bmt":p3236w7c said:So I should be able to put it into my top hose and run the bleed off to my original tank correct? My little tank can then be a ,(very), small header tank as well? If I can do it like that I will whip one up!! I guess the size is about 75mm dia and about 120mm high, a cone on the top to help funnel the air off. I imagine that the inlet and outlet just have to have a decent vertical gap between them to promote flow?
Youll see in the Milner photo quite a large bleed tank.
Im not sure exactly how large one should be
The most important thing is to have it above the highest coolant point in the engine bay, so air heads up to it, and cant return.
Higher up the better.
