zaluss":1mz0qekb said:Yes. Sadly I couldn't find someone to reproduce the dealer graphics to keep them. Next weekend is driver side cv and control arm sleeve that's torn. End of the month is rear main seal that's leaking badly.
88gt4DE":29wh1zaa said:zaluss":29wh1zaa said:Yes. Sadly I couldn't find someone to reproduce the dealer graphics to keep them. Next weekend is driver side cv and control arm sleeve that's torn. End of the month is rear main seal that's leaking badly.
Theres a guy on this website that reproduces all those decals and graphics ...
That's a normal 3s-fe auto thing... its deccel fuel cut turning on and off.zaluss":33sqsnau said:I took a quick video of the jumpy RPM issue i've been getting.
http://youtu.be/MrTPyeDOXps
You can see between 30-35mph when I let go of the throttle the RPM bounces around 1k and I can feel it jerking the car back and fourth. This happened after I replaced my cracked radiator.
phattyduck":lr18xwur said:That's a normal 3s-fe auto thing... its deccel fuel cut turning on and off.zaluss":lr18xwur said:I took a quick video of the jumpy RPM issue i've been getting.
First, the EGR temp code normally means you have a plugged EGR tube or a non-working actuator - its probably unrelated to the surging you are seeing (though it would be good to fix the issue).zaluss":3mc6br5n said:Could you explain this a bit further? I've never experienced this issue before. I'm getting an EGR low temp code (71) also so I'm wondering if its a vacuum problem at low speed.
Stupid question - did you plug the EGR temp sensor back in?zaluss":vfc661li said:Interesting. Unlikely a plugged egr as I cleaned and tested it a few thousand miles back. Maybe the actuator or a malfunctioning vacuum.
Thanks again.
