St215 motor + st205 gearbox into St165 JDM build
Re: St215 motor + st205 gearbox into St165 JDM build
Postby bmt » Thu Dec 03, 2015 5:39 am
WRX STI discs from 2002 through to 2004 I think? 326mm diameter, 30mm thick, bore 58mm, 53mm high. If you do a search on the DBA discs website you can confirm it.
bmt
Postby DeeCee » Thu Dec 03, 2015 6:48 am
Same as mine. How's your ball joint clearance under compression?
DeeCee
Postby bmt » Thu Dec 03, 2015 7:00 am
To be honest, no idea. Problem? Car is at painters so I cant check. I still need to change my master cylinder for a new one in the vain hope it will give me a consistent pedal. :bangshead:
bmt
Postby DeeCee » Thu Dec 03, 2015 7:11 pm
I had around ~1.2mm clearance when I was measuring up my brake kit. Others who have used the wrx disc have noted rubbing on the ball joint under load, requiring the ball joint to be ground back ~1mm or so to gain disc clearance. Just something to be aware of :)
DeeCee
Postby bmt » Sat Feb 06, 2016 8:34 am
So an update is WELL overdue. Finally got all the electrics working again. If there is one thing I have learnt from this build it is to never again to piss about with the electrics in the manner I did. That is remove the entire loom forward of the door openings. Whilst I am happy with the result of having all my fuses in one place it cost me untold amounts of anguish not to mention money. Other than that it's still the brakes that are denying me.
I have a brand new master cylinder (Camry 1"). A residual (2psi) valve on the front circuit, (Combat pad knock). A manual brake proportioning valve. Brembo front calipers from an Evo. Rear calipers are St205. St202 booster. Brand new stainless braided lines. Vacuum check valve is ok. Mintex 1166 pads. Fluid is good.
Every part has been checked, the system has been bled countless times and yet I still cannot get a consistent pedal.
Things I have noticed.
When the car is parked overnight with the car running the first push on the brake pedal is long.
Pedal will pump up if I pump the brakes.
The disconcerting thing is that on the road it's ok but at the track I get a great pedal sometimes then not then ok but not great. It isn't like brake fade because the pedal doesn't get overly long and soft. I'd say it feels like a "middle" pedal. A little bit longer, still firm but no retardation. Could be boiling fluid I suppose but it happens pretty quickly.
Any ideas, anyone?
In other news the car is back from the painters!
(41.87 KiB) Not downloaded yet
(38.06 KiB) Not downloaded yet
It's not totally finished on the outside. There is some more blacking to be done. I had all the windows pulled to check for rust, (unbelievably none!), and filled in the gaps on the bumper by the headlights and got all the trim reblacked. Still have alarm and stereo to fit and tints then it will be done I guess?
bmt
Postby klue » Sat Feb 06, 2016 12:20 pm
Hey,
whats your bleed technique
I'm running wilwoods, with a mess of different lines and what not. It took me forever to get the air out of the system and I still dont get a OEM feeling pedal. But what I noticed is the pedal feel has a lot to do with the brake system temperature. When I get up to temp the pedal gets a lot firmer than just driving around low speed
Postby ZeroDrift » Sat Feb 06, 2016 1:01 pm
The car is looking great! The hood and lights really add to a more modern look!
Air in the lines can be a major pain to deal with. May want to invest in some speed bleaders to make the process easier. I am not sure what you did with the brakes, but if you changed calipers, make sure they have the bleed screw at the highest point. Otherwise the system will trap air within the caliper itself.
Postby athousandleaves » Sat Feb 06, 2016 1:48 pm
ZeroDrift wrote: May want to invest in some speed bleaders to make the process easier.
I nearly bought these but then I read some reviews, apparently they are prone to shearing off inside calipers when tightened.
I'd recommend trying to reverse bleed the system if you think there's still air in the lines.
1992 Red GT-FOUR RC 626•1800
1992 White turbo4WD
athousandleaves
Postby bmt » Sat Feb 06, 2016 7:03 pm
Thanks for the replies guys!
Bleed process i did was to bleed the master then move to the proportioning valve bleed there. Then bleed at, (in order), left rear,right rear,left front finally right front. All bleed points on calipers were at the top. I use a vacuum bleed at first then with help from a mate old school manual bleed.
Athousandleaves How do you reverse bleed? Pressurise the system from the caliper? How?
bmt
Postby athousandleaves » Sat Feb 06, 2016 7:09 pm
https://youtu.be/231oK-_p5so
Takes a special tool, easy enough to DIY one if you're crafty.
1992 White turbo4WD
athousandleaves
Postby ___Scott___ » Sun Feb 07, 2016 2:05 am
You say "Brand new stainless braided lines". I assume you are referring only to the flexible lines that connect to the calipers?
Just to cover all the bases...
If you replaced all the hard lines with flexible stainless braided lines, you would get a soft peddle because of the expansion flexible lines exhibit under pressure. The more flex line, the more expansion and the softer the peddle. Also, if somehow you ended up with excessively stretchy lines, you may experience a soft peddle even if you only replaced the lines at the calipers. That will be true even with no air in the system.
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Postby bmt » Sun Feb 07, 2016 3:16 am
Yep just the flexible lines to the calipers. I'm going to have a go at making up a tool to reverse bleed it.
bmt
Postby bmt » Sun Mar 13, 2016 2:18 am
DeeCee wrote:I had around ~1.2mm clearance when I was measuring up my brake kit. Others who have used the wrx disc have noted rubbing on the ball joint under load, requiring the ball joint to be ground back ~1mm or so to gain disc clearance. Just something to be aware of :)
I had a look the other day and when it was on droop on the hoist I had about 5mm of clearance and no evidence of anything rubbing on the ball joint.
bmt
Users browsing this forum: Yahoo [Bot] and 5 guests
