Project: Force Fed GT4
Postby klue » Mon Nov 07, 2011 3:17 pm
Hey guys and gyals,
I decided to do a quick little write up on the car that I'm working on at the moment. Since I have never actually taken the time to do a my project for myself, I choose my second favorite car. The car is a 1990 GT4 straight from Japan. Condition is excellent inside and out, a real pleasure to wrench on VS the rusty Canadian cars I'm used to building. For a little back ground, the car was previously "stock" and running a GT2871 turbo kit. With upgraded management,fuel, inter cooling and suspension the car was able to muscle out a mid 13 sec pass. When I was first introduced to the owner it was already set up and running mediocre. He had it built and tuned at a local tuning shop and the work was sub par. They complained that it was running lean and thus was developing minimal power. Sadly, the shop just did not know apples from oranges. After some quick tuning with the management system we rekindled the missing power and the car was running great. This was short lived as I suspect the months of running lean took a toll on the pistons. After getting the extra 40-50 ponies they let go.
With a few tear drops and dollars in hand we set out to build a bad ass, force fed GT4. Guide line for this build was strictly give her hell. The whole build is based around the turbo charger. Selecting a Garrett GT35, .63 for the pumping duties. Forged pistons and rods will hold the ship together, and a rebuilt head to flow the air. Lots of custom parts on this build, and a few top secret mods :smokes:
Im going to add the pics slowly so bear with me :)
If your interested in seeing more up to date info you can log onto the club site at http://www.prydeauto.com
Cheers
Here is the block right from the Machinist
Pumps on, and tucked nicely between a st165 and st184T
Custom EGR block off for the USDM head we sourced
HFH
3sgte donor head, vs a d17 honda. both with instructions for the machinist
waiting for the head to come back
B4 pic of the rollers, 18inches of JDM drift
Re: Project: Force Fed GT4
Postby Rpz123isme » Tue Nov 08, 2011 12:09 am
No bake and shot peen on the block?
Hesperia, CA
Rpz123isme
Postby klue » Tue Nov 08, 2011 6:11 pm
Rpz123isme wrote:No bake and shot peen on the block?
It looked baked when I got it, but it wasn't shot peen'd. Do you mean shot peen the block, or bores specifically?
More pics
Manifold all ready
Postby klue » Fri Nov 11, 2011 1:36 am
Skip ahead a bit cylinder head is mounted
TVIS eliminator
Got a nice competition light weight flywheel 11.9 lbs
Postby klue » Sun Nov 13, 2011 3:37 pm
Here is the long block assembly, almost fully assembled. Think I was doing the valve clearance at the time. Used the later revision 3sgte cams to keep the VE broad across the band. The cams are properly timed stock and with our combination of parts creates a interference motor condition.
Running tein coilovers to control the wheels. You can see the new SS brake lines, painted up everything pretty
Here is another pic, the ARP wheel studs are in to accommodate our 18inch spinners
Postby klue » Sun Nov 13, 2011 3:39 pm
Postby klue » Mon Nov 28, 2011 3:01 pm
Nice hi res pic just before the belt gets timed
Postby klue » Thu Dec 15, 2011 11:43 pm
Running the gen3 cams, shim'd to my specs. Still using the shim over bucket set up. May end up doing the head again when we have a intake manifold which can support more RPM
Engine button'd up on the stand
Bully st.4 clutch mounted, light weight flywheel and ARP bolts holding it on
Ready to drop
Postby underscore » Fri Dec 16, 2011 1:36 am
beautiful build, any estimates on power once it's done?
Postby klue » Thu Dec 22, 2011 7:26 pm
Should be able to get 350whp without a sweat
Postby UtahSleeper » Thu Dec 22, 2011 8:00 pm
Damn that motor is looking good. Not sure if I missed it, but what will be controlling it?
UtahSleeper
Postby mixer72 » Thu Dec 22, 2011 8:24 pm
looks rely great mate :) you should get the power your after pritty easy :)
the big build viewtopic.php?f=44&t=34183
mixer72
Postby klue » Tue Jan 03, 2012 5:28 am
Some more p0rn,
Postby celigts » Tue Jan 03, 2012 9:46 am
So far what's the cost of the build?
If you don't mind saying ;)
3SGTE project motor very slow
celigts
Postby klue » Tue Jan 03, 2012 3:40 pm
Lets just say, you could raise a small village with whats under the hood alone :rofl:
