2of81
Postby Rick89GTS » Fri May 27, 2011 5:04 pm
Looking good, welcome :)
Rick89GTS
Postby jaydog82 » Fri May 27, 2011 6:54 pm
Thanks, im looking at putting down between 230hp and 250hp to the wheels.
jaydog82
Postby 88gt4DE » Sun May 29, 2011 2:55 am
jaydog82 wrote:Thanks, im looking at putting down between 230hp and 250hp to the wheels.
Good plan , nice to see a realistic hp goal also ... :wink:
Postby LegacyofDan » Mon May 30, 2011 2:03 am
Welcome! Clean looking trac! :)
friendly FYI...you signature is HUGE...it may be wise to re size it...
Postby jaydog82 » Mon May 30, 2011 2:17 am
thanks, ya i fixed my sig. at the time i was having a problem getting it to work right.
jaydog82
Postby jaydog82 » Sat Jun 04, 2011 1:27 pm
time for an update
speed source engine mount inserts
custom coolant overflow bottle
I also finished changing the grease and boots on the front cv half shafts and i found a shop to re-service my flywheel front and back and spec it out for $65. I also sent out all 5 injectors to whitchhunter.com to have them cleaned-balanced and flow tested.
jaydog82
Postby jaydog82 » Tue Jan 10, 2012 2:08 am
Its alive.
it runs, i have to finish the battery relocation and change a broken strut mount and fix a small coolant leak then reg and tires and ill have her on the road.
http://s469.photobucket.com/albums/rr54/jaydog82celi/?action=view&current=VIDEO0015.mp4
http://s469.photobucket.com/albums/rr54/jaydog82celi/?action=view&current=VIDEO0016.mp4
jaydog82
Postby UtahSleeper » Tue Jan 10, 2012 2:55 am
Glad to here she is alive now. And the white rims look good on red, IMO. Why do you have the heat stuff on the maf?
UtahSleeper
Postby jaydog82 » Tue Jan 10, 2012 3:39 am
for shits and giggles lol
jaydog82
Postby 88gt4DE » Tue Jan 10, 2012 12:44 pm
How did the results of the test run go ? looks great man ... nice work 8)
Postby jaydog82 » Tue Jan 10, 2012 4:46 pm
I have not driven it yet, but I will soon.
jaydog82
Postby monkey8oi » Wed Jan 18, 2012 9:55 pm
nice to see another st165 around in the bay... where are you located? hopefully you'll be at the little meet in san jose in march...
monkey8oi
Postby jaydog82 » Thu Jan 19, 2012 4:04 am
im in Martinez, its by Concord. Ya id like to make it to a meet, its been a while since iv been to one. Is there a thread for that meet?
jaydog82
