1988 Alltrac st165 leaking coolant head gasket?
Re: 1988 Alltrac st165 project/cleanup
Postby 801Alltrac » Fri Aug 24, 2012 4:07 am
that looks good in the grill, hope my t pipe doesnt do that :D
801Alltrac
Images: 13
Postby Redrkt01 » Fri Aug 24, 2012 6:41 pm
Anoo21 wrote:Went to the junkyard to find some parts but found them sweet camry all-trac emblem :) so decided to get it and going to put it on my front grill like the jdm gt fours but it will say all trac :)
Want to do the emblem just like this jdm gt-four but with the all-trac emblem it is gonna look nice :)
It's a real GT-Four from Australia. I think the guy still owns it. Although I cant remember his name he should be found at Toymods.
1989 ST162
1988 ST165 Black
1988 ST165 Red Parts Car
Redrkt01
Postby Anoo21 » Mon Aug 27, 2012 2:41 am
Thats awesome. I love that 165 i wish mine was that clean and RHD lol
Anoo21
Re: 1988 Alltrac st165 project/cleanup (Won't start)
Postby Anoo21 » Thu Dec 27, 2012 9:59 pm
Good and Bad news.
Good: Whiteline front strut bar and new rear subframe bushings(not yet installed)
Bad: Mad power steering leak, turbo oil line leak(i think so), Squeaky pulley, Starter went out on me(while on a date :shoots: )
Anoo21
Postby Anoo21 » Fri Jan 25, 2013 3:40 am
Got Klues rear subframe mounts and bushings and had a day off so i decided to pull my rear subframe and take the old 25 year old rubber ones out and put the nice shiny new ones in. Took about 8 hours by myself, I took it at a steady pace and got it done quicker and easier then I thought 8) . I could not POR 15 the subframe because the All-Trac is my daily. I PRESOAKED EVERYTHING IN WD-40 FOR 24 HOURS. I think this helped me out a bit.
Main Tools:
2 Floor jacks
2 Jack stands
Breaker bar
WD-40
Torch
Impact and sockets
Hammer
Grease
Did not know there was an "extra" bracket for the front subframe bolts/mounts
Subframe is OUT
Bushings are out. I burnt out the middle and then just hammered the outer ring out. Was rather easy after doing the first one.
Old bushings out and broken
New Bushings in :D
Everything is back together and picture of the new rear diff mount.
Any questions just let me know. I have not driven it around yet was getting a little late. I will let you guys know how she handles.
Anoo21
Postby 88gt4DE » Fri Jan 25, 2013 1:31 pm
I like those ... Nice work ... thats on my long list of " to do's " 8)
Postby Anoo21 » Fri Jan 25, 2013 3:25 pm
Thanks, it was on my to do list since I purchased the car in 2011. :lol: Now I can shift or downshift without hearing and feeling a huge clunk in the rear of my car.
Anoo21
Clutch :/
Postby Anoo21 » Fri May 17, 2013 2:01 pm
I will let the pictures do the talking but did the clutch and some other things while the engine was out. Took about 15 hours total over a course of a few days ( had to work) Was not as bad as I thought. I did a lot of reading the past year to get ready for this haha.
Some parts and gaskets
Dropped the engine/trans
During
Out
Old clutch :/
Back on the road rolling with ted
Anoo21
Re: 1988 Alltrac st165 much needed clutch job :/
Postby Awesome-Trac » Fri May 17, 2013 3:53 pm
How long did it take you to do the whole thing?
•Daniel
Awesome-Trac
Postby Anoo21 » Fri May 17, 2013 6:36 pm
Awesome-Trac wrote:How long did it take you to do the whole thing?
3 days about 5 hours a day, total 15 hours. Could have gone faster but I wanted to do everything right so i took things at a steady pace.
Day 1 disconnect everything and drop the engine/trans out
Day 2 Disassemble the engine and trans and do the clutch and clean and gaskets
Day 3 Put the engine back and finalize everything
Anoo21
Postby Awesome-Trac » Fri May 17, 2013 7:08 pm
Man as much as I want to attempt this kind of job again I know I'll end up taking months just to remove the trans
•Daniel
Awesome-Trac
Postby Anoo21 » Sat May 18, 2013 12:33 am
Awesome-Trac wrote:Man as much as I want to attempt this kind of job again I know I'll end up taking months just to remove the trans
Honestly it took almost 2 years for me to finally do the job. The car was running just slipped under boost and after a while I really want to boost again.
Anoo21
Postby Anoo21 » Sun Aug 04, 2013 2:17 pm
Well sad day, found a major coolant leak coming from the timing belt side so i am guessing it is the water pump. On top of that, hearing a loud tick coming from the head by cyl. 1. :cry: Still haven't fixed the oil leak either which I am pretty sure is from the oil cooler and oil filter bracket now. Car is sitting and I am really contemplating a 3rd gen swap, what do you guys think?
Anoo21
Re: 1988 Alltrac st165 leaks galore, in need of st205 swap
Postby 88gt4DE » Sun Aug 04, 2013 2:50 pm
Didn't you just have motor out ? I'd investigate first ... water pump and front seals isn't a reason to give up quite yet ... Get that valve cover off and check out that tick. Run low on oil ?
Postby Anoo21 » Mon Aug 05, 2013 2:13 am
88gt4DE wrote:Didn't you just have motor out ? I'd investigate first ... water pump and front seals isn't a reason to give up quite yet ... Get that valve cover off and check out that tick. Run low on oil ?
yeah I apologize for my previous post, I was just a bit angry. All-Tracs it is a love :oops: hate :shoots: relationship lol I am going to be ordering the water pump and fixing the oil leak. Hopefully for a while she will stop throwing her fits. gives me a headache :doh:
Anoo21
