My 90 alltrac project ( being parted out )
Re: My 90 alltrac project ( being parted out )
Postby celigts » Sat Apr 27, 2013 6:25 pm
Yea so I hope this is just the valve cover gasket being a whore cuz I REALLY! Can't afford more car problems right now.
3SGTE project motor very slow
celigts
Re: My 90 alltrac project goals
Postby celigts » Sat Apr 27, 2013 9:51 pm
celigts
Postby toayoztan » Mon Apr 29, 2013 4:56 pm
Looks to be so, if you have oil where the socket goes. Can you see if there is oil down in the spark plug chamber?
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby celigts » Mon Apr 29, 2013 9:26 pm
toayoztan wrote:Looks to be so, if you have oil where the socket goes. Can you see if there is oil down in the spark plug chamber?
Bryan
There was. The boot was soaked in it. Changed the valve cover gasket and no difference in idle tone. I'm going to throw half a bottle of sea foam in the gas today and then next fill ill add the rest.
celigts
Postby ALLensTRAC » Tue Apr 30, 2013 12:00 am
You will need to replace all the plug wires that got soaked with oil as well. If they are swelled compared to the boots that didn't get soaked in oil they can cause spark loss from arcing. Also check your plugs for cracks in the porcelain as this can cause spark loss as well.
Allen
ALLensTRAC
Postby celigts » Tue Apr 30, 2013 12:15 am
Don't think there is cracks but I can almost promise the plug boots ARE swelled. Replacement boots easy to get?
Added the sea foam and was gonna get plugs but Canadian tire only carries champion apparently.
celigts
Postby celigts » Tue Apr 30, 2013 12:16 am
celigts
Postby celigts » Wed May 01, 2013 12:00 am
Put new plugs in today. Exhaust is back to normal :) ordering the replacement parts for the distributor anyways as its leaking so it's needed.
celigts
Postby celigts » Wed May 01, 2013 10:31 pm
Made a battery bracket for the relocated battery. It's in a shitty spot right now and needs a better ground anyways. This weekends job unless its nicer. Winter doesn't want to go away! Gr!
celigts
Postby celigts » Mon May 06, 2013 4:20 pm
Washed the car and cut the bumper since it was falling into pieces anyways. Should be ok for fmic. But it'll be better once I get the cs bumper. SOON! This summer underscore. This summer ill order it!
celigts
Postby celigts » Mon May 06, 2013 4:21 pm
celigts
Postby underscore » Mon May 06, 2013 7:37 pm
celigts wrote:Washed the car and cut the bumper since it was falling into pieces anyways. Should be ok for fmic. But it'll be better once I get the cs bumper. SOON! This summer underscore. This summer ill order it!
Haha sounds good man, that cooler would look awesome behind a CS bumper.
Postby celigts » Mon May 06, 2013 8:29 pm
I believe it will :) love how it goes back to the inlet side. Or vise versa.
Ordered my helicoil kit. M10x1.25 is the size for the exhaust manifold studs right?
celigts
Postby celigts » Mon May 06, 2013 11:58 pm
Fml. Found more rust. The previous owner when they relocated the battery did a HORRIBLE job. They sprayed some rubbery foam and slapped MDF over it then screwed the battery box to that. Since I made my new bracket and today moved it half ass just to have it moved I found more rust. Great... This is more then a project I think. It's a restoration without a finish in sight. :/
celigts
Postby celigts » Sun May 12, 2013 3:29 am
Picked up some tires I ordered today and some exhaust gaskets.
celigts
