$400 Surprise Part Deux
Re: $400 Surprise Part Deux
Postby wakkjobb » Thu Mar 14, 2013 1:31 am
My wheels bring all the boys to the yard...
They were:
...then...
...and then...
Bazinga!
Next to my VW winter wheels:
Anyone in my shoes would have done the same. $15 for a set of wheels? Sure! Access to all manner of paint? Well, let's see what we can whip up!
And in other news, I got the title for ye secret AllTrac today... :D :D :D
MFIC at Rainbows and Unicorns Fabwerkz :D
Old build:
http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=27648
New build:
http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=42305
Go-Fast parts:
siliconeintakes.com
wakkjobb
Postby UtahSleeper » Thu Mar 14, 2013 1:37 am
NICE!!! Congrats on finally getting that shit done!!!
UtahSleeper
Postby wakkjobb » Fri Mar 15, 2013 3:12 pm
Word, it was easier than I had imagined. :shrug: If I didn't work where I do, it could have a colossal nut roll.
Anyways, the thing's heater doesn't get "hot"; so I thought I had put in the t-stat wrong/upside down, causing an air bind or whatever. Took it out yesterday; no wiggle valve... hm. What to do? Drill a 3/32" hole and replace. Simple.
Still no heat. It'll get warm, there's coolant flowing (checked with temp gun) and the engine itself gets to temp, fans kick on etc. I can't exactly remember, but I think heat was kicking when the car was moving. This has me stumped; I can't think of what else it could be... It has the fancy "auto climate" heater controls, maybe something inside there is amiss. A thought I had was to undo the heater core at the firewall and run a garden hose through it to flush out anything, is there's anything in there. After all, it was sitting in a field for 6 years or so... who knows. Another day...
I have to chase a wire from the ignition to the starter; once upon a time it worked great, but then... nothing. To start it, I have a pipe holding down the clutch, then I jump the starter to the battery. It works, but it's far from ideal. I am so rusty for working on these things; but hopefully it'll all come back to me and I'll be able to drop the engine/trans in 3 hours like old times... 'cause that clutch has got to go. Also going: cruise, A/C, EGR and any leaky old hoses I can find. I still have a set of brand new OEM HFH from the blue Trac build; lucky me! I think the mod list will be limited to:
oil filter moving
oil cooler
3SFE water pipe
make a hose fitting for turbo cooling
(screw buying a turbo-specific radiator $$$)
FCD
another fan for TMIC radiator
short shifter
maybe hood vents...
Other than that, I am leaning towards keeping this one "stock-ish"; FMIC is unlikely... time will tell.
Old build:
New build:
Go-Fast parts:
siliconeintakes.com
wakkjobb
Postby phattyduck » Fri Mar 15, 2013 3:53 pm
Use MR2 5s-fe coolant bypass pipes - it will give you the fittings needed for cooling the turbo (normally go to the oil cooler) and wont' have the extra outlet for the turbo near the coolant outlet. Then you can use a normal radiator. You could also use the hoses normally used for the throttle body coolant lines, though those might be a little long/awkward to use.
A regular problem on the Camry auto climate control panel is the solder connections on the ribbon cable between boards of the panel. Pull it out and hit each connection with a soldering iron to reconnect any broken joints. Also look for cracks/problems on the PCBs themselves.
For the starter... first check the starter contacts internally (search google for 'denso starter contacts' for tons of info). If those are in good shape, you'll want to add an extra relay between the solenoid wire and the starter (effectively removing the larger current draw that normally goes through the ignition switch and take it through a relay right from the battery). I can point you to a nice Camry write-up on that one if you need extra info.
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby wakkjobb » Sun Apr 21, 2013 10:19 pm
Wired in a relay to make the key work again, thinking of selling it since I want to go wheeling and a buddy is considering giving up on his build.
$2000/obo, runs, drives, no smoke, usual leaks, no drips though, I have driven this one a total of 40 miles. Needs struts, axles, clutch, radiator, windshield and someone with no projects to pay attention to it.
Colorado title
Old build:
New build:
Go-Fast parts:
siliconeintakes.com
wakkjobb
Postby wakkjobb » Mon May 20, 2013 12:51 am
Had a guy offer an '88 Prelude w/ 4-wheel steering and bad rust in trade for my non-rusty turbo 5-speed AWD Celica.
Oh yeah, I'll go for that... :rofl:
Old build:
New build:
Go-Fast parts:
siliconeintakes.com
wakkjobb
Postby Dracov » Fri May 24, 2013 6:42 pm
Oh c'mon. Who wouldn't want a rare piece of machinery with quirky mechanicals that are temperamental on the best of days and nearly impossible to find parts for?
...oh wait, you're selling your 165...again. Guess that answers it. :P
1988 Toyota Celica Alltrac
Dracov
Postby wakkjobb » Mon Jun 03, 2013 10:29 pm
Another tire-kicker... at this rate I'll keep the damn thing as a winter car and rebuild the Civic for a mileage car. My friend has a 79 K10 he'll sell to me for $800; rougher than hell but runs well, then I'll have all the vehicle bases covered. Trying to get $ together to buy a turn-key wheeling rig... went to pick up a free auto trans/t-case Sunday and the guy says he's going to sell his built rig soon as he finishes another auto to manual swap (87 4Runner of his). It's built with 90% of the goodies I'd put on it:
90? 4Runner (room for wife dog beer and gear) :D
internal 1.75" DOM cage, sliders, bumpers, 9k winch
3.4 swap (had 3.0h No!), manual trans, dual cases, 4.7 in rear case (super-low crawl ratio, like 200:1 ? )
Hi-Steer, solid axle swap, Detroit lockers front/rear, 4.88 gearing, or 5.29? I forget...
leaf swap in the rear, originally had coils (boooooooooooo)
riding on 35" tires, those General Grabbers with the diagonal tread... meh
some fancy Pioneer stereo
I'd add:
York 210 compressor and 10-gal air tank for on-board air awesomeness
different shoes; not a fan of the Generals for crawling and they're loud as shit on the road
lower it a touch, but it sits low already
sell/trade the front Detroit for a selectable locker like an ARB
paint it... it has some kind of "bedliner" on the lower half that looks like it was applied with a combination of brush, impact (thrown or smeared on) and spray gun handled by a drunk blind chimpanzee. He didn't do it and doesn't like it either, but that's how he bought it. It's also overdone olive drab, so that would change.
That's about it... but we'll see WTF really happens in August.
Wish me luck, I leave this Friday.
Think fish.
Old build:
New build:
Go-Fast parts:
siliconeintakes.com
wakkjobb
Postby wakkjobb » Thu Jun 06, 2013 9:14 pm
Guess who found out this 2-year secret today?
Guess who's okay with it? :shock:
Guess who's still married? :D
Win... so much WIN!!!
Old build:
New build:
Go-Fast parts:
siliconeintakes.com
wakkjobb
Postby RedCelicaTRD » Thu Jun 06, 2013 10:18 pm
So you're keeping it?
Postby wakkjobb » Fri Jun 07, 2013 1:35 pm
Yep, keeping it for winter use, some boost and orange juice... it rhymes. :shrug:
Lame-ass phone pics...
Old build:
New build:
Go-Fast parts:
siliconeintakes.com
wakkjobb
Postby LegacyofDan » Tue Aug 06, 2013 12:16 pm
Win!
Postby wakkjobb » Thu Aug 08, 2013 1:32 am
Win in the making; current battle is squeezing money from thin air; seriously thinking about selling the Civic once the swap is done and dumping some $ into Charlotte the Harlot. Some, not all... got bills to pay, got mouths to feed-there ain't nothing in this world for free.
I'd do the immediate repairs:
clutch
radiator (from N/A car)
axles
alternator rebuild
gut the DP
and drive it easy.
I did drive it around the block yesterday in the fresh rain; add wipers to that list.
Old build:
New build:
Go-Fast parts:
siliconeintakes.com
wakkjobb
Postby Theman88b » Sat Aug 10, 2013 5:40 am
Just got done reading that 59 page :shock: build thread on the $400 surprise part 1(the blue one I own now). I did not know you put that much work in the beast. I am glad to see you found one in good condition, much easier to work with when they are stock.
'88 Toyota Celica All-Trac Turbo(Blue) 145k - Race car!!!
'92 Ford Taurus SHO(White) 212k - Intake and exhaust, needs a clutch at the moment
'98 Jeep Cherokee - Current DD, 33" tires and 2 light bars :rofl:
Theman88b
Images: 3
Postby wakkjobb » Tue Aug 13, 2013 1:32 am
Yeah, when you have lots of space, time and easy money; projects turn out better and faster. Thanks, Montgomery GI Bill!
I can't believe I did so much work on that car either; that's easily the most labor-intensive project I've done so far. I don't think my 67 truck will be that involved; and that's a partial frame-up restoration (on hold).
Old build:
New build:
Go-Fast parts:
siliconeintakes.com
wakkjobb
