my 88 AllTrac ST165
Re: my 88 AllTrac ST165
Postby brutekiller787 » Wed Aug 21, 2013 2:26 am
overdone? because they work and are virtually maintenance free, unlike WTA systems
brutekiller787
Postby jaydog82 » Wed Aug 21, 2013 2:52 am
Overdone as in they are very common, I would rather have something less common and with less piping
jaydog82
Postby brutekiller787 » Wed Aug 21, 2013 12:11 pm
edit: to keep this thread "on topic"
Last edited by brutekiller787 on Fri Aug 23, 2013 4:24 pm, edited 3 times in total.
brutekiller787
Postby underscore » Wed Aug 21, 2013 3:13 pm
edit: deleted to keep this thread on topic.
Postby brutekiller787 » Thu Aug 22, 2013 2:30 pm
Last edited by brutekiller787 on Fri Aug 23, 2013 4:22 pm, edited 2 times in total.
brutekiller787
Postby underscore » Thu Aug 22, 2013 3:13 pm
Postby jaydog82 » Thu Aug 22, 2013 5:55 pm
OK, can you guys move you discussion to a different thread.
Thanks
jaydog82
Postby underscore » Thu Aug 22, 2013 6:07 pm
My apologies, I didn't notice this was a build thread. Posts edited.
Postby jaydog82 » Thu Aug 22, 2013 6:09 pm
Thanks
jaydog82
Postby wakkjobb » Fri Aug 23, 2013 1:35 pm
If you get around to doing a front-mount, check my first build thread (blue car) 'cause I did one using a Saab IC from a 97. Fits really well with super-minimal cutting and I used the stock intake, mainly because I sold the side-feed I had.
Aside from that, adding a slim fan to the WTA's radiator can help a metric ass-ton from what I've seen; anything to help keep these cars cool is a good thing.
Lose the hood. :evil:
How much for one of those fancy braided drain lines?
MFIC at Rainbows and Unicorns Fabwerkz :D
Old build:
http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=27648
New build:
http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=42305
Go-Fast parts:
siliconeintakes.com
wakkjobb
Postby brutekiller787 » Fri Aug 23, 2013 4:21 pm
i was just trying to save you from headaches down the road but ok.
i thought this was the purpose of build threads, not only to show off your own work but to get other people's opinions' on the subject that you post about. if someone told me i was doing something that didn't make sense to them i would want them to post and ask why i am doing such a thing. then i would explain why i am doing it and take their advice into consideration.
i don't consider someone asking why you do a certain thing going off topic but ok i will edit too
if you don't want other people's opinions, don't post on a forum...
brutekiller787
Postby jaydog82 » Fri Aug 23, 2013 8:02 pm
Wakkjobb: I am already running two st165 heat exchangers with a 7 " fan and the constant run mod. I can have the oil drain lines made for around $130.00 plus your hard line and oil pan fitting as cores.
jaydog82
Postby jaydog82 » Fri Aug 23, 2013 8:05 pm
Brutekiller787: I welcome other peoples input, I just don't want a full blown debate on my build thread, at some point I may go ata, but for now and the seeable future I will be using WTA.
jaydog82
Postby jaydog82 » Thu Sep 12, 2013 1:07 am
I cleaned up my engine bay this week, also finally got my egt sensor probe installed in my exhaust manifold.
jaydog82
Postby jaydog82 » Wed Nov 06, 2013 3:14 am
Installed a ss braided Teflon turbo oil feed and return line.
jaydog82
