dustinbart
New member
Hey guys, I'd like to start off by thanking everyone for all the information that is shared on this site. It has helped me countless times throughout my rebuild process. Ok now onto the build. I bought an 88 all trac off a buddy of mine for a price I couldnt refuse. But little did I know all the headache that would come with it. First off I NEVER heard the car run do to the fact the engine in the car had a spun bearing and he already started to pull apart the engine. Luckly the car came with an extra engine and transmission out of a all trac with 60,000 miles on it. I decided it was best to rebuild the engine with 60,000 before i pulled the engine and trans that was already in the car. I did just that and I paired the rebuilt engine and trans together and put them in (dropped subframe to pull the engine and put the new pair in through the bottom as well). My father owns a fully stocked auto garadge so i had all the tools I needed and a lift to do the heavy lifting for me. To pull the engine and and put in the other engine took MAYBE an hr at most. My father is verrrrry efficent and know his sh#$, blew my mind how fast it went. Soooo let me just go ahead and list everything done to the car...bare with me.....
Water pump
Timing belt
Timing belt tensinor and idler pully
Main and Rod bearings (Acl?)
every gasket you could imagin including valve cover seal
light weight fly wheel
stage 2 clutch
twin entry Turbo conversion (uncle owns a machine shop and made a custom spacer for clearence issues I'm sure you all are aware of)
Turbo rebuilt (Gpop Shop) VERY nice people even hooked me up!
fuel cut off to run higher boost
Super Air flow converter
Turbo timer
HKS mushroom airfilter
new OEM AFM
performance exhaust manifold
3'' down pipe
3'' exhaust all the way through
meagan muffler
boost gage
temp gage
blitz bov
new belts (power steering and alt.)
ASI radiator
Battery relocation to the trunk
MSD coil
new cap, rotor, wires, ngk plugs
short shifter
As to the exterrior
shaved door handles
Shaved rear wiper
Shaved antenna
new pant job (gun metal- lots of flake)
and the said part is....I still havent seen it run :x but hopefully that day will be soon.
Water pump
Timing belt
stage 2 clutch
Turbo timer
new OEM AFM
3'' down pipe
meagan muffler
boost gage
temp gage
blitz bov
ASI radiator
MSD coil
short shifter
As to the exterrior
shaved door handles
Shaved rear wiper
Shaved antenna
