Awesome Project ST165
Re: PROJECT "DARK KUMA" Custom Privacy Hatch
Postby 88gt4DE » Thu Nov 08, 2012 11:27 am
Holy crap that came out nice !!! Please do tell what you used to make it !! I need to make a new one. Have one but its a little busted up ... BTW ... good looking car and yer girl is a keeper !!! I got one just like her :D
Postby jaydog82 » Thu Nov 08, 2012 4:08 pm
I may need to copy that, while adding 2 speakers.
jaydog82
Re: PROJECT
Postby Awesome-Trac » Thu Nov 08, 2012 11:02 pm
jaydog82 wrote:I may need to copy that, while adding 2 speakers.
Yeah if we have another meet you can check it out
•Daniel
Awesome-Trac
Postby Awesome-Trac » Thu Nov 08, 2012 11:06 pm
88gt4DE wrote:Holy crap that came out nice !!! Please do tell what you used to make it !! I need to make a new one. Have one but its a little busted up ... BTW ... good looking car and yer girl is a keeper !!! I got one just like her :D
Thank you, surprizingly I used the spare tire cover from a 2010 Nissan versa but a cover from a 09 corolla works well to. Btw took the car out for a spin seeing how it's raining in Cali and all the noise I use to hear is gone so overall a success
•Daniel
Awesome-Trac
Postby Overtriped » Fri Nov 09, 2012 1:12 am
Nice gt4... Did the TRD shocks come on it or did you purchase them seperatly?
90 ST185~205
04 Tundra V6 5spd 2wd
TOYOTA JUNKIE
Overtriped
Postby Awesome-Trac » Fri Nov 09, 2012 1:34 am
Thank you sir, they came with the car when I bought it
•Daniel
Awesome-Trac
Re: PROJECT AWESOME
Postby Awesome-Trac » Tue Mar 26, 2013 7:19 pm
UPDATE: so this week I have some time to kill plus I get my celica GTS back :D which leaves me time to pull apart the Trac. On my to-do list is to clean up all the oil covering the bottom end of the engine so I can further diagnosis the oil leak problem and repair, second add the WORK Emotion CR Kai that's just been sitting in storage for about two months now and third install Apexi Turbo timer, HKS blow off valve then find a good manual boost controller so overall this week will be nothing but work and Alltrac dedication
•Daniel
Awesome-Trac
Re: PROJECT AWESOME
Postby jaydog82 » Wed Mar 27, 2013 3:46 am
i just installed an apexi ebay turbo timer, hit me up for the wire colors. get a boost valve brand mbc.
jaydog82
Re: PROJECT AWESOME
Postby Awesome-Trac » Wed Mar 27, 2013 5:35 am
jaydog82 wrote:i just installed an apexi ebay turbo timer, hit me up for the wire colors. get a boost valve brand mbc.
I have the same Apexi turbo timer as well including the hks TT-1 harness which makes it easier on hook up. Did I hook up the other features on the timer?
•Daniel
Awesome-Trac
Re: PROJECT AWESOME
Postby jaydog82 » Wed Mar 27, 2013 1:55 pm
i hooked it up to the ecu for the afr, but i think i need to check it because the afr does not work.
jaydog82
Re: PROJECT AWESOME
Postby Awesome-Trac » Wed Mar 27, 2013 3:04 pm
jaydog82 wrote:i hooked it up to the ecu for the afr, but i think i need to check it because the afr does not work.
Cool but I heard these afr reading from the turbo timer are inaccurate tho which is why I left mine alone
•Daniel
Awesome-Trac
Re: PROJECT AWESOME
Postby underscore » Wed Mar 27, 2013 3:52 pm
If you stock O2 sensor is a narrowband one then you won't be able to pull the AFR from the ecu.
Re: PROJECT AWESOME
Postby jaydog82 » Wed Mar 27, 2013 4:52 pm
its a 4 wire so idk, can i hook the tt up to mu wideband?
jaydog82
Re: PROJECT AWESOME
Postby underscore » Wed Mar 27, 2013 5:06 pm
depends if it's a wideband sensor or not, and what kind of signal it's putting out vs what the gauge is expecting to see.
Re: PROJECT AWESOME
Postby McKenzieJr18 » Wed Mar 27, 2013 6:46 pm
On my aem uego the oxgen sensor signal is only used for reference for the guage. The narrow band guage only reads 0 to 1v and the wideband read 0-5v
92 alltrac 3rd gen 3s
McKenzieJr18
