My 90 alltrac project ( being parted out )
Re: My 90 alltrac project goals
Postby Tecker185 » Sat Apr 20, 2013 12:53 am
89 ST165
89 SV25
86 AW11 2zzge swapped
86 AE86 1uz swap
89 AE95 sedan
89 AW11 Supercharged
17 4runner TRD Off Road
Tecker185
Postby underscore » Sat Apr 20, 2013 12:53 am
You've got a 25mm/4.1% difference in size, assuming the treads were similar. I wouldn't be driving it like that.
http://www.rimsntires.com/specs.jsp
Postby celigts » Sat Apr 20, 2013 3:42 pm
What kind of damage can I do driving like this?
3SGTE project motor very slow
celigts
Postby celicast184 » Sat Apr 20, 2013 7:35 pm
it messes up your Viscous Coupling unit in the trans!! the front wheels are gonna spin at different speeds then the rear, causing your VC in the trans to transfer power unevenly and messing it up.
I <3 MY ST214
celicast184
Postby underscore » Sat Apr 20, 2013 10:04 pm
Yeah you'll cook the VC
Postby celigts » Sun Apr 21, 2013 1:44 am
f***. How long think it would last. Had family supper about 2hrs away and don't have another vehicle. Or for work. Had no spare tires to use but these and no money for tires or the rims till next weekend....
celigts
Postby underscore » Sun Apr 21, 2013 1:47 am
Not very long? No clue.
Postby celigts » Sun Apr 21, 2013 2:12 am
Well I've been keeping rpms under 3k and speed between 80-90km
celigts
Postby underscore » Sun Apr 21, 2013 3:21 am
rpm won't matter, speed will though.
Postby celigts » Sun Apr 21, 2013 11:12 pm
My installed parts this besides the ko racing dp. Just waiting for it to arrive.
Interior::
Momo D shape steering wheel
SOLD - Unknown wheel hub
SOLD - Sparco Star reclinable seats on custom rails
SOLD - Dual gauge pillar pod with Aem digital wideband, boost gauge
SOLD - Aem digital water temp gauge
Autometer phantom oil pressure gauge
A/c deleted
Audio deleted
Rear strut bar
Engine::
Custom intake with Aem dryair filter
SOLD - Hks ssqv modified with dual springs
Custom oil pressure sender relocation
SOLD Hks MBC
SOLD - Asi 56mm dual core aluminum rad with 12" thin fans on personal switch
2.5" KOracing downpipe
2.5" custom cat back exhaust to apexiN1 2.5" muffler (no cat tho)
Speedsource poly front and rear motor mounts
Custom Acetal/derlin rear subframe bushings and solid aluminum diff mount made by xiiimotorsports
GT4racing full poly suspension bushings set
Wheels::
Enkei RP01 16x8 +38 offset on 205/45 tires
PENDING - Front has 8mm universal slide on wheel spacer
PENDING - Rear has 25mm bolt on wheel spacer
celigts
Postby phattyduck » Mon Apr 22, 2013 6:33 pm
underscore wrote:Not very long? No clue.
I wouldn't drive with that tire combination more than around a parking lot.
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby celigts » Mon Apr 22, 2013 6:54 pm
Yea it's been... 6hrs on the tires now. Buddy let me take the last 2 rims from him but doesn't help when the local shop won't cut me a break till Friday...
celigts
Postby underscore » Mon Apr 22, 2013 11:42 pm
I'm paranoid as hell about my car, I've already decided I'd only use off size tires to roll onto a flatbed.
Postby celigts » Tue Apr 23, 2013 3:39 pm
Well I got some tires for the front. Both different types but Atleast they are all the same sizes. Car pulls funny now and I'm more sure it's the tires being different then the VC toast. I don't know for sure tho.
celigts
Postby celigts » Sat Apr 27, 2013 1:41 am
KO Dp here
and xiiimotorsports decal ;)
celigts
Users browsing this forum: Ollielawsac and 2 guests
